Check Engine Light #3067188
08/11/22 09:45 PM
08/11/22 09:45 PM
Hunt Valley, Maryland
1fastrunner Offline OP
Hi,
I have a 2009 Dodge Ram 1500 with the Hemi. It has 33K miles and is not driven often. A couple months ago the CEL came on and then went off some time later. The other day it came on again, but has stayed on. The code is P3401. When looking this up showed the engine running poorly, it made me wonder as mine actually runs better. My MPG has gotten better since the light has been on, MDS has not been coming on with the CEL.
Any ideas what could be going on or what to check? Hate to have to get the manifold pulled to check the solenoids when it could be n easier fix.
Re: Check Engine Light [Re: 1fastrunner] #3067207
08/11/22 10:57 PM
08/11/22 10:57 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Have erased the code and see what it does. Maybe it won't come back on. You could also disconnect the battery for a bit and lst the system reboot. Just a couple ideas. You never know.
Re: Check Engine Light [Re: stumpy] #3067357
08/12/22 02:09 PM
08/12/22 02:09 PM
Cleared the code and went for a ride. The Fuel Saver light came on, then went off and the CEL came back on. I believe it's the solenoid that could be bad which won't let the engine go into MDS mode. The problem is the solenoid is located under the manifold. I wish there was an easy way to at least verify that it is the solenoid, or a way to get [censored] off the MDS.
Re: Check Engine Light [Re: 1fastrunner] #3067491
08/12/22 09:43 PM
08/12/22 09:43 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
First, dont let something as simple as an intake manifold deter you from making a repair. Its a 10 minute job to remove. But before you replace anything, pay a pro with up to date diagnostic equipment to pinpoint the issue. You'll be miles ahead then just guessing. Second, just a warning- if you're set on removing and inspecting an mds solenoid, buy a new one. You will break it removing it. The job, if it is in fact an mds solenoid, is super simple. Look online for a mopar overstock/wholesaler to purchase the solenoid from. Its a savings of near $100 a piece. Buy the Mopar brand.
Re: Check Engine Light [Re: 1fastrunner] #3067492
08/12/22 09:44 PM
08/12/22 09:44 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
maybe this will help shruggy VIDEO LINKY ONLY 4 MINUTES
Re: Check Engine Light [Re: TJP] #3067530
08/13/22 06:09 AM
08/13/22 06:09 AM
Port Huron, Michigan
MI_Custumz Offline
MI_Custumz  Offline
Does the 2009 have lifetime power train warranty from Mopar? If so, it may be a free fix at the dealer. Not sure when they quit offering the lifetime on power train.
Re: Check Engine Light [Re: MI_Custumz] #3067595
08/13/22 11:38 AM
08/13/22 11:38 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Re: Check Engine Light [Re: Moparite] #3067706
08/13/22 05:48 PM
08/13/22 05:48 PM
I do have the lifetime power train warranty, not sure if it applies.
I am looking at possible causes and eliminating them as I can.
Oil level was good
Oil pressure is good
Changed the oil today just to see if that helps
Then most likely to the dealer.
Re: Check Engine Light [Re: MI_Custumz] #3068092
08/15/22 09:38 AM
08/15/22 09:38 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
2009 was the last year for the Lifetime powertrain.
Re: Check Engine Light [Re: JohnRR] #3068399
08/16/22 09:21 AM
08/16/22 09:21 AM
I have an appointment at a dealer tomorrow. They want $180 to diagnose it, and can't verify if it is covered under the warranty.
Re: Check Engine Light [Re: 1fastrunner] #3068724
08/17/22 05:38 AM
08/17/22 05:38 AM
MI_Custumz Offline
MI_Custumz  Offline
If it's covered under warranty (either max care or factory powertrain), the diagnostic fee should be waived.
Re: Check Engine Light [Re: MI_Custumz] #3069001
08/17/22 09:30 PM
08/17/22 09:30 PM
Thanks to all, it ended up being the solenoid for cylinder 1 that was bad. It was all covered under warranty, including the diagnostic fee.
Re: Check Engine Light [Re: 1fastrunner] #3069018
08/17/22 10:21 PM
08/17/22 10:21 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
up thanks for the follow up wink
Re: Check Engine Light [Re: 1fastrunner] #3069064
08/18/22 06:02 AM
08/18/22 06:02 AM
MI_Custumz Offline
MI_Custumz  Offline
I have lifetime max care on 2 of my vehicles. Co worker says I'm crazy for taking the vehicle to the dealer for brakes since other shops can do it cheaper. While that is true, they try to make sure any issues that the warranty will cover are covered.Corrosion issues are not covered, and in Michigan that is an issue. They worked around it a few times. Pay a little more for maintenance, but when it comes to expensive repairs, the max care pays off.
Re: Check Engine Light [Re: MI_Custumz] #3070378
08/22/22 09:44 AM
08/22/22 09:44 AM
Well, while that CEL fix was free, my recall costed me over $1,000 on the same visit. The recall was for the gas tank strap because of it being weakened by rust and corrosion. When they droped the tank, the strap and the bracket it was supposed to hook up to were rusted. They had to weld in a new bracket, replace the brake line that was also corroded in that area. I guess I should be happy the brake line was taken care of, but all that happened because of the corrosion above the gas tank, which is why they initiated the recall.
Re: Check Engine Light [Re: 1fastrunner] #3070386
08/22/22 10:00 AM
08/22/22 10:00 AM
md
mopars4ever Online content
mopars4ever  Online Content
md
Seems to me if the strap was under the recall then so should the damaged area where the strap attaches? Make no sense to give you a new strap but no place to attach it to due to rust. I would look into it a little further.
