Page 1 of 3 1 2 3
Lower control arm bushing #3067751
08/14/22 12:11 AM
08/14/22 12:11 AM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
This is for '70 E-body, I got the Energy Suspension front bushing kit 5.3112g
Is this how it goes together in the picture, grease everything up and push it all together ? I'm not missing any washers or anything am I ?
The outer shell is in the LCA and the inner shell is on the spindle.
Re: Lower control arm bushing [Re: hemienvy] #3067753
08/14/22 12:17 AM
08/14/22 12:17 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
You MUST use that thick and gooey white/clear urethane paste-grease or these will S-q-u-e-a-k !
Re: Lower control arm bushing [Re: Kern Dog] #3067755
08/14/22 12:27 AM
08/14/22 12:27 AM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Thanks Kern Dog, I bought an extra tub of that stuff, they never give you enough with those itty bitty packets.
Re: Lower control arm bushing [Re: hemienvy] #3067757
08/14/22 12:36 AM
08/14/22 12:36 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Sand the rubber out off the inner and outer shells.
I sanded then polished mine. Never squeak since 1997.
Re: Lower control arm bushing [Re: hemienvy] #3067823
08/14/22 12:23 PM
08/14/22 12:23 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Agreed wink More is better and wipe off the excess after assembly.
BTW Great stuff isn't it? I've even thought of putting it on door knobs, car door handle's of those that have uhh PMO. Also be great on a co-workers tools, tool box drawers etc. laugh2
smile
Re: Lower control arm bushing [Re: TJP] #3067863
08/14/22 02:34 PM
08/14/22 02:34 PM
moparx Offline
moparx  Offline
"Also be great on a co-workers tools, tool box drawers etc. laugh2"
so YOU are the guy that was always greasing my office door knob at work ! biggrin
beer
Re: Lower control arm bushing [Re: hemienvy] #3067940
08/14/22 05:54 PM
08/14/22 05:54 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Your assy process is correct, however I recommend you purchase the front 2 pc strut rod poly package, the stock strut rod bushings in the K frame will splay the LCA's rearward when you start to mount everything up
Re: Lower control arm bushing [Re: DAYCLONA] #3067963
08/14/22 06:52 PM
08/14/22 06:52 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
DAYCLONA, I was leaning against doing those on the strut rod, but this is my first rodeo.
Are you saying the stock rubber bushings don't compress quite enough ?
I see that the OE setup does not appear to have any length adjustability.
Re: Lower control arm bushing [Re: hemienvy] #3067989
08/14/22 08:48 PM
08/14/22 08:48 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Well guess what, I found a new set of Moog K7026 strut rod bushings,
I think I bought these about 25 years ago.
Re: Lower control arm bushing [Re: hemienvy] #3067998
08/14/22 09:07 PM
08/14/22 09:07 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Performance Suspension Technology, p-s-t.com, has adjustable strut rods for $325 a pair
Anybody tried them ?
Re: Lower control arm bushing [Re: moparx] #3068006
08/14/22 09:51 PM
08/14/22 09:51 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
beer
NOT ME I wouldn't do such a thing to a decent person beer
Re: Lower control arm bushing [Re: hemienvy] #3068010
08/14/22 09:58 PM
08/14/22 09:58 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
The problem with those IMO is you are side loading the bushing to achieve adjustment (usually more caster) that was not designed in. If you desire more adjustment I would recommend Adjustable upper control arms. twocents beer
Re: Lower control arm bushing [Re: TJP] #3068022
08/14/22 10:35 PM
08/14/22 10:35 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Side loading the LCA bushing, OK I see that.
Our cars have, unfortunately, not the greatest front suspension geometry. The fulcrum axis of the strut rod is not co-linear with the the torsion bar axis,
so the LCA bushing is going to be deformed anyway by the different arcs of movement of the LCA and the strut rod, moving up and down. Oh well.
I was just thinking about ease of assembly. I guess it's not that bad.
Re: Lower control arm bushing [Re: hemienvy] #3068068
08/15/22 09:01 AM
08/15/22 09:01 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Hmmm, if putting ‘grease’ on the bushing what keeps the LCA from coming off? Or at the very least moving back and forth? There’s a reason the pin is so hard to get out when replacing.
Re: Lower control arm bushing [Re: cudaman1969] #3068071
08/15/22 09:14 AM
08/15/22 09:14 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Exactly the reason why I wouldn't put poly bushings on the front end of a street driven car ... but that's me .
People that swear by them say they don't move back and forth .... fan
Re: Lower control arm bushing [Re: JohnRR] #3068079
08/15/22 09:24 AM
08/15/22 09:24 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
The rubber is the part that twists or moves. Not much since the wheel should only move up and down 3-4” in normal day to day driving, I doubt many do Dukes of Hazard jumps everyday.
Re: Lower control arm bushing [Re: cudaman1969] #3068238
08/15/22 05:52 PM
08/15/22 05:52 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Torsion bar keeps the LCA in place....
Re: Lower control arm bushing [Re: DAYCLONA] #3068243
08/15/22 06:15 PM
08/15/22 06:15 PM
White Plains, NY
VCODE Offline
VCODE  Offline
White Plains, NY
I do not use this system, I replace with NOS lower control arm bushings. It's not that difficult. I have seen cars with them on and they did move.
my 2cents
Bob
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
Re: Lower control arm bushing [Re: hemienvy] #3068249
08/15/22 06:52 PM
08/15/22 06:52 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I thought this debate was put to bed years ago and the poly lost due to squeaks and movement. Seems not.
Master, again and still
Re: Lower control arm bushing [Re: DaveRS23] #3068276
08/15/22 08:22 PM
08/15/22 08:22 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
I've used both polyurethane and poly graphite-impregnated on other cars and never had a squeak.
The issue of movement, of either the T-bar or the LCA, is new to me.
Page 1 of 3 1 2 3
