Re: SW Temp Gauge Probe Install
[Re: topside]
#3067923
08/14/22 05:15 PM
08/14/22 05:15 PM
Posts: 21,064 Niles , Ohio
therocks
Niles , Ohio
reducer needed as said.We got them at Advanced .Think they were a few bucks.
Chrysler Firepower
[Re: 44D6PAKCUDA]
#3068114
08/15/22 10:47 AM
08/15/22 10:47 AM
Posts: 9,388 Super Spudsville
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
One simple brass fitting will do it on your oem intake, If I cant find the fitting today I will post a pic of it when in use.
I used this fitting on a 70 6bbl intake so I dont see why it would not work on a 4BBL.
Still lets the tip of the sender be in the coolant flow and it seemed to be accurate.
I will see If I have a extra one if you cant source one.
STOP POTATO HATE!
[Re: Mr PotatoHead]
#3068347
08/15/22 11:34 PM
08/15/22 11:34 PM
Posts: 10,198 Someplace you aren't
SomeCarGuy
I’ve had to build an adapter before but it’s been decades ago so I can’t point you to the port. Just a task you need a box of fittings in front of you while under hood.
I want my fair share
[Re: Mr PotatoHead]
#3068372
08/16/22 06:55 AM
08/16/22 06:55 AM
Posts: 2,294 Land of 10,000 Lakes
44D6PAKCUDA
So I need to remove the larger,outside adaptor that is on the sender probe now and find an adaptor to fit the OE sender hole and the smaller fitting on the gauge/probe correct? Thanks Mr Potato
[Re: 44D6PAKCUDA]
#3068376
08/16/22 07:38 AM
08/16/22 07:38 AM
Posts: 1,819 South Bend
John Brown
South Bend
Whatever you use, be sure the fitting the temperature probe fits into has a seat for the probe to seal to. If it doesn't have that seat, you're gonna have leak city going on.
[Re: 44D6PAKCUDA]
#3068717
08/17/22 02:56 AM
08/17/22 02:56 AM
Posts: 43,097 Bend,OR USA
Cab_Burge
Do NOT use any thread sealer on either part , the senders need to be well ground to work properly
[Re: Cab_Burge]
#3068762
08/17/22 08:59 AM
08/17/22 08:59 AM
therocks
Niles , Ohio
Cab its mechanical not electric Dosent need a ground.
Chrysler Firepower
[Re: 44D6PAKCUDA]
#3068777
08/17/22 09:51 AM
08/17/22 09:51 AM
Posts: 15,268 Omaha Ne
TJP
Omaha Ne
So I need to remove the larger,outside adaptor that is on the sender probe now and find an adaptor to fit the OE sender hole and the smaller fitting on the gauge/probe correct? Thanks Mr Potato What is the OD of the probe? I believe the Chrysler sending unit ports are 1/8 NPT. 1/8 NPT outside thread diameter is ~.375> Your probe looks to be fairly large which my not leave enough wall thickness for an 1/8 NPT adapter
[Re: 44D6PAKCUDA]
#3069850
08/20/22 12:03 PM
08/20/22 12:03 PM
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
Ok, two fittings.... dam the memory sucks at times.
But id not be worried about how much get exposed to coolant, if the tip does it will heat soak as thats all it does in the first place. Had this config going for over 10 years with consistent readings.
I just recalled where my fitting box is so I will go dig out the spare for pics.
STOP POTATO HATE!
