Re: Lower control arm bushing
[Re: hemienvy]
#3067757
08/14/22 12:36 AM
08/14/22 12:36 AM
Posts: 27,451 So Cal
autoxcuda
So Cal
Sand the rubber out off the inner and outer shells. I sanded then polished mine. Never squeak since 1997.
[Re: hemienvy]
#3067823
08/14/22 12:23 PM
08/14/22 12:23 PM
Posts: 15,268 Omaha Ne
TJP
Omaha Ne
Thanks Kern Dog, I bought an extra tub of that stuff, they never give you enough with those itty bitty packets. Agreed More is better and wipe off the excess after assembly. BTW Great stuff isn't it? I've even thought of putting it on door knobs, car door handle's of those that have uhh PMO. Also be great on a co-workers tools, tool box drawers etc.
[Re: hemienvy]
#3067940
08/14/22 05:54 PM
08/14/22 05:54 PM
Posts: 18,157 Mass
DAYCLONA
Mass
This is for '70 E-body, I got the Energy Suspension front bushing kit 5.3112g
Is this how it goes together in the picture, grease everything up and push it all together ? I'm not missing any washers or anything am I ?
The outer shell is in the LCA and the inner shell is on the spindle. Your assy process is correct, however I recommend you purchase the front 2 pc strut rod poly package, the stock strut rod bushings in the K frame will splay the LCA's rearward when you start to mount everything up
[Re: DAYCLONA]
#3067963
08/14/22 06:52 PM
08/14/22 06:52 PM
Posts: 903 Washington
hemienvy
Washington
DAYCLONA, I was leaning against doing those on the strut rod, but this is my first rodeo.
Are you saying the stock rubber bushings don't compress quite enough ? I see that the OE setup does not appear to have any length adjustability.
[Re: cudaman1969]
#3068071
08/15/22 09:14 AM
08/15/22 09:14 AM
Posts: 74,947 U.S.S.A.
JohnRR
U.S.S.A.
Hmmm, if putting ‘grease’ on the bushing what keeps the LCA from coming off? Or at the very least moving back and forth? There’s a reason the pin is so hard to get out when replacing. Exactly the reason why I wouldn't put poly bushings on the front end of a street driven car ... but that's me . People that swear by them say they don't move back and forth ....
[Re: JohnRR]
#3068079
08/15/22 09:24 AM
08/15/22 09:24 AM
Posts: 8,233 fredericksburg,va
cudaman1969
fredericksburg,va
Hmmm, if putting ‘grease’ on the bushing what keeps the LCA from coming off? Or at the very least moving back and forth? There’s a reason the pin is so hard to get out when replacing. Exactly the reason why I wouldn't put poly bushings on the front end of a street driven car ... but that's me . People that swear by them say they don't move back and forth .... The rubber is the part that twists or moves. Not much since the wheel should only move up and down 3-4” in normal day to day driving, I doubt many do Dukes of Hazard jumps everyday.
[Re: cudaman1969]
#3068238
08/15/22 05:52 PM
08/15/22 05:52 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Hmmm, if putting ‘grease’ on the bushing what keeps the LCA from coming off? Or at the very least moving back and forth? There’s a reason the pin is so hard to get out when replacing. Torsion bar keeps the LCA in place....
[Re: DAYCLONA]
#3068243
08/15/22 06:15 PM
08/15/22 06:15 PM
Posts: 2,368 White Plains, NY
VCODE
White Plains, NY
I do not use this system, I replace with NOS lower control arm bushings. It's not that difficult. I have seen cars with them on and they did move. my 2cents Bob
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
[Re: hemienvy]
#3068249
08/15/22 06:52 PM
08/15/22 06:52 PM
Posts: 11,996 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I thought this debate was put to bed years ago and the poly lost due to squeaks and movement. Seems not.
Master, again and still
