'69 22" fan shroud & brkts ??? #3067192
08/11/22 09:57 PM
08/11/22 09:57 PM
So Near, Yet So Far
topside Online content OP
topside  Online Content OP
So Near, Yet So Far
I have a plastic 22" fan shroud (# 2998325) off a '70-'72 A body.
Thinking about adding to a '69 Road Runner; it looks the same as the B shroud, except it has some serrations for the upper tank "ribs".
Shouldn't be hard to sand those down so it fits the rounded tank.
Anybody out there have one on theirs ?
I need to know the measurements of the shroud mounting holes/studs.
I can buy a bracket set from Classic ("fits '69-'74 B and '70-'74 E"), but I'd like to be sure they fit this shroud.
Or maybe I should trade it for the dead-correct part...
Re: '69 22" fan shroud & brkts ??? [Re: topside] #3067249
08/12/22 08:02 AM
08/12/22 08:02 AM
Almost Heaven
Bob Stinson Offline
Bob Stinson  Offline
Almost Heaven
Mancini has dimensions for the repop part, should be the same since it fits the a-body radiator.
https://www.manciniracing.com/325.html
69 road runner A12 ex-racer
71 Duster w/ a 400
Shiny paint causes stress.
Re: '69 22" fan shroud & brkts ??? [Re: Bob Stinson] #3067327
08/12/22 11:51 AM
08/12/22 11:51 AM
So Near, Yet So Far
So Near, Yet So Far
Thanks, Bob -
That's the shroud I have, just wondering if the B brackets position it correctly.
My Duster's OEM radiator had tabs instead of the add-on brackets.
The '69 B 22" radiator requires the brackets.
Re: '69 22" fan shroud & brkts ??? [Re: topside] #3067362
08/12/22 02:28 PM
08/12/22 02:28 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Originally Posted by topside
Thanks, Bob -
A Body radiator is shorter than a B body radiator I believe from looking into getting a radiator to put in my Big block A body.
