Re: Shock settings and bias slicks
[Re: justinp61]
#3066729
08/10/22 05:46 AM
08/10/22 05:46 AM
Posts: 2,915 A shed in England
Tig
A shed in England
Generally, you have to calm down the hit and slow the rise going from radials to bias ply's. Otherwise you will just kill the sidewall before you wear the slick down, DAMHIK HTH's
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: dvw]
#3066752
08/10/22 09:10 AM
08/10/22 09:10 AM
Posts: 2,494 PA
moparacer
PA
I agree tighten up the rear rebound. You may have to loosen the rear compression a tad as well. Doug Might end up slowing down the front end too. Too much too quick on a slick is bad.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
