Re: TC bolt tightening sequence
[Re: cudaman1969]
#3066110
08/07/22 06:54 PM
08/07/22 06:54 PM
Posts: 4,706 Florida
BDW
Well that was a F'in nightmare, Flex plate is a universal deal that fits 3 different configurations, took me forever to find the right orientation...... Crawling under car, try, crawl back out, turn motor using socket..........rinse and repeat.
And there was not enough room to use a torque wrench, so calibrated crank and loctite will have to do.
Thx for all the replies, but unless there's a low profile 1/4" torque wrench / socket combo, its not happening.....
[Re: BDW]
#3066115
08/07/22 07:16 PM
08/07/22 07:16 PM
Posts: 20,154 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Thx for all the replies, but unless there's a low profile 1/4" torque wrench / socket combo, its not happening..... Now spray paint the converter and flex plate by one of the bolts so it’s easy to line up next time. I do this on the floor before installation.
[Re: John_Kunkel]
#3066182
08/08/22 10:22 AM
08/08/22 10:22 AM
Posts: 74,970 U.S.S.A.
JohnRR
U.S.S.A.
I use blue on Cummins convertors and never heard of them loosening.
[Re: cudaman1969]
#3066183
08/08/22 10:26 AM
08/08/22 10:26 AM
JohnRR
U.S.S.A.
Since the 90s all the converter bolts (at least the ones for dodge trucks) come with loctite on them and to not reuse the old ones.
I spent a couple year hopping up transmissions for 2nd Gen Dodges with Cummins and V10's about 2002/3 , always reused the bolts with blue loctite , no issues I ever heard of ... YMMV
[Re: JohnRR]
#3066189
08/08/22 10:52 AM
08/08/22 10:52 AM
Posts: 20,154 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Blue, red it doesn’t matter and isn’t worth arguing over. Just remember to clean any oil from the bolts and converter threads.
[Re: BDW]
#3066208
08/08/22 11:46 AM
08/08/22 11:46 AM
Posts: 11,524 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Thx for all the replies, but unless there's a low profile 1/4" torque wrench / socket combo, its not happening..... Torqueflite? I have to assume you haven't done the scallop cut at the bottom of the bell housing. Makes life easier.
[Re: BDW]
#3066218
08/08/22 12:48 PM
08/08/22 12:48 PM
Posts: 8,233 fredericksburg,va
cudaman1969
fredericksburg,va
Thx for all the replies, but unless there's a low profile 1/4" torque wrench / socket combo, its not happening..... Did you remove the starter? Straight shot on both sides of pan too. But that’s why we eventually just use a box wrench and screw driver to hold the ring gear.
[Re: moparx]
#3066220
08/08/22 12:53 PM
08/08/22 12:53 PM
Posts: 15,299 Omaha Ne
TJP
Omaha Ne
"Now spray paint the converter and flex plate by one of the bolts so it’s easy to line up next time. I do this on the floor before installation." i do this before i separate the transmission if i'm going to use the same combo, and it hasn't been marked like this previously. makes life SO much easier ! X3 I'll also do so with the flex plate if it's off or use another/ spare before install
[Re: CMcAllister]
#3066302
08/08/22 05:51 PM
08/08/22 05:51 PM
BDW
Thx for all the replies, but unless there's a low profile 1/4" torque wrench / socket combo, its not happening..... Torqueflite? I have to assume you haven't done the scallop cut at the bottom of the bell housing. Makes life easier. scalloped bell housing? Its a 518, starter not installed, only bolts exposed are at bottom and blocked by oil pan, just not enough room to get a socket in there. I understand why everyone mentioned using a wrench. My bad not marking the orientation before starting. I did mark it with a paint dab, but I really hope this thing never comes back apart. To add insult to injury, the motor mounts pushed the whole assembly forward 1/4-1/2", and that was just enough so that the trans mount no longer aligned. Had to pull the trans cross member and increase the mounting holes for both the transmission cross member and trans mount to get to bolt together, what started out as a 1 hr project took me all day.
[Re: BDW]
#3066321
08/08/22 07:12 PM
08/08/22 07:12 PM
Posts: 3,069 Michigan
A727Tflite
Thx for all the replies, but unless there's a low profile 1/4" torque wrench / socket combo, its not happening..... Torqueflite? I have to assume you haven't done the scallop cut at the bottom of the bell housing. Makes life easier. scalloped bell housing? Its a 518, starter not installed, only bolts exposed are at bottom and blocked by oil pan, just not enough room to get a socket in there. I understand why everyone mentioned using a wrench. My bad not marking the orientation before starting. I did mark it with a paint dab, but I really hope this thing never comes back apart. To add insult to injury, the motor mounts pushed the whole assembly forward 1/4-1/2", and that was just enough so that the trans mount no longer aligned. Had to pull the trans cross member and increase the mounting holes for both the transmission cross member and trans mount to get to bolt together, what started out as a 1 hr project took me all day. Something on this order - most guys make a square cut out - this pic is from a diesel or gas 618. Ignore the highlighted circles.
[Re: TJP]
#3066525
08/09/22 12:44 PM
08/09/22 12:44 PM
Posts: 17,840 S.E. Michigan
ZIPPY
S.E. Michigan
"Now spray paint the converter and flex plate by one of the bolts so it’s easy to line up next time. I do this on the floor before installation." i do this before i separate the transmission if i'm going to use the same combo, and it hasn't been marked like this previously. makes life SO much easier ! X3 I'll also do so with the flex plate if it's off or use another/ spare before install Same. Oldest trick in the book.
Rich H.
Esse Quam Videri
