Page 7 of 12 1 2 5 6 7 8 9 11 12
Re: A Body - Parts For Sale - 3rd Quarter [Re: moparts] #3065246
08/04/22 04:18 PM
08/04/22 04:18 PM
NJ
moparply Offline
moparply  Offline
NJ
Original 1970 Duster Dart 340 Bell Housing, part number 2892482, early 2 - 70 dated, $100
I just cleaned/degreased and inspected the bell housing. It will need some repairs. There is a small crack about 1 1/2" long. It's in an open area and is easy to get to. There are 2 pictures of this area posted.
There are one set of threads repaired with a helicoil. There is some partially missing threads on one of the starter threaded holes, it should probably get a helicoil.
Located in NJ
Email Kenei@comcast.net
Nationals delivery with prepayment.
A body 18 Spline 4 speed set up [Re: moparply] #3065507
08/05/22 03:17 PM
08/05/22 03:17 PM
Southwest Missouri
E
eenloe Offline
eenloe  Offline
E
Southwest Missouri
Here is an almost complete 4 speed conversion set up an A body. Rebuilt 18 Spline A833 transmission. New big block bell housing, inspection cover, ball stud hardware, New McCleod Clutch, Pressure Plate, Flywheel, Throw out Bearing, New Torque shaft and clutch rods all from Brewer's, New Hurst Shifter, Comes with shifter rods, really nice A body Hurst shift lever, Vintage white shifter knob, shift fork, high torque mini starter, floor boot and bezel, firewall and bellhousing boots. If you add all this up new from Brewer's it comes out to almost $6000.00. Sacrificing the whole package for $4,800. See photos for contact information.
4 sd A Body web.JPG (650 downloads)
(SLANT 6) 7 BLADE HIGH CAPACITY 18" FAN [Re: eenloe] #3065728
08/06/22 11:23 AM
08/06/22 11:23 AM
BRIDGEWATER, CT.
WINGNUT Offline
WINGNUT  Offline
BRIDGEWATER, CT.
Good used 18" 7 blade high capacity fan. Fits 67-72 slant 6 engines. $50 plus shipping. No Paypal. U.S money order only. VEIGHTPETE@GMAIL.COM
Re: A Body - Parts For Sale - 3rd Quarter [Re: moparts] #3065783
08/06/22 02:26 PM
08/06/22 02:26 PM
Arizona
sixpakjoe Offline
sixpakjoe  Offline
Arizona
Mopar Oil Filter Adapter
90 degree type. Fits 273, 318, 340 and 360 engines. Will work with A, B, C and E Body cars. Original part in excellent condition. $40 - Pickup preferred, as shipping would be too expensive. Contact Joe at sixpakjoe.net.
20220806_104502 (1).jpg (599 downloads)
71 Dart taillight lenses [Re: bfly] #3065805
08/06/22 03:16 PM
08/06/22 03:16 PM
Sacramento, CA
cal_gecko Offline
cal_gecko  Offline
Sacramento, CA
Used, driver quality - set of 4. $250 obo, shipped in the US
I'm in CA (zip 95835)
IMG_0907 2.jpeg (595 downloads)
fuel sending unit for 1971 Dart [Re: cal_gecko] #3065812
08/06/22 03:39 PM
08/06/22 03:39 PM
Sacramento, CA
cal_gecko Offline
cal_gecko  Offline
Sacramento, CA
fuel sending unit for 1971 Dart Swinger with 360, new, never used - has fuel return line (which you can cap/plug if you don't need to use it). $60 obo
IMG_0895 2.jpg (592 downloads)
IMG_0897 2.jpg (591 downloads)
IMG_0898 2.jpg (590 downloads)
1968 Barracuda Trunk lid Trim moldings $75 [Re: moparts] #3066915
08/10/22 08:28 PM
08/10/22 08:28 PM
NH USA
littleredcoffin Offline
NH USA
Both are in good condition..They have minor imperfections. These will be good for a nice driver. Aluminum is not milky .$75pr.Calls only 603 209 1678
convertible top power motor. [Re: moparts] #3066918
08/10/22 08:32 PM
08/10/22 08:32 PM
NH USA
NH USA
Works perfectly..Ground wire has a chaffe in it,but it works perfectly.$35.Calls only 603 209 1678
67-69 Convertible rear window regulators [Re: moparts] #3066922
08/10/22 08:36 PM
08/10/22 08:36 PM
NH USA
NH USA
These came out of a `67 Barracuda convertible.Both work great!! $40pr.Calls only 603 209 1678
68 Barracuda formula S rocker moldings [Re: moparts] #3067244
08/12/22 06:16 AM
08/12/22 06:16 AM
NH USA
NH USA
68 Formula S trim.These attach to the very back of the rocker .These are Cast Aluminum. Very minor pitting. Chrome is good for the age.1 year only piece.$50pr...Calls only 603 209 1678
1967-68 inside plastic door vents [Re: moparts] #3067929
08/14/22 05:36 PM
08/14/22 05:36 PM
NH USA
NH USA
Complete with no broken studs and has the 4 nuts.Plastic is all intact.These are nice pieces.Matched pair from the same car.$35pr.Calls only 603 209 1678.Us Postal money order only
Drivers side black convertible armrest [Re: moparts] #3067930
08/14/22 05:38 PM
08/14/22 05:38 PM
NH USA
NH USA
Not slpit,,some pitting on backside but tabs work great to secure it to the interior panel $15.Calls only 603 209 1678.
Black interior kick panels [Re: moparts] #3067931
08/14/22 05:40 PM
08/14/22 05:40 PM
NH USA
NH USA
Matched pair.No cracks.These are originally black.Not chaulky $25pr.Calls only 603 209 1678
Black pillar post plastics [Re: moparts] #3067933
08/14/22 05:43 PM
08/14/22 05:43 PM
NH USA
NH USA
Matched pair of black A pillar plastics,Tabs are intact.No pull thru screws.$40pr.Calls only 603 209 1678
Gold A pillar post plastics [Re: moparts] #3067934
08/14/22 05:45 PM
08/14/22 05:45 PM
NH USA
NH USA
Tabs are missing,and 1 screw hole has 75% of the smaller hole size missing.These will still work,Tabs missing never gets seen and screw hole can be repaired easily $20pr.Calls only 603 209 1678
Filler tube with vent line [Re: moparts] #3067936
08/14/22 05:49 PM
08/14/22 05:49 PM
NH USA
NH USA
This is a very clean pice.Inside galvansizing is great.Vent line is not bent.Even rubber hose and clamp are good! $35.Calls only 603 209 1678
67-70 door window regulators [Re: moparts] #3067938
08/14/22 05:51 PM
08/14/22 05:51 PM
NH USA
NH USA
For 2 door model.Work fine.Teeth are good.Window cranks are not stripped. $20pr.Calls only 603 209 1678 .Parting 2 67 Barracuda`s.What do you need?
filler neck retainer screws [Re: moparts] #3067939
08/14/22 05:53 PM
08/14/22 05:53 PM
NH USA
NH USA
These are speacial screws that hold the filler neck to the quarter panel.These are difficult to find $6 for the 3.Calls only 603 209 1678
Small block A body oil filter adapter [Re: moparts] #3067941
08/14/22 05:55 PM
08/14/22 05:55 PM
NH USA
NH USA
Correct cast iron,with correct bolt and the metal washer came off a 1967 273 $20.Calls only 603 209 1678
67-69 Barracuda hood latch support with release lever [Re: moparts] #3067945
08/14/22 05:58 PM
08/14/22 05:58 PM
NH USA
NH USA
Levers moves.Latch plate is straight.Came off a 67 Barracuda I am parting out.Has your car been hit in the front end?? If so you will be looking for this. $20.Calls only 603 209 1678
