Page 12 of 13 1 2 10 11 12 13
15% OFF EVERYTHING [Re: moparts] #3065595
08/05/22 08:09 PM
08/05/22 08:09 PM
MA
ragtop Offline
ragtop  Offline
MA
TAKE 15% OFF ALL PRICES. NOT SHIPPING ANYTHING FOR ANY PRICE. Cash Pick Up Only. Located in Billerica MA. All parts from a 1970 Challenger. See my other parts in the Transmission section and Small block engine section.
1970-71 Space Saver collapsible spare K2, date code is 0 11 4 1700
Passenger side Front Frame Rail includes shock tower, inner fender and torque box 400
Driver side Front Frame Rail includes Shock tower and torque Box 350
Left Rear frame rail: includes torque box 300
Right rear Frame Rail: Includes torque Box 300
Fender: passenger 200
V8 K Frame: with shock towers, inner bumper brackets and front frame rail portion 325
Front bumper 125
Rear bumper 125
Transmission crossmember 90
Driver’s side inner fender cover plate 25
Rear wheel lip moldings 25 each
Front windshield molding 5 pc. Set 275
Rear bumper filler panel 40
Front vertical radiator support rusty 10
Lower radiator support brace 30
Headlight rings 7 each
Front license plate bracket 25
Rear valance panel brackets 40 pair
Rear bumper guard brackets 10 each
Space saver spare tire hold down bolt & wing nut for Cuda hardtop 25
Lug wrench 20
Trunk lock, latch, cylinder, & key 35
Front parking lamps 55 each
Side marker lamp assembly 45 each
License plate lamp 30
‘Cuda drip rail corners or caps 45 set
Body hole plugs & gromets almost complete set 25
Fuel tank sending unit filter 8
Wiper linkage under cowl: 2 spd 65
Wiper linkage under cowl: 3 spd 65
Wiper arms 75 pair
Hood hinge with spring: passenger side 45
Hood springs 10 each
Ignition switch: works 2947487 75
Brake light switch: works 10
Brake light switch mounting bracket 2947543 30
Headlight switch: works 1971 2997305 65
Dome light dimmer switch: needs rebuild 2947713 15
Variable speed wiper switch: needs rebuild 2770380 30
High beam switch: works 10
Horn relay 2926327 works 25
Key-in buzzer works 2983696 45
Radio suppressor for coil 2884869 25
Radio suppressor for voltage limiter 2884868 25
Dome light: no plastic cover: works 30
Ash tray light: works 55
Map light ground strap 10
Batter hold down for group 24 battery 10
Windshield washer motor filter 15
Starter relay shield 7
Front lighting wiring harness 40
Neutral safety switch wiring harness 20
Horn: works 20
Rallye dash fuel gauge: works 55
Rallye dash oil gauge: works 55
Rallye dash temperature gauge: works 5
Brake booster mounting plate 10
Brake booster wiring harness bracket 15
Master cylinder: disc brake, new aftermarket 60
Master cylinder: drum brake, needs rebuild 10
Disk brake pads: (2) new, (2) slightly used 20 set
7/8 rear wheel cylinders: new aftermarket (smaller that stock) 20 each
Disk caliper hoses: new aftermarket 25 pair
Disc caliper dust shields 30 pair
Disc caliper adapters 115 pair
Disc brake spindle: passenger side 55
Disc brake master cylinder pushrod & bolt 40
Parking brake cable: left rear, new inline tube #RE552 25
Passenger window regulator & parts 35
Inside door lock leavers 10 each
Inside door handles 5 each
Arm rest: black, new repro 45
Arm rest pull cup 15
Original quarter window bee stickers 20 pair
Door hinges: may need rebuild, upper or lower 10 each
Window crank handle 10
Quarter window vertical felts: new repro 30 pair
Door weatherstrip set: 4 pc new repro 65 set
Side & quarter window wiper style seals:
Inner & outer 8 pc set: most pcs are new repro 65 set
Passenger Qtr panel jam rubber coated seal for leading edge of Qtr window 5
Axles (2) (8 ¾) 125 each
T/A rear sway bar & brackets, no end link brackets 200
Centerlink Draglink 85
Upper control arms (3) 45 each
Idle arms (2) 30 each
Pitmal arm (power steering) (not Fast Ratio) 75
Tie rod sleeve 15
Strut rod bushings: new 3 of 4 20
Pinion Snubber bracket 35
Upper control arm eccentrics 30 pair
Leaf spring U bolts (4) 40 set
Lower control arm bumper 15
Strut rods 75 pair
Kick panels: black 35 each
1971 steering column: complete, black, PS, floor shift 225
1971 inside mirror day/night 35
Bucket seat tracks & hardware 100 pair
Front dash center speaker: new, aftermarket 20
Ignition cylinder & key 10
Ignition cylinder & key with collar 40
Column lock star wheel 10
Rallye dash speedometer (1970-71 style) 200
Parking brake pedal dress up 7
Original Challenger Trunk Floor [Re: ragtop] #3065712
08/06/22 10:14 AM
08/06/22 10:14 AM
MD
floyd Offline
floyd  Offline
MD
Original trunk floor out of a 71 Challenger. The car was rolled within a few months of being new. The collision shop that repaired the car back in 1971 cut out the damaged section and sectioned in a piece from an NOS floor pan. It looks like hell, but there is some nice patch panel potential here. The car had very low miles and there is only light surface rust. Pick up in the Washington DC area or free delivery to the Nats.
$125
SALE PENDING
Thanks for the ad!
Re: E Body - Parts For Sale - 3rd Quarter [Re: TWS] #3065787
08/06/22 02:32 PM
08/06/22 02:32 PM
Arizona
sixpakjoe Offline
sixpakjoe  Offline
Arizona
Mopar Oil Filter Adapter
90 degree type. Fits 273, 318, 340 and 360 engines. Will work with A, B, C and E Body cars. Original part in excellent condition. $40 - Pickup preferred, as shipping would be too expensive. Contact Joe at sixpakjoe@cox.net.
20220806_104502 (1).jpg (337 downloads)
Re: E Body - Parts For Sale - 3rd Quarter [Re: moparts] #3065861
08/06/22 06:56 PM
08/06/22 06:56 PM
Cleveland, OH
TWS Offline
TWS  Offline
Cleveland, OH
Updated List, with new items:
426 Hemi Parts
Set of 2780518 .020" Oversize Hemi Pistons, Never Run, $250 / set **NEW**
Nylon Windage Tray w/ Gaskets, NOS, $60 **NEW**
Orig Hemi Balancer, a lot of holes drilled, $100 **NEW**
NOS 70-71 B&E 1/2" Oil Pickup, $130 **NEW**
Cuda Parts
Orig. 71-74 Cuda Rear Valance w/ Cutouts, chemically stripped. $300 **NEW**
Orig. Rocker Gill, Driver Side Only, $200 **NEW**
71 Chrome Headlight Bezels, repro, $300 / 4
71 Argent Headlight Bezels, orig, $300 / 4
Orig. Cuda quarter skin cutoff, $200
New repro 2-piece trunk floor, $100
Orig. 70 Cuda header panel, $250
Orig. 72-74 Cuda header panel, $150
71-74 Cuda fuel tank, used orig, $150
Door and Quarter Top Trim, $200 / set
Challenger Parts
71-74 Challenger Body Side Mouldings, excellent, $950 / set of 6 **NEW**
1970-only Tail Trim, restored original set (decklid and 2 quarter trims), $800 / set **NEW**
T/A Rear Spoiler, Repro, $300 **NEW**
T/A Exhaust Tips, Orig, $450 / pair **NEW**
Challenger Wide Rocker Mouldings, Orig., $300 / pair **NEW**
SE Rear Window Plug Assembly, Complete, $500
70-74 Challenger NOS Exhaust Tips. $700 pair
70 Challenger 3-Speaker Dash Pad, excellent, $900
71 Challenger Indy Pace Car Wheels, $1,600 / 4
71 Front Wide Fender Chrome, NOS, $700 / pair
70-74 Challenger new passenger door skin, repro, $140
72-74 Challenger used tailpanel, $200
72-74 Challenger used taillights, $100 / pair
E-Body Parts
3400024-34 E-Body 70-71 440-6 / Hemi Leaf Springs, Orig. chemically stripped, $800 / pair **NEW**
3400043-43 E-Body 70 340 / 383 Leaf Springs, Orig, $300 / pair **NEW**
2951865 Driver Side Exhaust Manifold. Orig, 70-71 E-Body 383 / 440 HP, $275 **NEW**
1971 340 Intake Manifold, $150 **NEW**
Lower Control Arms, with Sway Bar Brackets, chemically stripped, $600 / pair **NEW**
14" trim rings, P/N 2944424. Restored by Rick Miller, $700 / 4
NOS Sway Bar Brackets for Front Lower Control Arms (only set I've ever seen), $180 / pair
NOS 7290 U-Joints, Detroit #2781937, $300 each
71 340 4-Barrel Shaker Baseplate, orig, $950
NOS Shaker Seal, $300
Used Orig Shaker Seal, $75
Repro Shaker Adapter Ring, $500
Repro Cold & Warm Air Doors, $300 / pair
Repro Metal Shaker Grilles, $400 / pair
Hemi Oval Air Cleaner Lid, orig, $200
71-72 440, 440-6 and Hemi Fuel Vapor Separator, 3577867 NOS, $350
Federal Power Steering Pump Cooler, $450
70-71 Orig 2-Piece Rotors, $700 / pair
Original 10" drums, $300 / pair
72-74 Rally Dash Woodgrain Trim, Actual Wood Veneer, $250
AMD 70-74 E-Body Passenger Outer Cowl Hinge Panel, 376-1570-1R, $200
E-Body Front Bench Seat, $500
70-74 Ash Tray Assembly, restored, $60
Convertible Top Pump / Cylinders Set-up, $400
Original Convertible Clear Door Glass, Passenger Side, Likely Repairable Edge Chip. $300
Used E-Body Luggage Rack, Restorable Core. $300
NOS Ralley Dash Gauges (fuel, amp, oil), $650 / 3
NOS Ralley Gauge Clock, $350
DCS Repro Resonators, $100 / pair
DCS Repro Muffler, $80
Convertible Top Switch, clone “423” switch, $150
Misc Original Glass, windshield, rear, door, quarter, inquire
Free delivery to the Mopar Nats if paid in advance.
All prices are plus shipping. Offers accepted, discounts for multiple purchases.
TWSchuler@aol.com
1970 Challenger taillight lenses $40 [Re: moparts] #3065880
08/06/22 08:10 PM
08/06/22 08:10 PM
NH USA
littleredcoffin Offline
NH USA
Both are in descent shape.Not chipped.Minor small stress cracks.Polish and install..Coloring is good.$40.Calls only 603 209 1678
70 slapstick assembly with selector rod [Re: moparts] #3065882
08/06/22 08:16 PM
08/06/22 08:16 PM
NH USA
NH USA
Descent shape,missing black button.Black plastic sheath is not broken.$25.Calls only 603 209 1678
70 non rally dash heater control panel bezel [Re: moparts] #3065883
08/06/22 08:19 PM
08/06/22 08:19 PM
NH USA
NH USA
Missing blower switch and has plastic partially missing for hold down tab $10.Calls only 603 209 1678
70-71 Challenger lower front parking light assemblies [Re: moparts] #3065888
08/06/22 08:27 PM
08/06/22 08:27 PM
NH USA
NH USA
Both have descent lenses and Castings are in descent shape also.$20pr.Calls only 603 209 1678.I sell for less every day
1970 hood hinges [Re: moparts] #3065891
08/06/22 08:29 PM
08/06/22 08:29 PM
NH USA
NH USA
In clean condition.Teeth are not worn.Great cores $30pr.Calls only 603 209 1678
Rim blow steering wheel $50 [Re: moparts] #3065892
08/06/22 08:30 PM
08/06/22 08:30 PM
NH USA
NH USA
Needs restoration.What you is ,is what you get $50.Calls only 603 209 1678
70-71 rally steering wheel [Re: moparts] #3065894
08/06/22 08:32 PM
08/06/22 08:32 PM
NH USA
NH USA
Very minor crcking on the bck side.Pads are in good shape.Easy restoration on this one.$60.Calls only 603 209 1678
Wiper arms [Re: moparts] #3065896
08/06/22 08:33 PM
08/06/22 08:33 PM
NH USA
NH USA
Matched pair iwth the hard to find pivot clip intact $25pr.Calls only 603 209 1678
Interior rearview mirror [Re: moparts] #3065897
08/06/22 08:35 PM
08/06/22 08:35 PM
NH USA
NH USA
Stem has minor pits.Lense is above average.Works fine $10.Calls only 603 209 1678
Control panel switches [Re: moparts] #3065899
08/06/22 08:38 PM
08/06/22 08:38 PM
NH USA
NH USA
Head light switch $7,instrument dimmer switch $7and 2 speed wiper switch $8 or all 3 $20.Calls only 603 209 1678
Re: E Body - Parts For Sale - 3rd Quarter [Re: moparts] #3065902
08/06/22 08:41 PM
08/06/22 08:41 PM
oak park, il.
dsd70bee Offline
dsd70bee  Offline
oak park, il.
1971 426 HEMI front carb, excellent used condition $2500.00 (708) 288-2879
parts 8-06-2022 038.JPG (315 downloads)
parts 8-06-2022 040.JPG (315 downloads)
parts 8-06-2022 046.JPG (315 downloads)
parts 8-06-2022 051.JPG (315 downloads)
Front windshield lower corner stainless [Re: moparts] #3066327
08/08/22 07:46 PM
08/08/22 07:46 PM
NH USA
NH USA
Matched pair.Some scuffing,Easily can Use as is.$18pr.Calls only 603 209 1678
1970 challenger rear window stainless pieces [Re: moparts] #3066329
08/08/22 07:49 PM
08/08/22 07:49 PM
NH USA
NH USA
Matched pair of the lower pieces.A few minor imerfections.Totally usable as is and these have the special retaining clips found on 1970.$30pr.Calls only 603 209 1678
1970-71 Challenger rear bumper brackets [Re: moparts] #3066330
08/08/22 07:51 PM
08/08/22 07:51 PM
NH USA
NH USA
Have some heavy pitting.Still totally usable.$15pr.Calls only 603 209 1678
1970 challenger vertical hood latch support [Re: moparts] #3066333
08/08/22 07:58 PM
08/08/22 07:58 PM
NH USA
NH USA
Straight, clean item.Not bent $15.Calls only 603 209 1678
Passengers side bucket seat tracks [Re: moparts] #3066338
08/08/22 08:00 PM
08/08/22 08:00 PM
NH USA
NH USA
Both work fine.Not rusty or scabby.Only have the passengers side $60pr.Calls only 603 209 1678
