Page 3 of 3 1 2 3
Re: 1965 273 RH Exhaust Manifold Gaskets [Re: floyd] #3062102
07/24/22 02:37 PM
07/24/22 02:37 PM
IL
furious70 Offline
furious70  Offline
IL
Complete 81-83 imperial electronic fuel injection
At least I'm guessing it's complete
2 brains and 2 pressure nozzles? MAF sensor.
Distributor
Don't know functionality but the guy did have one of these cars.
someone still running one need an 'insurance policy'?
$100 obo + shipping or make me an offer
70 Sport Fury
68 Charger
69 Coronet
72 RR
$40 OBO - Proform 650-800cfm Baseplate [Re: dragracer1] #3062754
07/26/22 01:59 PM
07/26/22 01:59 PM
Indiana
dragracer1 Offline
dragracer1  Offline
Indiana
New Proform 650-800cfm cast baseplate. P/N 67268. I bought it, tried it, but didn't fix my issue. Less than 30min of garage run time.
The linkage has been trimmed up so my cable mount would work. Which is why I couldnt just send it back. Other than that, its perfect.
Summit: $114.99
Mine: $40.00 OBO + Shipping from So. Indiana
PM me if interested.
1962 318 4 bbl powerpack tune up kit with vacuum adv [Re: ragtop] #3064697
08/02/22 04:16 PM
08/02/22 04:16 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
1962 POWER PACK 318 4 BBL FOR #2095981 DISTRIBUTOR
TUNE UP KIT
BLUE STREAK HP COPPER INSERT, HD BAKELITE DISTRIBUTOR CAP, AUTOLITE ROTOR, AUTOLITE CONDENSER, USA MADE POINTS, 2444911 NOS VACUUM ADVANCE WITH #, 6.5x,DPCD ON IT, 1 CORRECT DISTRIBUTOR LEAD.
1962 Plymouth Belvedere, Savoy, Fury, Custom, Suburban and Sport Wagon
1962 Dodge Dart, Dart Pioneer, Dart Phoenix, Dart Seneca, Dart 330 and Dart 440
$ 100 MAILED
cowgerwilliam035@gmail.com
62powerpack 001.JPG (385 downloads)
62powerpack 003.JPG (387 downloads)
62powerpack 004.JPG (385 downloads)
62powerpack 010.JPG (385 downloads)
90 degree oil filter adapters [Re: ragtop] #3064819
08/03/22 07:57 AM
08/03/22 07:57 AM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
I have 2 90 degree oil filter adapters. Both are used. I personally have not used either one. They have been on a shelf in my dads garage for years. Prices does not include shipping. Feel free to make offers as well.
orange cast # 2951995 - $100
aluminum # 4179425 - $130
Re: For Sale - Small Block Engine - 3rd Quarter [Re: moparts] #3065221
08/04/22 03:42 PM
08/04/22 03:42 PM
Cannelton, IN
mike337 Offline
mike337  Offline
Cannelton, IN
Kick down, return spring, and distributor retention brackets $25 Can be reached at moparzone4@aol.com.
Thanks for the ad Moparts!
Re: For Sale - Small Block Engine - 3rd Quarter [Re: moparts] #3065222
08/04/22 03:42 PM
08/04/22 03:42 PM
Cannelton, IN
mike337 Offline
mike337  Offline
Cannelton, IN
Kick down linkage bracket, with throttle cable bracket and kick down linkage pivot. $30 Can be reached at moparzone4@aol.com.
Re: For Sale - Small Block Engine - 3rd Quarter [Re: moparts] #3065225
08/04/22 03:45 PM
08/04/22 03:45 PM
Cannelton, IN
mike337 Offline
mike337  Offline
Cannelton, IN
Misc Alternator Brackets $50 Will separate out brackets. Can be reached at moparzone4@aol.com.
Misc Brackets.jpg (262 downloads)
Re: For Sale - Small Block Engine - 3rd Quarter [Re: moparts] #3065484
08/05/22 01:43 PM
08/05/22 01:43 PM
cali
68mannix Offline
68mannix  Offline
cali
1971 340 duel point distributor 4018C for a b and e 4spd cars probably 3 spd manuel as well clean core needs rebuilding look at pictures 125.00 located in lake isabella ca 93240 can ship in cont. usa for 16.50 SOLD
15% OFF EVERYTHING [Re: moparts] #3065594
08/05/22 08:06 PM
08/05/22 08:06 PM
MA
ragtop Offline
ragtop  Offline
MA
TAKE 15% OFF ALL PRICES. NOT SHIPPING ANYTHING FOR ANY PRICE. Cash Pick Up Only. Located in Billerica MA. See my other parts in the E-body section and Transmission section.
1970 T/A 340 block: std bore, hot tanked, .005 max cylinder ware, includes caps & bolts, OB 305926 Can provide some inspection measuring tools. 6000
1970 T/A 340 heads: complete, re-built, bowls cleaned up, push rod pinch area machined away, Rockers bored +.010 to match new + .010 oversize shaft, includes valves, retainers, seals, locks, & springs Valve springs removed for inspection. 4000 pair
1970 T/A 340 pushrods: new sealed power RP1359 150
1971 340 Long Block: 030 over, very low mileage. 10 to 1 forged pistons, new cam bearings and oil pump, comes with oil pick up, windage tray, oil pan, oil slinger, fuel pump eccentric, front cam plate, date coded timing chain cover, Flex Plate, engine cradle, & date coded heads which are re-built. Heads come with rockers and shaft, retainers, valves, locks & valve seals. (no valve springs) Heads and Oil Pan removed for inspection. 5000
1968 273 block: needs rebuild, std bore 200
1968 273 pistons & rods assembly, std diameter, no measurable ware 150 set
Small block cast crankshaft 50
340 forged crankshaft 100
340 294 oil pan 130
340 right hand oil filter adaptor complete 55
340 right hand oil filter adapter missing bolt 45
1970 & up small block timing chain cover 15
Small block straight oil filter adaptor & bolt 20
Small block oil pump & pick up tube 25
Small block F E oil filler cap 20
Small block rubber motor mounts, new aftermarket 35 pair
Thermostat housing small block 15
Small block harmonic balancer: forged crank 65
Small block crank pulley: 2 groove, non AC asymmetric hole pattern 60
Small block water pump pulley: non AC 25
318 valve covers 20 pair
Small block alternator bracket set & spacers, non AC 40
Small block power steering pump bracket set: federal style with spacers 75
Small block coil bracket 20
Small block distributer hold down bracket 10
Power steering pump reservoir: federal style 30
NOS Fram CA332 Six Pack air filter 125
Edelbrock SP2P 318 Intake Manifold, has weld repair on bottom. 75
Carter Thermoquad for 1972 340 automatic, #6139 SA 300
VERY CLEAN Edelbrock performer intake $115 [Re: moparts] #3065905
08/06/22 08:45 PM
08/06/22 08:45 PM
NH USA
littleredcoffin Offline
NH USA
Looks almost new.Really clean.Never ported.$115.Again,this is very clean.You will not find a lower price ANYWHERE!! Calls only 603 209 1678
Page 3 of 3 1 2 3
