69 11 in. Big Block Bell Housing #2892628
[Re: Memongo]
#3058761
07/13/22 03:03 AM
07/13/22 03:03 AM
Posts: 2,849 Fenton, MI
Memongo
Parts peddler
Parts peddler
Fenton, MI
69 11 in. Big Block Bell Housing #2892628. Used, $300 + Shipping. Payment via US Postal Money Order Only! Pick Up Fenton Michigan. Shipping: US Address Only! Call Steve 810-629-1097
rebuilt 904 (non-lockup)
[Re: Jstern]
#3060197
07/18/22 12:24 PM
07/18/22 12:24 PM
Posts: 2,083 oberlin, Ohio
Rapid340
oberlin, Ohio
Fully rebuilt 904 (non lockup)
Setup for street/strip with HD parts including
2.74 low gear set new billet 4.3 lever new clutch/steels/seals reverse wound direct drum spring new turbo action cheetah RM valve body new finned deep aluminum pan with high flow filter (and extension) babbit front bushing
$1675 (no core required)
could be delivered to mopar nationals in Columbus OH with deposit
thanks
Rapid340@yahoo.com
1971 Factory Appearing Duster 340 11.000 @ 122 mph
18 Spline 4 speeds A body & B Body
[Re: dsd70bee]
#3065515
08/05/22 03:32 PM
08/05/22 03:32 PM
Posts: 225 Southwest Missouri
eenloe
Southwest Missouri
1) I have an almost complete 4 speed conversion set up an A body. Rebuilt 18 Spline A833 transmission. New big block bell housing, inspection cover, ball stud hardware, New McCleod Clutch, Pressure Plate, Flywheel, Throw out Bearing, New Torque shaft and clutch rods all from Brewer's, New Hurst Shifter, Comes with shifter rods, really nice A body Hurst shift lever, Vintage white shifter knob, shift fork, high torque mini starter, floor boot and bezel, firewall and bellhousing boots. If you add all this up new from Brewer's it comes out to almost $6000.00. Sacrificing the whole package for $4,800.
2) I also have an almost complete 4 speed conversion set up for a B body. It has less than 200 miles on it. Previous owner changed mind on drive train and is going to Gen 3 hemi and auto. Rebuilt 18 Spline A833 transmission. Correct # big block bell housing, inspection cover, ball stud hardware, New McCleod Clutch, Pressure Plate, Flywheel, Throw out Bearing. Torque shaft and clutch rods New Hurst Shifter, Comes with shifter rods, Choice of Hurst shifter and knob, shift fork, high torque mini starter, floor boot and bezel, bellhousing boots. If you add all this up new from Brewer's it comes out to almost $5,600.00. Sacrificing the whole package for $4,200.
See photos for contact information.
15% OFF EVERYTHING
[Re: moparts]
#3065591
08/05/22 08:02 PM
08/05/22 08:02 PM
Posts: 1,540 MA
ragtop
MA
TAKE 15% OFF ALL PRICES. NOT SHIPPING ANYTHING FOR ANY PRICE. Cash Pick Up Only. Located in Billerica MA. See my other parts in the E-body section and Small block engine section.
E-body T/A style 4 speed: rebuilt with no miles, Has 1968 case, long E-body tail housing, close ratio 2.47 gear set, 23 spline 1500 Slip yoke 60 Speedometer gear housing 30 4 speed front bearing retainer: 3410395, 23 spline small bearing 55 Clutch fork 40 Clutch fork boot: new 25 Clutch fork rod: new 25 4 speed tail shift bushing: new 10 4 speed brass stop rings good used 25 set of (5) 3rd-4th syncromesh assembly 140 1st-2nd 1971 style steel shift fork: new 55 Speedometer gears: 29 tooth & 40 tooth 15 each 904 automatic transmission 100 904 automatic transmission: torque converter 50 904 automatic transmission: torque converter shield 10 904 automatic transmission: torque converter dip stick 10 Automatic transmission Flex Plate 35
fresh 904 transmission
[Re: ragtop]
#3065841
08/06/22 05:40 PM
08/06/22 05:40 PM
Rapid340
oberlin, Ohio
A904 (non lockup)
2.74 low gear set billet 4.2 lever reverse wound direct drum spring turbo action cheetah RM valve body finned deep aluminum pan with high flow filter (and extension) babbit front bushing built by Chris Botson
$1575
can be delivered to mopar nationals in Columbus OH with deposit (will be there Saturday)
thanks
Rapid340@yahoo.com
shifter linkages rods balls
[Re: Memongo]
#3066197
08/08/22 11:11 AM
08/08/22 11:11 AM
Posts: 1,577 Keymar, MD
DusterKid
Keymar, MD
shifter linkages rods etc. I’m not sure what anything fits as everything has been in my dads garage for years and he’s had a, b, e and f bodies. Asking $300 plus shipping for everything obo.
