Help with part# for B body rubber firewall hole plug #3064804
08/03/22 12:20 AM
08/03/22 12:20 AM
Warren, MI
71TA Offline OP
71TA  Offline OP
Warren, MI
I "think" the part# is 2571069 but the numbers on the one original part I had were very worn.
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: Help with part# for B body rubber firewall hole plug [Re: 71TA] #3065046
08/03/22 11:24 PM
08/03/22 11:24 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I use to have one of those No idea if I still have it or not
best I remember its 71 and up ????
Re: Help with part# for B body rubber firewall hole plug [Re: gtx6970] #3065400
08/05/22 08:57 AM
08/05/22 08:57 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
What years does this plug fit?
"Only the best and brightest"
Re: Help with part# for B body rubber firewall hole plug [Re: gtx6970] #3065401
08/05/22 08:58 AM
08/05/22 08:58 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
What years does that fit?
Re: Help with part# for B body rubber firewall hole plug [Re: 6PakBee] #3065457
08/05/22 12:21 PM
08/05/22 12:21 PM
Rio Linda, CA
John_Kunkel Offline
Much ado about nothing
John_Kunkel  Offline
Rio Linda, CA
The number suggests it was first produced for '64 models but might still be used many years after that.
Doing my best to irritate the herd.
Re: Help with part# for B body rubber firewall hole plug [Re: John_Kunkel] #3065531
08/05/22 04:55 PM
08/05/22 04:55 PM
Warren, MI
71TA Offline OP
71TA  Offline OP
Warren, MI
Heres a discussion on Dodge Charger about these plugs. I THOUGHT they were used to fill the non AC heater box stud holes when an AC heater box was used.
http://www.dodgecharger.com/forum/index.php?topic=110012.0
Re: Help with part# for B body rubber firewall hole plug [Re: 71TA] #3065691
08/06/22 07:14 AM
08/06/22 07:14 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
That’s what they are for. I’ve got a couple of ac b bodies at the shop. I’ll see what I can did up for you this morning at the shop.
Re: Help with part# for B body rubber firewall hole plug [Re: fastmark] #3066558
08/09/22 02:25 PM
08/09/22 02:25 PM
Warren, MI
71TA Offline OP
71TA  Offline OP
Warren, MI
Thanks Mark
