69 Charger with a 2014 392 #3065518
08/05/22 03:44 PM
08/05/22 03:44 PM
TX/GA/WI
Bob Stinson Offline OP
TX/GA/WI
https://www.hemmings.com/auction/1969-dodge-charger-834453
This car had a lot going for it, but the interior takes it all away
ETA: ooops
69 road runner A12 ex-racer
71 Duster w/ a 400
Re: 69 Charger with a 2014 392 [Re: Bob Stinson] #3065520
08/05/22 03:53 PM
08/05/22 03:53 PM
O
oldjonny Offline
Don't argue with me.
oldjonny  Offline
O
Flex exhaust??? I did not think anyone used that garbage anymore. I worked at an auto parts store in the late 70's and we only sold that as a cheap fix for desperate people that were looking for short term fixes prior to flips...Seriously, someone would put that junk on?
Never, ever argue with an IDIOT. They will drag you to their level and then beat you with their years of experience
Re: 69 Charger with a 2014 392 [Re: oldjonny] #3065521
08/05/22 03:59 PM
08/05/22 03:59 PM
Puttin' on the foil in Charles...
not_a_charger Online mad
Mr. Big Shot Moparts Moderator
not_a_charger  Online Mad
Lotta quotation marks in that ad. laugh2
Earning every penny of that moderator paycheck.
DBAP
Re: 69 Charger with a 2014 392 [Re: oldjonny] #3065523
08/05/22 04:05 PM
08/05/22 04:05 PM
TX/GA/WI
TX/GA/WI
I'm going to use it as a short term connection between Schumacher headers and the exhaust built for long tubes that is on the car now. Just long enough to get the car moved to a different storage spot. I'm also going to try to use it to figure out what I need bent to make the final connection.
But permanent? Not now, not ever, even when I was a broke kid pumping gas in the 70s.
71 Duster w/ a 400
Re: 69 Charger with a 2014 392 [Re: Bob Stinson] #3065541
08/05/22 05:46 PM
08/05/22 05:46 PM
USA
V
VS29H0B Offline
VS29H0B  Offline
V
USA
Interior = If it wasn't for POOR taste ... some folks would have no taste at all ....
Exhaust - to use flex pipe shows a total lack of awareness and/or disregard for prospective buyers who will ask WHY?
Those things alone -- makes for --- a lot of question marks in the minds of prospective buyers.
Great job limiting your pool of prospective buyers ....
Like the women I have dated --- Always looking for a better deal ....
Re: 69 Charger with a 2014 392 [Re: Bob Stinson] #3065547
08/05/22 05:58 PM
08/05/22 05:58 PM
N
NITROUSN Offline
NITROUSN  Offline
N
That car is a mess everywhere you look. If it sells cheap enough it would be a good daily driver. A quality high end show piece NOT.
Re: 69 Charger with a 2014 392 [Re: NITROUSN] #3065561
08/05/22 06:39 PM
08/05/22 06:39 PM
Central Florida
larrymopar360 Offline
I'm tired...Very tired.
Central Florida
Agree! Interior awful, but I believe just a steering wheel swap would make huge difference. And yes, what a shock to see that exhaust!!!
Facts are stubborn things.
Re: 69 Charger with a 2014 392 [Re: larrymopar360] #3065630
08/05/22 09:30 PM
08/05/22 09:30 PM
Central Michigan
N
nuthinbutmopar Offline
N
Central Michigan
They took all the right pieces and ended up with a mess. Check out the remote oil filter: anybody who mounts one like that doesn't know what they're doing. The under-dash wiring makes me wish there was a Halon extinguisher handy...
Re: 69 Charger with a 2014 392 [Re: nuthinbutmopar] #3065697
08/06/22 08:52 AM
08/06/22 08:52 AM
TX/GA/WI
TX/GA/WI
It lubricates the parts under it with every oil change.
71 Duster w/ a 400
Re: 69 Charger with a 2014 392 [Re: Bob Stinson] #3066212
08/08/22 12:06 PM
08/08/22 12:06 PM
moparx Offline
moparx  Offline
the cheapo, bolt on battery terminals are hid with whatever that covering is.
those things are JUNK, and i cringe every time i see them ! down
beer
Re: 69 Charger with a 2014 392 [Re: moparx] #3066758
08/10/22 09:45 AM
08/10/22 09:45 AM
GA
roadrunninMark Offline
GA
Don't forget about the poor fitting dash components, the awful gauges and radio, and the clutch pedal that looks to be out of a Suburu! Does the shifter even fit without smacking the back side of the console when shifting?
