RacePak EGT's Q's
#3064836
08/03/22 09:17 AM
08/03/22 09:17 AM
Posts: 2,915 A shed in England
Tig
A shed in England
Hi. Just running the motor up (part throttle) after fitting a V300 and there's a variance of 200 degrees between hottest and coldest on the EGT's. IF this the case on full power runs, is it worth chasing the jetting to equalize them ? Anyone have any experience ? Did you pick up HP staggering the jetting ? How much does changing one jet effect its neighboring cylinders ? 580 wedge, heavily ported 572-13 heads, Indy T/R and 2x1150 T/R Dominators. A little bit more info: square jetted (98?) 1:1 throttle linkage. TIA.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
Re: RacePak EGT's Q's
[Re: Tig]
#3064848
08/03/22 10:13 AM
08/03/22 10:13 AM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
I wouldn't sweat it until you run it hard, the intake manifold isn't going to function right unless you are operating in its range.
I have read some people say that timing will influence EGTs more than mixture, but I don't have any experience there. Unless you are coil on plug per cylinder timing changes aren't easy anyways.
68 Barracuda Formula S 340
[Re: Bad340fish]
#3064852
08/03/22 10:22 AM
08/03/22 10:22 AM
Tig
A shed in England
Hmmm...Food for thought, I have a grid but no cam sync....I also only monitor O2, per bank, in each collector. In hind sight I maybe should have got 8 O2's Thanks Edit: I found out you just need this to individually time cylinders with a grid https://www.holley.com/products/ign..._grid_modules_and_accessories/parts/7555
[Re: Tig]
#3064880
08/03/22 11:28 AM
08/03/22 11:28 AM
Posts: 4,036 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
Hi. Just running the motor up (part throttle) after fitting a V300 and there's a variance of 200 degrees between hottest and coldest on the EGT's. IF this the case on full power runs, is it worth chasing the jetting to equalize them ? Anyone have any experience ? Did you pick up HP staggering the jetting ? How much does changing one jet effect its neighboring cylinders ? 580 wedge, heavily ported 572-13 heads, Indy T/R and 2x1150 T/R Dominators. A little bit more info: square jetted (98?) 1:1 throttle linkage. TIA. BEFORE the days of one O2 per pipe per cylinder. I used to dyno for a pro NASCAR team. YOU CAN tune an engine WELL with cylinder egt data. YES it is worth power and worth to understand HOW to adjust and WHY it needs it. Probably most intakes including 2x4 tunnel rams can respond to either modifications AND/or jetting changes. We used to balance all 8 egt's within around 10 degrees F and it ALWAYS was worth power. Based on my O2 data, which was bank to bank only, my right bank was about .5 point LEANER than the left on my INDY T/R with 2 4150's
[Re: HardcoreB]
#3064902
08/03/22 12:29 PM
08/03/22 12:29 PM
Posts: 19,356 Las Vegas
Al_Alguire
Las Vegas
You have two carbs, 8 jets so IMO yes its worth the effort as it will respond to changes more readily. Question is whats the target tat makes the most power. I personally don't use EGTs but prefer O2's.
[Re: HardcoreB]
#3064905
08/03/22 12:34 PM
08/03/22 12:34 PM
Tig
A shed in England
Hi. Just running the motor up (part throttle) after fitting a V300 and there's a variance of 200 degrees between hottest and coldest on the EGT's. IF this the case on full power runs, is it worth chasing the jetting to equalize them ? Anyone have any experience ? Did you pick up HP staggering the jetting ? How much does changing one jet effect its neighboring cylinders ? 580 wedge, heavily ported 572-13 heads, Indy T/R and 2x1150 T/R Dominators. A little bit more info: square jetted (98?) 1:1 throttle linkage. TIA. BEFORE the days of one O2 per pipe per cylinder. I used to dyno for a pro NASCAR team. YOU CAN tune an engine WELL with cylinder egt data. YES it is worth power and worth to understand HOW to adjust and WHY it needs it. Probably most intakes including 2x4 tunnel rams can respond to either modifications AND/or jetting changes. We used to balance all 8 egt's within around 10 degrees F and it ALWAYS was worth power. Based on my O2 data, which was bank to bank only, my right bank was about .5 point LEANER than the left on my INDY T/R with 2 4150's Screen shot: Difference is way more here at a fast idle. Note the O2 readings PS> Ignore Cylinder 8 as it wasn't connected properly, It went to a -ve reading later on when Investigating the wires weren't in the terminals correctly
[Re: Al_Alguire]
#3064909
08/03/22 12:46 PM
08/03/22 12:46 PM
Tig
A shed in England
You have two carbs, 8 jets so IMO yes its worth the effort as it will respond to changes more readily. Question is whats the target tat makes the most power. I personally don't use EGTs but prefer O2's. Good point, my plan was to read the plugs and go off the best cylinder(s) as a reference.
[Re: Tig]
#3064914
08/03/22 12:59 PM
08/03/22 12:59 PM
HardcoreB
Shelby Twp. Mi
You have two carbs, 8 jets so IMO yes its worth the effort as it will respond to changes more readily. Question is whats the target tat makes the most power. I personally don't use EGTs but prefer O2's. Good point, my plan was to read the plugs and go off the best cylinder(s) as a reference. Excellent! many things can guide you. I didn't speak to you noticing an 'issue' during part throttle and idle because distribution can be biased due to throttle blades IAB/carb tuning in general too. One thing i'll mention in addition is the INDY plenum IS SMALL. adding a spacer will help distribution as well.
[Re: HardcoreB]
#3064922
08/03/22 01:32 PM
08/03/22 01:32 PM
Tig
A shed in England
I plan to get a buddy to machine a 1" spacer for me (I was thinking of a phenolic one but the dust is an issue). Talking to Indy, they didn't see an improvement on a 572 (1/2" spacer) until over 7200 rpm. Pretty sure the 580 we have starts tailing off there anyway (Best shift seems to be around 6800). I do think it will help on the 655 though. I might just go ahead and try it my self in phenolic to see what occurs. I didn't want to, but also I think I'm gonna strip down the induction, give everything a clean and set it all up on the bench before it goes back on the engine just to eliminate any possible issues as it's been standing over a year. We're house hunting at the moment so racing is taking a bit of a back seat but we should out at the start of Sept for a day of testing, then 4 days of racing. Should get plenty of passes if the weathers good so plenty of data and tuning PS out of interest what was the issue you spotted ?
[Re: Tig]
#3064926
08/03/22 01:51 PM
08/03/22 01:51 PM
Al_Alguire
Las Vegas
There are also a couple versions of that Indy intake, one with a smallish plenum and one with almost no plenum and a peak in the "tent" protruding into it. The open version is clearly the better option and yes it will need a spacer...How much of one can vary but if it were me I would have a couple made up. We use high temp teflon stuff
As far as whats an ideal EGT I would pay way more attention to the timeslip than a plug. I have seen way to many people chase an ideal number in a racepak and ignore the timeslip, rather than giving the car what it wants/needs and then referring to the data for benchmarks. You woudl be surprised what you might find. But you have to start somewhere and reading a plug is a good start I suppose. But we run what many would consider an ugle plug to achieve the best ET's in the heads up car
[Re: Al_Alguire]
#3064927
08/03/22 01:56 PM
08/03/22 01:56 PM
Tig
A shed in England
There are also a couple versions of that Indy intake, one with a smallish plenum and one with almost no plenum and a peak in the "tent" protruding into it. The open version is clearly the better option and yes it will need a spacer...How much of one can vary but if it were me I would have a couple made up. We use high temp teflon stuff We've got the tent one......
[Re: Tig]
#3064929
08/03/22 02:01 PM
08/03/22 02:01 PM
Al_Alguire
Las Vegas
Ya know I might be getting the choices confused. I just sold one not long ago to a buddy in Canada and seem to recall it being open, but maybe that was the Predator version?!? I cant seem to find the pictures but for some reason I thought they had both depending on how old they were...I cant see the "tent" being any help, I suppose the thinking behind it was to help direct flow to the 4 cylinders on each end?!? Seems like a bad way in my mind to build a tunnel ram but maybe I'm wrong.
[Re: Al_Alguire]
#3064932
08/03/22 02:15 PM
08/03/22 02:15 PM
Tig
A shed in England
Ya know I might be getting the choices confused. I just sold one not long ago to a buddy in Canada and seem to recall it being open, but maybe that was the Predator version?!? I cant seem to find the pictures but for some reason I thought they had both depending on how old they were...I cant see the "tent" being any help, I suppose the thinking behind it was to help direct flow to the 4 cylinders on each end?!? Seems like a bad way in my mind to build a tunnel ram but maybe I'm wrong. There is definitely a more "open" version, pretty sure it's the earlier one. It has about double the amount of bolts fastening the top plate. I don't know why Indy redesigned it ? Indy had a picture of a 572 (or a 588) going out to a customer, I noticed the T/R it had was fitted with a 1" spacer and asked if it was worth anything. The reply was "yes, a small gain between 7200 and 7500 rpm"
[Re: Tig]
#3064935
08/03/22 02:21 PM
08/03/22 02:21 PM
Al_Alguire
Las Vegas
The one I sold which I am pretty sure was open was on a 655" deal we had tat i bought used. We freshened it up and made some big changes to since it is going in a bracket car we went with a single 4. I was pretty sure it was open but so many engines of our own around here and getting older aint helping. I thought/ assumed the tent version was the older one. The 655 we bought was not that old but who knows..I know I sold it to my buddy in Canada to replace hos tent version which he as had for long time, at least a 15 years I have known him. He crashed his car and intake got hurt when it was sliding on its roof and the old BG Demons got destroyed(thats how old this was). Sold him the tunnel ram and a pair of Book carbs I had for it so he could fix his 655.
[Re: Tig]
#3064936
08/03/22 02:22 PM
08/03/22 02:22 PM
Posts: 10,020 MN
JERICOGTX
MN
Have any pictures of the EGT's on the engine? What part # did you buy, from RacePak, for a Mopar?
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3064959
08/03/22 03:35 PM
08/03/22 03:35 PM
Tig
A shed in England
The one I sold which I am pretty sure was open was on a 655" deal we had tat i bought used. We freshened it up and made some big changes to since it is going in a bracket car we went with a single 4. I was pretty sure it was open but so many engines of our own around here and getting older aint helping. I thought/ assumed the tent version was the older one. The 655 we bought was not that old but who knows..I know I sold it to my buddy in Canada to replace hos tent version which he as had for long time, at least a 15 years I have known him. He crashed his car and intake got hurt when it was sliding on its roof and the old BG Demons got destroyed(thats how old this was). Sold him the tunnel ram and a pair of Book carbs I had for it so he could fix his 655. The pic of the Indy RB wedge T/R definitely is a tent version in their current on-line catalogue, but it may be an old picture ? There was a thread on here a while back where someone had modified a tent version to be an open one. I assumed the tent version was the older one also back then but I now have it in my head it's the newer one. Have any pictures of the EGT's on the engine? What part # did you buy, from RacePak, for a Mopar? Only this one below: They are Racepak ones though you can buy probes elsewhere (K Type) that are compatible. They are universal, come in BB Chevy or Hemi spacing and lengths from racepak but they fit a wedge OK with a little juggling. I was informed you can cut them to length but the ends are sealed with the glue type heat shrink sleeves so it could get a bit messy if you only need to remove an inch or so. You can just make out the probes at the bottom of the valve covers, they are about a 1 1/4" from the header flange, the amplifier is on the inner wing marked 2 4 6 8 HTH's
[Re: Tig]
#3065158
08/04/22 12:38 PM
08/04/22 12:38 PM
Al_Alguire
Las Vegas
Ya know I am not sure on the intake thing clearly I have had four or five of them over the years but never run one. Just stuff bought and sold over the years. I tend to spend to much time and money buying lots of parts. I prefer the O2 method but it is fair bit more expensive for sure than EGT's, not that either is "cheap" The fuel we use also seems easier to deal with using O2's than EGT's. Although if it gets to rich it can sometimes read lean on the sensor..Oh the joy of racecar tuning.
[Re: Al_Alguire]
#3065240
08/04/22 04:00 PM
08/04/22 04:00 PM
Posts: 4,563 Motor City
6PKRTSE
Motor City
I have all 8 Racepak EGT and both Racepak O2's on my car. Yes, it gets costly..... Zoom in. I have all engine mounted sensors on my snout bars.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#3065261
08/04/22 04:54 PM
08/04/22 04:54 PM
Tig
A shed in England
I prefer the O2 method but it is fair bit more expensive for sure than EGT's, not that either is "cheap" The fuel we use also seems easier to deal with using O2's than EGT's. Although if it gets to rich it can sometimes read lean on the sensor..Oh the joy of racecar tuning. I hear ya, all part of the fun, I've been watching you tube where they picked up 60 hp by staggering the jetting as below....but they were using O2 sensors rather than EGT sensors, there was a surprisingly big swing in the jetting !! (We got our tent T/R in 2014 BTW if that's any help ). https://www.youtube.com/watch?v=EP1Rh829rVk&t=1291sI have all 8 Racepak EGT and both Racepak O2's on my car. Yes, it gets costly..... Zoom in. I have all engine mounted sensors on my snout bars. Neat, I can see a row of V-net Tees but cant find the EGT amp boxes Snout bars are on the other side on the inner fender on mine We used a USM for our engine monitoring but I'm looking at more (as ya do )
