Re: What offset dials do I need? [Re: Clanton] #3064320
08/01/22 12:05 PM
08/01/22 12:05 PM
eastern,Ky
70RT Charger Offline OP
eastern,Ky
Originally Posted by Clanton
I used a base like that for my ultra bell and it worked fine just the total ht of the gage is smaller than the hole and enough movement to measure the min/max.
Ok thanks!!!
Re: What offset dials do I need? [Re: moparx] #3064322
08/01/22 12:07 PM
08/01/22 12:07 PM
eastern,Ky
eastern,Ky
Thanks! Do you think that’ll fit on the base I posted? Thought about just using the dial I already have.
Re: What offset dials do I need? [Re: 70RT Charger] #3064432
08/01/22 05:36 PM
08/01/22 05:36 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
You're going to have to stand on your head for the lower third of the rotation !! People have been making do with the type you have for decades. Will it fit any better if you ditch the second arm and attach the indicator to the main post?
Re: What offset dials do I need? [Re: Stanton] #3064436
08/01/22 05:44 PM
08/01/22 05:44 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Re: What offset dials do I need? [Re: 70RT Charger] #3064523
08/01/22 10:43 PM
08/01/22 10:43 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I have a tool I designed that might work for you. It has a 6 bolt flange and I use for all my bellhousings. If you want to use it send me a PM with your address I'll ship it to you.
Gus beer
64 Plymouth Savoy
Dana 60
Re: What offset dials do I need? [Re: Stanton] #3064582
08/02/22 09:46 AM
08/02/22 09:46 AM
eastern,Ky
eastern,Ky
Originally Posted by Stanton
This type of dial I have won’t attach to those arms. I have a straight shaft coming my way.
Re: What offset dials do I need? [Re: fourgearsavoy] #3064583
08/02/22 09:48 AM
08/02/22 09:48 AM
eastern,Ky
eastern,Ky
Gus beer
That looks sweet. I already have this straight shaft coming my way that I think will work a lot better. If it doesn’t I’ll be shooting you a PM. Thanks!!!!
Re: What offset dials do I need? [Re: 70RT Charger] #3064673
08/02/22 02:53 PM
08/02/22 02:53 PM
moparx Offline
moparx  Offline
the indicator you have appears to have the same size shafts. [remember, my eyes are not the best any more]
can't you attach your indicator to the main shaft using the clamps you have ?
beer
Re: What offset dials do I need? [Re: moparx] #3064685
08/02/22 03:37 PM
08/02/22 03:37 PM
eastern,Ky
eastern,Ky
beer
No it won’t attach. I’ve already tried it. I probably could have cut it off and rigged it up somehow but I had other stuff going on and didn’t have time to mess with it. The indicator I have now will work on this shaft I’m getting but wanted an extra one.
Re: What offset dials do I need? [Re: 70RT Charger] #3064689
08/02/22 03:56 PM
08/02/22 03:56 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I have the same one you ordered and it works just fine.
Re: What offset dials do I need? [Re: moparx] #3064829
08/03/22 08:43 AM
08/03/22 08:43 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Thank you for that. I need my own...
69 GTX 68 Road Runner
Re: What offset dials do I need? [Re: Stanton] #3064875
08/03/22 11:16 AM
08/03/22 11:16 AM
eastern,Ky
eastern,Ky
Good deal. Thanks!!!
Re: What offset dials do I need? [Re: Stanton] #3064881
08/03/22 11:32 AM
08/03/22 11:32 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
The base does not need to be mounted dead center on the crank - I don't know why people think it does. You can mount it right out on the flat surface of the flywheel, it doesn't matter. The dial indicator will be in the hole and all that matters is that IT is roughly level with the flat surface of the bell and, for lack of a better term, square to the edge of the hole. And it also has to point in the direction of the base.
X2
Re: What offset dials do I need? [Re: AndyF] #3064882
08/03/22 11:33 AM
08/03/22 11:33 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Originally Posted by AndyF
Here is the set up that I use. I had to build it myself since I couldn't find anyone who sold a tool that worked with my parts.
Do you sell the base you made ?
