Re: Need help with harmonic balancer [Re: A727Tflite] #3062612
07/26/22 07:41 AM
07/26/22 07:41 AM
VA
dragon slayer Offline
VA
So you should see 5/32" depth when balance on fully. Not 3/8 or 12/32" that you see now. So if the balance goes on an additional 7/32 does that line up the pulley? If not you might have to use a different pulley, either crank or water pump. Of course that may change every thing like alternator and power steering.
That is a wide damper with marginal inset. So it will push crank pulley farther out towards radiator.
Re: Need help with harmonic balancer [Re: rickraw] #3062623
07/26/22 08:53 AM
07/26/22 08:53 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Originally Posted by rickraw
First off, never beat a damper on. You could have damaged the thrust bearing, who knows you may have. That damper looks like it’s made wrong. Get an American made damper. Do some research for your application.
This would really be concerning me too.
Re: Need help with harmonic balancer [Re: 6PakBee] #3064361
08/01/22 02:05 PM
08/01/22 02:05 PM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
Here's an update on my balancer problem. I got a balancer installation tool from Autozone. I heated the balancer back up again in the oven, oiled the crank snout, seal and balancer inner bore and slid the balancer on the crank. Attached the tool and pushed the balancer on as far as it would go. It went on 3/32" further than the first time. There is still about 9/32" of the balancer bore showing and based on my calculations it should be 5/32" if the balancer was seated all the way on the crank. So it would seem the balancer should still go on another 1/8". The pulleys are still no where close to lining up and even if the balancer was on the additional 1/8" the pulleys still wouldn't line up. They are a matched pair taken off of a 440 and the water pump and housing are MP aluminum parts. The forged crankshaft is from 440 Source. I also wanted to mention I have a stock 440 balancer that I compared to the Summit piece. The bore is the same length and when you stand them both on their snouts on a table everything is the same except the body of the Summit balancer is wider but it does not affect the crank pulley at all. The face of the balancer where the pulley mounts is the same height off the table on both. I've about had it trying to resolve this. I'm thinking of selling the motor as-is and just buying a running 340 to put in the car. flame
Re: Need help with harmonic balancer [Re: 6PAX] #3064379
08/01/22 02:59 PM
08/01/22 02:59 PM
AndyF Offline
AndyF  Offline
Why not use the stock 440 balancer that you already have?
Re: Need help with harmonic balancer [Re: 6PAX] #3064380
08/01/22 03:00 PM
08/01/22 03:00 PM
an8sec70cuda Online content
an8sec70cuda  Online Content
I'd measure the snout of that 440 source crank versus a stock crank. twocents
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Need help with harmonic balancer [Re: an8sec70cuda] #3064406
08/01/22 04:33 PM
08/01/22 04:33 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
I had to draw in the last 1/8 with the bolt and impact gun, you will know when its seated with impact gun
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Need help with harmonic balancer [Re: AndyF] #3064434
08/01/22 05:43 PM
08/01/22 05:43 PM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
This engine build goes back 5 years (which happens to be when I bought the balancer). I have no engine building experience so a distant family member (through in-laws) offered to build it for me. He got as far as getting the rotating assembly and camshaft installed and then he suddenly passed away. The engine has been on the engine stand in my garage ever since so I am now trying to finish it up myself. I got the heads, rocker arm assemblies, distributor and water pump installed. All I have left at this point is installing the balancer, pullies and intake and I can then put the engine in the car. To answer your question about the 440 balancer, the guy who was building the motor suggested I get a new balancer since everything else was new (with the exception of the block) which is why I didn't use the 440 one.
Re: Need help with harmonic balancer [Re: 440lebaron] #3064437
08/01/22 05:45 PM
08/01/22 05:45 PM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
I was told not to do this as it could damage the threads so I assumed it wasn't safe.
Re: Need help with harmonic balancer [Re: 6PAX] #3064455
08/01/22 07:05 PM
08/01/22 07:05 PM
remove the bolt and coat it with a good anticize and reinstalled it so you can seat the balancer all the way: wrench: :two cents wrench hammer up:
The stock hole size and thread count is 3/4 inch, .750, with 16 threads per inch, if you can break it you have done something I've never heard of anyone doing that with oil or Anti seize or even dry threads of that size and countwork scope
Re: Need help with harmonic balancer [Re: Cab_Burge] #3064503
08/01/22 09:30 PM
08/01/22 09:30 PM
upstate western ny
sogtx Offline
sogtx  Offline
upstate western ny
I honed mine ever so slightly by a machinist
Re: Need help with harmonic balancer [Re: sogtx] #3064518
08/01/22 10:28 PM
08/01/22 10:28 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
iagree
I honed a few dampers before with zero issues twocents It doesn't have to be THAT tight of a grip on the crank.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Need help with harmonic balancer [Re: fourgearsavoy] #3064520
08/01/22 10:38 PM
08/01/22 10:38 PM
If it doesn't have a tightness to the crankshaft snout it won't absorb the vibrations it needs to do it jobs, way better to be tight than loose twocents(just like your G.F. whistling grin)
Re: Need help with harmonic balancer [Re: 6PAX] #3064539
08/02/22 12:45 AM
08/02/22 12:45 AM
AndyF Offline
AndyF  Offline
See if the 440 balancer will fit and work. Try it to see if the pulley alignment is correct. If it works then no reason you can't use it. Nothing else, it will show you what a proper fit looks and feels like.
Re: Need help with harmonic balancer [Re: 6PAX] #3064592
08/02/22 10:24 AM
08/02/22 10:24 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The balancer needs to be honed a bit because it's undersized , I've never had to heat a balancer to get it on.
Re: Need help with harmonic balancer [Re: JohnRR] #3064677
08/02/22 03:01 PM
08/02/22 03:01 PM
moparx Offline
moparx  Offline
if it were mine, i would remove the balancer and look close at the crank snout to see if any galling occurred.
then look at the balancer bore for the same.
lastly, i would look at the key way to see if something was going on there.
beer
Re: Need help with harmonic balancer [Re: moparx] #3064680
08/02/22 03:15 PM
08/02/22 03:15 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
I can’t imagine that no one has mentioned that the balancer is assembled backwards. look at the picture on the box that you posted in your first reply. the bolts are toward the back side on the box. the fact that the timing numbers are backwards should be a pretty strong clue…
Re: Need help with harmonic balancer [Re: TRENDZ] #3064940
08/03/22 02:33 PM
08/03/22 02:33 PM
moparx Offline
moparx  Offline
i had to look at the pictures again, but it sure seems you are on to something ! up
thanks for pointing that out !
can this balancer be taken apart and assembled the correct way by the basic person, or does it need to be sent back to the manufacturer to have it corrected ?
if i had it in my hands, i would try to take it apart and assemble it correctly. however, i have way more shop equipment than the average person, and i'm not afraid to ruin anything. biggrin
that's how one learns things. i have learned more things NOT to do than i have learned correct methods of doing things. laugh2
beer
Re: Need help with harmonic balancer [Re: moparx] #3064954
08/03/22 03:13 PM
08/03/22 03:13 PM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
The picture on the box is not what it looks like. Look at the pic I posted of it on my engine. Also here. https://www.summitracing.com/parts/sum-c4279
Re: Need help with harmonic balancer [Re: 6PAX] #3064992
08/03/22 05:24 PM
08/03/22 05:24 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
If it was me, I’d scrap it. Too many issues. First you beat it on, you may have damaged the thrust earring, second, misaligned pulley’s, third, numbers on the wrong side, Hope you straighten things out.
