How big can you stroke a gen III hemi? #3063764
07/29/22 10:58 PM
07/29/22 10:58 PM
San Jose,CA
migsBIG Offline OP
YouTube is my go-to news source
migsBIG  Offline OP
San Jose,CA
Since Mopar guys always can’t leave engines stock, has anybody built a stroker late model hemi and if so, how big did they make it? I’m kinda curious as there seems to be a lot more tech for these engines and might be worth a change from a big block engine.
Re: How big can you stroke a gen III hemi? [Re: migsBIG] #3063809
07/30/22 08:55 AM
07/30/22 08:55 AM
houston texas
gremlinsteve Offline
houston texas
I’ve seen a 4.250 stroke crank
I don’t know if there has been bigger
if You Like Gremlinsteve. Gremlinsteve Likes You.
Re: How big can you stroke a gen III hemi? [Re: gremlinsteve] #3063821
07/30/22 10:01 AM
07/30/22 10:01 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
I'm sure others will disagree but there is a limit to how much stroke you can package effectively in a 9.24 or 9.28 deck height. The pistons for the 4.080 stroke crank are barely over 1" compression height with a 6.125 rod. Thats 1.50 rod ratio. More stroke means a shorter rod and then you start to pull the piston out of the bore at the bottom of the stroke too much. Technically the limiting factor is the main oil passage casting above the crank. I know BB Chevy 632 and such combos have 1.47 RR and run great but they have large bores and GREAT heads. It will take Thitek's best heads, LARGE solid roller cam and adjustable rockers at minimum to feed a 4.250 stroke on one. Just my opinion.
Re: How big can you stroke a gen III hemi? [Re: fbs63] #3063840
07/30/22 11:31 AM
07/30/22 11:31 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Re: How big can you stroke a gen III hemi? [Re: CSK] #3064077
07/31/22 01:42 PM
07/31/22 01:42 PM
NH, USA
toddinNH Offline
Egghead
toddinNH  Offline
Egghead
NH, USA
I'm sure there are unsmart people that will opt for the $10k plus stroker option from MMX, but for standard deck heights there are saner limits to what can be achieved. A 4.125" stroke should be accessible to most builders. Tom Molnar shows the 4.250" stroke, but that will require lots of compromises.
Re: How big can you stroke a gen III hemi? [Re: toddinNH] #3064144
07/31/22 06:39 PM
07/31/22 06:39 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
HHP sells a 440. N/a. Looks nice
Re: How big can you stroke a gen III hemi? [Re: moparjim79] #3064160
07/31/22 07:51 PM
07/31/22 07:51 PM
San Jose,CA
migsBIG Offline OP
migsBIG  Offline OP
San Jose,CA
108 inch increase and it makes 1000hp. The torque numbers would probably fun factor awesome, but not sure if that would be well worth it or not. Do they supply it assembled or just the parts?
