Re: Mom's 68 road runner
[Re: ZIPPY]
#2992686
12/06/21 09:05 PM
12/06/21 09:05 PM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
Here are a few pictures to bring this up to date. I just got the front fenders back from being blasted. Apparently someone dropped the left front or hit it with something pretty hard as it came back dented in the front next to the headlight. The decal on the radiator support has the dealer service date still visible. I masked it off when I repainted the car in 1981 to save it. The area behind the hood hinges will need to be cut out and patched as well as the upper left front corner near the battery box. I think that is the worst of the remaining rust repair. the floor pans are solid .
[Re: Hemi Allstate]
#2997401
12/21/21 07:39 PM
12/21/21 07:39 PM
Posts: 17,838 S.E. Michigan
ZIPPY
S.E. Michigan
This was the only area that didn't align well. The rest looked good . Door gap , dutchman panel , etc. was good. This part was too tall from where the glass will bed and too wide . Also the lower area was not curved correctly in the radius for the moulding to fit, and that made the verticle moulding too long as well. I have it close now and will fine tune it from here. .
Mark My quarters are just like that. I admit thought I was pretty slick because I got the area where the glass lays on the side to fit nicely without cutting it (I held a piece of 3/16 steel in that glass channel and hit that with the hammer for quite a while to reshape that area, it worked better than expected), but when I test fit my molding recently I found out I'm going to have to cut the bottom part exactly like you did to get the shape correct. Your pics have definitely helped me out a bunch and I saved those + plenty of others in my FB album that you have probably noticed. Thanks again Mark and keep 'em coming.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2997851
12/23/21 12:30 PM
12/23/21 12:30 PM
Hemi Allstate
Mt. Eden Ky.
My quarters are just like that. I admit thought I was pretty slick because I got the area where the glass lays on the side to fit nicely without cutting it (I held a piece of 3/16 steel in that glass channel and hit that with the hammer for quite a while to reshape that area, it worked better than expected), but when I test fit my molding recently I found out I'm going to have to cut the bottom part exactly like you did to get the shape correct. Your pics have definitely helped me out a bunch and I saved those + plenty of others in my FB album that you have probably noticed. Thanks again Mark and keep 'em coming. [/quote] Hey Rich, Obviously that is spot that AMD has not corrected in these panels. We have to be happy that we caught it prior to painting etc. I guess. I am very glad to hear that my pictures were a help to you. You are moving along much faster than I am. Keep up the good work ! Mark
[Re: basketcase]
#3015137
02/13/22 08:28 PM
02/13/22 08:28 PM
Hemi Allstate
Mt. Eden Ky.
sucks about the fender...of course they denied any part of it? Those floors look fantastic. Yes Dave , I was told that the dent was already there! Thanks for the compliment on the floorboards. I am glad to see I won't be doing any surgery on the floors . I have epoxy primed the fenders, then skim coated them and I am blocking them out / prime and repeat. I think they are about finished. I stripped the driver's door and did similar rust repair to what was needed on the passenger door except the pinchweld was in much better shape on this one. The door has been skim coated and primed and is in the block sanding process as well. I really hated to lose the hand painted RR birds from the doors . They were done by a friend that I haven't seen in many years.
[Re: rdrnr6970]
#3076710
09/12/22 08:07 PM
09/12/22 08:07 PM
Posts: 2,914 Calgary, Alberta Canada
a12rag
Thanks for sharing the progress and great history !! It sure means more to you, as it is part of the family !!! . . . looking at your pics, made me remember all the time I spent putting my Satellite back together, wondering if I would ever see the end and drive it. Well, that was 11 years and 15k miles ago now ! . . .
Sounds like you are enjoying your journey, and probably your siblings are as well !! . . . . great to have all those memories and stories !
Cheers,
Mark
[Re: a12rag]
#3144544
05/14/23 12:36 PM
05/14/23 12:36 PM
Hemi Allstate
Mt. Eden Ky.
Thanks Guys for the kind words. I am really happy to hear that the pictures have been helpful for others here. I haven't made a lot of progress but I will share what I have . The rust behind the hinges as well as the front corners or the radiator support had rust coming through and so was my focus for repairs now. I think this is the last of the rust repairs, at least I hope so ! Mark
