Re: My new Slanty! Not what you'd think
[Re: cudaman1969]
#3063575
07/29/22 11:51 AM
07/29/22 11:51 AM
Posts: 7,498 Minnesota
Hemi_Joel
Minnesota
The problem is that it has no suspension whatsoever. And the majority of the weight is on the rear wheels. So if one of the rear wheels hits a slight low spot, or digs into the gravel just a little bit, it teeter totters one of the front wheels up off of the ground. Or if one of the front wheels hits a low spot, all the weight transfers to the other three wheels. Since it is front wheel drive with out positraction, as soon as one front wheel is unloaded, it spins. I have another facility that is all paved that I use just for material storage when I need to, but that is pretty infrequent.. I'm contemplating whether to bring it out there and try and get some use out of it or flip it. It's so cool I hate to get rid of it but I probably should. I think I could make a little bit on it.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#3063584
07/29/22 12:12 PM
07/29/22 12:12 PM
Posts: 21,553 N.E. OHIO, USA
A12
N.E. OHIO, USA
The problem is that it has no suspension whatsoever. And the majority of the weight is on the rear wheels. So if one of the rear wheels hits a slight low spot, or digs into the gravel just a little bit, it teeter totters one of the front wheels up off of the ground. Or if one of the front wheels hits a low spot, all the weight transfers to the other three wheels. Since it is front wheel drive with out positraction, as soon as one front wheel is unloaded, it spins. I have another facility that is all paved that I use just for material storage when I need to, but that is pretty infrequent.. I'm contemplating whether to bring it out there and try and get some use out of it or flip it. It's so cool I hate to get rid of it but I probably should. I think I could make a little bit on it. You just need to figure out how to split the front brake system when that happens. My John Deere 322 has two brake pedals side by side with a plate that connects them together, The plated pivots and if I lose traction on one drive wheel I disconnect the brake pedals and hold the brake on the spinning wheel to drive the traction wheel. Maybe just left footing the brake and right footing the throttle will get you the traction you need for the situation???
[Re: A12]
#3063590
07/29/22 12:24 PM
07/29/22 12:24 PM
Posts: 10,049 MN
JERICOGTX
MN
The problem is that it has no suspension whatsoever. And the majority of the weight is on the rear wheels. So if one of the rear wheels hits a slight low spot, or digs into the gravel just a little bit, it teeter totters one of the front wheels up off of the ground. Or if one of the front wheels hits a low spot, all the weight transfers to the other three wheels. Since it is front wheel drive with out positraction, as soon as one front wheel is unloaded, it spins. I have another facility that is all paved that I use just for material storage when I need to, but that is pretty infrequent.. I'm contemplating whether to bring it out there and try and get some use out of it or flip it. It's so cool I hate to get rid of it but I probably should. I think I could make a little bit on it. You just need to figure out how to split the front brake system when that happens. My John Deere 322 has two brake pedals side by side with a plate that connects them together, The plated pivots and if I lose traction on one drive wheel I disconnect the brake pedals and hold the brake on the spinning wheel to drive the traction wheel. Maybe just left footing the brake and right footing the throttle will get you the traction you need for the situation??? Don't give him any ideas... He doesn't have time to figure all that out.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3063597
07/29/22 12:33 PM
07/29/22 12:33 PM
A12
N.E. OHIO, USA
The problem is that it has no suspension whatsoever. And the majority of the weight is on the rear wheels. So if one of the rear wheels hits a slight low spot, or digs into the gravel just a little bit, it teeter totters one of the front wheels up off of the ground. Or if one of the front wheels hits a low spot, all the weight transfers to the other three wheels. Since it is front wheel drive with out positraction, as soon as one front wheel is unloaded, it spins. I have another facility that is all paved that I use just for material storage when I need to, but that is pretty infrequent.. I'm contemplating whether to bring it out there and try and get some use out of it or flip it. It's so cool I hate to get rid of it but I probably should. I think I could make a little bit on it. You just need to figure out how to split the front brake system when that happens. My John Deere 322 has two brake pedals side by side with a plate that connects them together, The plated pivots and if I lose traction on one drive wheel I disconnect the brake pedals and hold the brake on the spinning wheel to drive the traction wheel. Maybe just left footing the brake and right footing the throttle will get you the traction you need for the situation??? Don't give him any ideas... He doesn't have time to figure all that out. ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
[Re: A12]
#3063707
07/29/22 07:12 PM
07/29/22 07:12 PM
Posts: 15,952 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
When I was in high school I worked at a local marina and I was shocked to see the big travel lift had a slant six!
Facts are stubborn things.
[Re: Hemi_Joel]
#3063746
07/29/22 10:13 PM
07/29/22 10:13 PM
Posts: 10,661 Freeport IL USA
poorboy
Freeport IL USA
I probably shouldn't say this but.... When I worked in factory maintenance, the two slant 6 fork trucks we had were both equipped with a very narrow 8 3/4.. Sure Grip time? LOL! Bet that would be fun with about 4,000 load on an 8,000 lift, trying to make a turn.
For those that don't know fork trucks, the one Joel has uses solid steel wheels with pressed on tread less tires vulcanized on to a steel sleeve. New tires with tread on the outer edges are available, but won't help much because one of the drive tires was usually off the ground. 40 years ago new solid rubber with the steel sleeve, drive wheel, fork lift tires were just over $500 each, the steering tires with the steel sleeves were about 1/2 the price). Wouldn't try to guess what they would cost now.
I did just see that Joel's fork lift already has the treaded drive tires. That is as good as they get as far as traction, which pretty much sucks on anything other then a dry, hard surface.
[Re: SLO-KID]
#3063775
07/30/22 12:25 AM
07/30/22 12:25 AM
Posts: 20,224 Park Forest, IL
slantzilla
Park Forest, IL
I worked on a bunch of those when I worked at the Hyster dealership. Yale used a lot of Slants. Does your have the belt driven transmission pump that looks like a power steering pump driven by 3 belts?
[Re: SLO-KID]
#3063778
07/30/22 01:09 AM
07/30/22 01:09 AM
Hemi_Joel
Minnesota
Is it drag week ready and where’s Jeff gonna sit? Jeff can be like the spider in a motorcycle side car race, maneuvering all over to keep weight on the drive wheels. https://youtu.be/SltqgZrPXt8
[Re: A12]
#3063909
07/30/22 04:24 PM
07/30/22 04:24 PM
Posts: 5,966 ohio
ruderunner
ohio
I did that to a couple pairs of boots when I worked in the lumber yards.
Angry white pureblood male
[Re: ruderunner]
#3063911
07/30/22 04:32 PM
07/30/22 04:32 PM
Posts: 5,966 ohio
ruderunner
ohio
I've seen a few of the bigger Hysters with, GM 350, GM 6.2 diesel and honest to God Detroit Diesels! Happy the last one had a blown transmission so nobody tried to use it.
[Re: SLO-KID]
#3064400
08/01/22 03:50 PM
08/01/22 03:50 PM
Posts: 10,049 MN
JERICOGTX
MN
Is it drag week ready and where’s Jeff gonna sit? It's more Drag Week ready than the Coupe, and I'll most likely be sitting at work, while Drag Week is going on.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3064424
08/01/22 04:55 PM
08/01/22 04:55 PM
Posts: 8,038 Tulsa OK
Bad340fish
Tulsa OK
Jeff you should probably run over there and put the battery charger on the GTX.
68 Barracuda Formula S 340
[Re: Bad340fish]
#3064682
08/02/22 03:25 PM
08/02/22 03:25 PM
Posts: 10,049 MN
JERICOGTX
MN
Jeff you should probably run over there and put the battery charger on the GTX. ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif) I kinda wish we would be taking the parade car again. We had a ton of fun on that trip, but those days are over, for that car.
69 GTX
68 Road Runner
