Re: Filling the valve covers with oil at WOT
[Re: AndyF]
#3063173
07/28/22 01:00 AM
07/28/22 01:00 AM
Posts: 11,526 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Oil restrictors. That's oil that should be on the crank.
[Re: AndyF]
#3063220
07/28/22 10:01 AM
07/28/22 10:01 AM
Posts: 17,840 S.E. Michigan
ZIPPY
S.E. Michigan
Can't really see the oil level rising, maybe my fault or I need new glasses.
It'd be a good test for a Hemi, given the internet folklore of "each valve cover holds a gallon of oil at high rpm" or whatever it is this week.
Dave V. sent me some valve covers that are too wide to fit most passenger vehicles, but would work on a dyno, and are nice and flat for opening up and creating a couple picture windows, above and below the spark plugs for a similar test. Hmm, maybe they'd be good for that type of project.
Rich H.
Esse Quam Videri
[Re: moparx]
#3063361
07/28/22 04:22 PM
07/28/22 04:22 PM
ZIPPY
S.E. Michigan
Windows and/or various styles of sight glasses and sight tubes in oil pans have been used for many years for this kind of testing.
A sight tube can give a more solid view of how much liquid oil is really there, without struggling to see through a hurricane.
Rich H.
Esse Quam Videri
[Re: AndyF]
#3063364
07/28/22 04:31 PM
07/28/22 04:31 PM
Posts: 43,123 Bend,OR USA
Cab_Burge
B1 motors are famous for that, even with additional #8 AN drain hoses added on each end of both heads My next B1 motor will have #10 AN drain back from each end of both heads to help keep the oil in the oil pan quicker: luck:
[Re: ZIPPY]
#3063600
07/29/22 12:37 PM
07/29/22 12:37 PM
Posts: 19,342 north of coder
moparx
A sight tube can give a more solid view of how much liquid oil is really there, without struggling to see through a hurricane. if one were to make up a sight tube, what size of tubing would be best, and what material would one use that wouldn't cloud or degrade over time ? where would be the best place to install the sight tube ? what type of fittings would be the best to use ?
[Re: AndyF]
#3063627
07/29/22 02:04 PM
07/29/22 02:04 PM
Posts: 19,360 Las Vegas
Al_Alguire
Las Vegas
Just goes to show you can get away with a very small restrictor for top end oiling.
[Re: Al_Alguire]
#3063628
07/29/22 02:06 PM
07/29/22 02:06 PM
Al_Alguire
Las Vegas
A window in the pan might help some IF it was on the other side of the pan than the one pictured. On the pass side its going to get covered as soon as you fire it up and the crank will be slinging any oil there that direction. Oil control and oil in suspension from the lack of control at the crank are big issues with a BBM for sure.
[Re: AndyF]
#3063652
07/29/22 03:03 PM
07/29/22 03:03 PM
Posts: 16,923 NC
440Jim
NC
Yeah I'm not sure how much oil was actually trapped in the valve covers in these tests, you can see it coat the bottom of the Lexan window but you can't see anything else. This was a wet sump engine. I have videos of a dry sump engine and it does the same thing. The rocker arms throw off so much oil at WOT that even the dry sump can't suck it all back into the tank. That is all I could see as well. It is interesting to see at least something in the valve cover for info.
