Re: old Optima batteries
[Re: hemienvy]
#3062111
07/24/22 02:45 PM
07/24/22 02:45 PM
Posts: 2,094 Byron, NY
W.I.N. Racing
Byron, NY
Here is what I was told to do... Take a Lead Acid battery and run jumper cables from the LA to the Optima (pos to pos) and (neg to neg) then put a battery charger on the LA battery.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: hemienvy]
#3062159
07/24/22 05:04 PM
07/24/22 05:04 PM
W.I.N. Racing
Byron, NY
W.I.N., I'll try that but I don't understand....... The resistance in a AGM battery is so low that the charger doesn't see a load. Make sure you start with a fully charged LA battery...
[Re: hemienvy]
#3062185
07/24/22 06:56 PM
07/24/22 06:56 PM
W.I.N. Racing
Byron, NY
[Re: W.I.N. Racing]
#3062586
07/25/22 10:17 PM
07/25/22 10:17 PM
Posts: 1,229 In The Hills
jughed
In The Hills
Thanks for that Wish i had known of this before trading in a 'dead' 15 yr. old red Optima core for a new Optima last year. I would have bought the new Optima anyway, but could have given them a different core. Would have been worth a try to recharge it.
[Re: W.I.N. Racing]
#3062591
07/25/22 10:43 PM
07/25/22 10:43 PM
Posts: 1,072 Loudoun County, VA
Brad_Haak
Loudoun County, VA
Haven't watched the vid yet, but I have an OLD Optima that's been sitting around for 10+ years. I also have a new one I purchased w/in the last year to replace it, since I ASSumed the old one was nothing but scrap now.
2021 Challenger 6.4L Scat Pack 1320 (2022) 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) wheels, tires, air filter: 1.714, 11.833 at 115.80 (DA 310 ft)
1973 Challenger 452 ci street/strip (2008) pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: W.I.N. Racing]
#3062616
07/26/22 08:07 AM
07/26/22 08:07 AM
Posts: 161 W. Pa
usp4u
W. Pa
Here is what I was told to do... Take a Lead Acid battery and run jumper cables from the LA to the Optima (pos to pos) and (neg to neg) then put a battery charger on the LA battery. Have done this before, myself. It works.
[Re: Brad_Haak]
#3062645
07/26/22 10:19 AM
07/26/22 10:19 AM
Posts: 30,947 Oregon
AndyF
Haven't watched the vid yet, but I have an OLD Optima that's been sitting around for 10+ years. I also have a new one I purchased w/in the last year to replace it, since I ASSumed the old one was nothing but scrap now. The video is good. They recover a 20 year old Optima by using another battery as a storage cell. The trick requires a battery charger with a 10 amp setting. Trickle charger doesn't work and neither does the super blast type of charger.
[Re: AndyF]
#3062710
07/26/22 12:15 PM
07/26/22 12:15 PM
W.I.N. Racing
Byron, NY
As an aside... I have switched to Snyder motorsports batteries, smaller (by weight and size) and less expensive.
[Re: hemienvy]
#3062897
07/27/22 06:30 AM
07/27/22 06:30 AM
Posts: 8,005 Tulsa OK
Bad340fish
Tulsa OK
Next time you have it charging and it gets warm feel all the cylinders, if one is cold then you likely won't get it over 10.5v or so due to a dead cell.
68 Barracuda Formula S 340 87 "Chrysler" Conquest
