Gasket Sealer " Part 2 " #3062688
07/26/22 11:46 AM
07/26/22 11:46 AM
Ohio
B5TA Offline OP
B5TA  Offline OP
Ohio
, Are you guys using any gasket sealer on the timing chain cover and water pump gaskets ? If so what you using ? ( Sm. Block ) Thanks, Kevin
Next question , What are you doing as far as the ends of the intake manifold ? any Gaskets or just sealer ? ( Wall of China )
Re: Gasket Sealer [Re: B5TA] #3062697
07/26/22 11:57 AM
07/26/22 11:57 AM
IMGTX Offline
IMGTX  Offline
I use a thin smear of RTV/Permatex.
Just enough to keep the gasket in place and seal a few little imperfections but the paper gasket does the work.
The thin smear also makes it a little easier to clean the gasket off in the future. Straight paper will bake on hard over the long haul and has to be evicted with more force.
Make sure the timing cover is flat. The stamped steel ones on big block often get bent from over tightening and force-ably removing them.
Re: Gasket Sealer [Re: IMGTX] #3062705
07/26/22 12:09 PM
07/26/22 12:09 PM
5thAve Offline
5thAve  Offline
I use gasket sealer. It's made by permatex it's brown and it stinks.
Re: Gasket Sealer [Re: 5thAve] #3062734
07/26/22 01:10 PM
07/26/22 01:10 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Same as IMGTX.
Re: Gasket Sealer [Re: topside] #3062771
07/26/22 03:10 PM
07/26/22 03:10 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Not unless there are imperfections/corrosion damage around the coolant holes. Otherwise, maybe a light smear around the coolant passages only.
Re: Gasket Sealer [Re: B5TA] #3062784
07/26/22 04:15 PM
07/26/22 04:15 PM
Gasket Cinch on the gaskets and thread sealer on the 2 or 3 wet bolts scope up
Motor oil on the other dry bolts up
Re: Gasket Sealer [Re: Cab_Burge] #3062818
07/26/22 06:26 PM
07/26/22 06:26 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
I use Permatex Copper Spray-A-Gasket just to hold them in place more than anything else. I very, very sparingly use RTV in some cases, but not here.
Re: Gasket Sealer [Re: Sniper] #3062856
07/26/22 09:12 PM
07/26/22 09:12 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
permatex ultra black beer
Re: Gasket Sealer [Re: TJP] #3062899
07/27/22 06:41 AM
07/27/22 06:41 AM
rust belt
Moparite Online content
Moparite  Online Content
rust belt
permatex ultra copper, Great stuff!
Re: Gasket Sealer [Re: Moparite] #3062900
07/27/22 06:50 AM
07/27/22 06:50 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I sometimes use that brown permatex with the brush in the can. If I really have a tough one to seal, I use that Right Stuff in the tube. It expensive but is the best silicon type you can buy.
Re: Gasket Sealer [Re: fastmark] #3062966
07/27/22 10:33 AM
07/27/22 10:33 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
I have used pretty much all of the products mentioned in the above posts. I would add the following to your sealer arsenal
1. Gorilla Snot (aka 3M Trim Adhesive). Use it like a heavy duty version of Gasgacinch
2. The red High Tack spray can be useful but kind of ugly looking.
3. On metal gaskets like BB valley tubs I use Aluminum spray paint that has aluminum particles in it. works as good as copper coat without the ugly color.
4. Some people swear by some of the OEM sealers like Yamabond and Hondabond.
Notes about RTV (silicone sealers).
1. Use it very sparingly. When squeezed thin, globs will squeeze inward and break off. Eventually getting caught in oil pickups.
2. It does work great in place of thick gaskets to seal gaps like where Intake manifolds that don't use tub gaskets sit above the china walls. Example: SBMopar
3. The extreme high temp versions can actually be used instead of header gaskets.
Re: Gasket Sealer [Re: B5TA] #3063621
07/29/22 01:38 PM
07/29/22 01:38 PM
Pasadena, Texas
fal3 Offline
fal3  Offline
Pasadena, Texas
I like to use Permatex type 3 aviation gasket glue. It's impervious to just about everything-gas, oil, heat, water. Someone on here years ago recommended it for intake manifolds. I was always chasing vacuum leaks using only rtv silicon. Same with annoying oil leaks. Brushes on nice and smooth; gives you better control on gasket glue oozing out and contaminating oil pick-up.
Re: Gasket Sealer [Re: fal3] #3063638
07/29/22 02:32 PM
07/29/22 02:32 PM
moparx Offline
moparx  Offline
how is it [type 3] when it comes to removal time ?
beer
Re: Gasket Sealer " Part 2 " [Re: B5TA] #3064262
08/01/22 10:28 AM
08/01/22 10:28 AM
Ohio
B5TA Offline OP
B5TA  Offline OP
Ohio
bump
Re: Gasket Sealer " Part 2 " [Re: B5TA] #3064316
08/01/22 12:00 PM
08/01/22 12:00 PM
5thAve Offline
5thAve  Offline
I use RTV/silicone. Actual gasket sealer can't be used for stuff like that.
Re: Gasket Sealer " Part 2 " [Re: B5TA] #3064347
08/01/22 01:20 PM
08/01/22 01:20 PM
Pasadena, Texas
fal3 Offline
fal3  Offline
Pasadena, Texas
Perm type 3 came off fairly easy. Used some paint thinner, little elbow grease, very fine steel wool. For stubborn spots, go easy with a razor blade. For example, with intake manifold, took about 10-15 minutes, from laying out materials to throwing waste in trash.
Re: Gasket Sealer " Part 2 " [Re: 5thAve] #3064359
08/01/22 01:58 PM
08/01/22 01:58 PM
Ohio
B5TA Offline OP
B5TA  Offline OP
Ohio
Yes, sorry my bad. I did not use the correct wording . I meant RTV silicone , but said sealer. I know alot of the guys just used the RTV silicone, but didn't know if ideas have change any pertaining to the " End " gaskets. Thanks, Kevin
Re: Gasket Sealer " Part 2 " [Re: B5TA] #3064431
08/01/22 05:34 PM
08/01/22 05:34 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
A very thin layer of Ultra Copper on the timing cover and teflon pipe dope on the wet bolts. On any of the long bolts that go through the timing cover into the block I like to use a thin layer of anti-seize on the shanks of the of the bolts. It can save a lot of headache down the road. For the china walls, I sue the same silicone and let it dry for at least two days before trimming the excess with a razor blade.
Re: Gasket Sealer " Part 2 " [Re: justinp61] #3064655
08/02/22 01:49 PM
08/02/22 01:49 PM
moparx Offline
moparx  Offline
always a good idea to use anti-seize on steel bolts used to secure aluminum components, unless the holes are way bigger than the bolts.
still a good idea regardless.
beer
Re: Gasket Sealer " Part 2 " [Re: B5TA] #3064691
08/02/22 04:07 PM
08/02/22 04:07 PM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
I use Hylomar aviation sealant on intake. Stays relatively soft and isn't affected by fuel. I don't use the paper gaskets on either side of the valley pan but use gaskets everywhere else with Gaskacinch
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
