Hemi Spark plug tubes #3062369
07/25/22 11:45 AM
07/25/22 11:45 AM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
Changed the plugs on a 426 Hemi and # 1 and 2 were nice and dry...#3 through 8 had oil. Plugs installed with washers from day 1. Is there a solution to keeping the oil out ?
I would think that by now someone would invent some sort of seal or gasket.
Thanks MOPARTS...Thanks to all in advance
Re: Hemi Spark plug tubes [Re: terzmo] #3062378
07/25/22 12:05 PM
07/25/22 12:05 PM
central il.
second 70 Offline
second 70  Offline
central il.
I always have oil in some of my tubes. It's just something I quit fighting and learned to accept was the norm.
Re: Hemi Spark plug tubes [Re: terzmo] #3062388
07/25/22 12:33 PM
07/25/22 12:33 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
There are tube seals made for this
Milodon sold by Summit, Jegs, Mancini and many others
Summit
Much cheaper. Made in China copy?
Classic Industries
Note:. They install easier if you freeze them first.
Note2: Don't know if it is true but I read somewhere that they may not fit aftermarket heads that have beafier rocker stands.
Re: Hemi Spark plug tubes [Re: terzmo] #3062403
07/25/22 01:11 PM
07/25/22 01:11 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
There are seals available , has been for decades .
I thought I read no washers on the plugs ?
Re: Hemi Spark plug tubes [Re: JohnRR] #3062427
07/25/22 01:56 PM
07/25/22 01:56 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Always had a little oil in mine, didn't seem to affect the plug.
The washers really scrape the hell out of the tubes; I quit using washers and never had a problem without them.
Re: Hemi Spark plug tubes [Re: GomangoCuda] #3062473
07/25/22 03:14 PM
07/25/22 03:14 PM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
Summit
Classic Industries
Valve covers off for installation or just plugs and tubes...Thanks
Re: Hemi Spark plug tubes [Re: topside] #3062476
07/25/22 03:17 PM
07/25/22 03:17 PM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
Did You initially remove the washers or after one or two plug changes ? I'm told that the washers beat up the tubes...told the washers stay on...big debate I guess. Thanks
Re: Hemi Spark plug tubes [Re: terzmo] #3062489
07/25/22 04:03 PM
07/25/22 04:03 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I think it would be a lot easier with the covers off.
Re: Hemi Spark plug tubes [Re: JohnRR] #3062497
07/25/22 04:30 PM
07/25/22 04:30 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
1st few times, I ran the washers - heard from a Hemi racer/engine guy not to - saw what he meant at next plug change.
Replaced the tubes rather than risk little shards getting into anything. Ran it some 30 years w/o the washers.
Re: Hemi Spark plug tubes [Re: JohnRR] #3062511
07/25/22 05:24 PM
07/25/22 05:24 PM
GomangoCuda Offline
GomangoCuda  Offline
Impossible with covers on.
Re: Hemi Spark plug tubes [Re: JohnRR] #3062584
07/25/22 10:14 PM
07/25/22 10:14 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Correct or the tubes gall wink
Re: Hemi Spark plug tubes [Re: TJP] #3062658
07/26/22 10:55 AM
07/26/22 10:55 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
With or without lubricant/anti seize compound?
Aluminum head instructions always state use anti seize compound....should take care of that
Rich H.
Esse Quam Videri
Re: Hemi Spark plug tubes [Re: ZIPPY] #3062666
07/26/22 11:11 AM
07/26/22 11:11 AM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
Will the tube seals work on aluminum heads ?
Now I changed the plugs and left the washers on. Drove the car and the smoke and sputtering cleared up as usual but now when it sits for a while and I start it..it fires up nicely but idles erraticly and smokes for a few minutes..like I just changed a plug. So I "assume" there is a tube or two leaking into a cylinder or two. New tubes and no washers ?
Re: Hemi Spark plug tubes [Re: terzmo] #3062671
07/26/22 11:22 AM
07/26/22 11:22 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
“Will the tube seals work on aluminum heads?”
They do on my -m heads
Re: Hemi Spark plug tubes [Re: terzmo] #3062750
07/26/22 01:38 PM
07/26/22 01:38 PM
A727Tflite Offline
A727Tflite  Offline
Since inception we have never used spark plug washers. Makes no difference if cast iron or aluminum heads.
If tubes were used with washers I would start with new tubes or find the appropriate size socket and extension and flatten the inside gasket face of the tube.
Depends how knarled up they are.
Re: Hemi Spark plug tubes [Re: terzmo] #3062946
07/27/22 09:49 AM
07/27/22 09:49 AM
Northeast Indiana
73DAD Offline
73DAD  Offline
Northeast Indiana
I don't understand why using the washer on the plug would cause galling while removing them doesn't. Most of you guys seem to be in agreement on it so there must be some truth to it.
I would expect a plug with no washer would compress the tube end, drag against the aluminum while tightening, and work harden it until it chips off. I would also the expect a crush washer to somewhat prevent that.
But the opposite is true??? I've been using the crush washers on my own Hemi since I built it in 2016, so far so good on the tubes, but I'm open to change if there's a good reason.
Re: Hemi Spark plug tubes [Re: 73DAD] #3062969
07/27/22 10:41 AM
07/27/22 10:41 AM
VA
dragon slayer Offline
VA
It was recommended to me also, and I used them. I just don't torque down as much on the plugs.
Re: Hemi Spark plug tubes [Re: 73DAD] #3062970
07/27/22 10:44 AM
07/27/22 10:44 AM
A727Tflite Offline
A727Tflite  Offline
You reduce the effective surface area by using the washer which increases the “unit loading” which galls the tube.
The tube acts as a seal, pinched by the plug and head, it conforms to the plug and head. I have actually had to use a few tubes that were jacked up. By repeated tightening and loosening you can sometimes salvage the tube in a pinch.
(A similar galling issue - using the incorrect head gasket on an aluminum head).
Re: Hemi Spark plug tubes [Re: 73DAD] #3063018
07/27/22 01:55 PM
07/27/22 01:55 PM
All the hemi motors I know of, except the latest Gen 3 motors that I have not work, came with washers on all the plugs.
I have had some of the tubes on the 426 motor tear the sealing surfaces off completely and still work fine with the after market push in tube seals up twocents
I did try running one of those motors several times without the washer and ended putting them back in, especially on iron heads up wrench
Re: Hemi Spark plug tubes [Re: Cab_Burge] #3063025
07/27/22 02:34 PM
07/27/22 02:34 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Just use the oil plug nylon washer,
