Gasket Sealer " Part 2 "
#3062688
07/26/22 11:46 AM
07/26/22 11:46 AM
Posts: 881 Ohio
B5TA
Ohio
, Are you guys using any gasket sealer on the timing chain cover and water pump gaskets ? If so what you using ? ( Sm. Block ) Thanks, Kevin
Next question , What are you doing as far as the ends of the intake manifold ? any Gaskets or just sealer ? ( Wall of China )
Re: Gasket Sealer
[Re: topside]
#3062771
07/26/22 03:10 PM
07/26/22 03:10 PM
Posts: 11,526 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Not unless there are imperfections/corrosion damage around the coolant holes. Otherwise, maybe a light smear around the coolant passages only.
Re: Gasket Sealer
[Re: fastmark]
#3062966
07/27/22 10:33 AM
07/27/22 10:33 AM
Posts: 4,711 Moved to N.E. Tennessee
GomangoCuda
I have used pretty much all of the products mentioned in the above posts. I would add the following to your sealer arsenal
1. Gorilla Snot (aka 3M Trim Adhesive). Use it like a heavy duty version of Gasgacinch 2. The red High Tack spray can be useful but kind of ugly looking. 3. On metal gaskets like BB valley tubs I use Aluminum spray paint that has aluminum particles in it. works as good as copper coat without the ugly color. 4. Some people swear by some of the OEM sealers like Yamabond and Hondabond.
Notes about RTV (silicone sealers). 1. Use it very sparingly. When squeezed thin, globs will squeeze inward and break off. Eventually getting caught in oil pickups. 2. It does work great in place of thick gaskets to seal gaps like where Intake manifolds that don't use tub gaskets sit above the china walls. Example: SBMopar 3. The extreme high temp versions can actually be used instead of header gaskets.
Re: Gasket Sealer " Part 2 "
[Re: B5TA]
#3064262
08/01/22 10:28 AM
08/01/22 10:28 AM
Posts: 881 Ohio
B5TA
Ohio
[Re: B5TA]
#3064316
08/01/22 12:00 PM
08/01/22 12:00 PM
Posts: 4,142 Canada -- Posts: 4034 -Registe...
5thAve
I use RTV/silicone. Actual gasket sealer can't be used for stuff like that.
[Re: B5TA]
#3064691
08/02/22 04:07 PM
08/02/22 04:07 PM
Posts: 5,137 East Aurora (Buffalo) NY
RoadRunner
Next question , What are you doing as far as the ends of the intake manifold ? any Gaskets or just sealer ? ( Wall of China ) I use Hylomar aviation sealant on intake. Stays relatively soft and isn't affected by fuel. I don't use the paper gaskets on either side of the valley pan but use gaskets everywhere else with Gaskacinch
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
