Aluminum Driveshaft? #3061701
07/22/22 08:00 PM
07/22/22 08:00 PM
MN
JERICOGTX Offline OP
MN
Who makes a good aluminum driveshaft, at a reasonable price, and not take 6 months to get?
Thanks.
Jeff
69 GTX 68 Road Runner
Re: Aluminum Driveshaft? [Re: JERICOGTX] #3061724
07/22/22 09:31 PM
07/22/22 09:31 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I got mine made at Henderson Driveline in Grafton Ohio and my friend just had 1 made in 2 days the ph# 440 892 0411
Re: Aluminum Driveshaft? [Re: Clanton] #3061745
07/22/22 11:20 PM
07/22/22 11:20 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Minnesota Driveline in St. Cloud will make you one.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Aluminum Driveshaft? [Re: Hemi_Joel] #3061754
07/23/22 01:15 AM
07/23/22 01:15 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Mark Williams
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Aluminum Driveshaft? [Re: BloFish] #3061796
07/23/22 09:42 AM
07/23/22 09:42 AM
Pattison Texas
CSK Online shake_head
CSK  Online Shake_Head
Pattison Texas
Originally Posted by BloFish
Mark Williams
X2
Re: Aluminum Driveshaft? [Re: CSK] #3061882
07/23/22 04:01 PM
07/23/22 04:01 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
It had damm well better be polished to a high luster when installed
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Aluminum Driveshaft? [Re: bigdad] #3061950
07/23/22 09:47 PM
07/23/22 09:47 PM
MN
MN
laugh2
Re: Aluminum Driveshaft? [Re: JERICOGTX] #3061951
07/23/22 10:17 PM
07/23/22 10:17 PM
AZLIVN
SLO-KID Offline
SLO-KID  Offline
AZLIVN
I presently have an aluminum from Inland Empire and while they hit the mark on the Mirada shaft, I suspect the one in the Duster “ain’t quite right”….. I “believe” Mark Williams has the equipment to spin balance them at a higher rpm.
Re: Aluminum Driveshaft? [Re: BloFish] #3062024
07/24/22 09:21 AM
07/24/22 09:21 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Mark Williams
x3
Re: Aluminum Driveshaft? [Re: JERICOGTX] #3062046
07/24/22 11:13 AM
07/24/22 11:13 AM
Minnesota
R3 Racing Offline
R3 Racing  Offline
Minnesota
Inland Empire made mine.
Re: Aluminum Driveshaft? [Re: R3 Racing] #3062081
07/24/22 01:01 PM
07/24/22 01:01 PM
moparx Offline
moparx  Offline
high rpm balance on any drive shaft is a must, in my opinion, regardless of the material made of.
beer
Re: Aluminum Driveshaft? [Re: moparx] #3062176
07/24/22 06:15 PM
07/24/22 06:15 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
X4 On Mark Williams you wont be sorry....
Re: Aluminum Driveshaft? [Re: Hemi_Joel] #3062358
07/25/22 11:11 AM
07/25/22 11:11 AM
MN
MN
I called them. They wanted as much as Mark Williams to make one...
Re: Aluminum Driveshaft? [Re: JERICOGTX] #3062375
07/25/22 11:56 AM
07/25/22 11:56 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I think I paid 625$ for mine in Grafton.I had the yoke already.
Re: Aluminum Driveshaft? [Re: Clanton] #3062382
07/25/22 12:19 PM
07/25/22 12:19 PM
MN
MN
I was quoted $900, and using my yoke.
Re: Aluminum Driveshaft? [Re: JERICOGTX] #3062466
07/25/22 02:57 PM
07/25/22 02:57 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Shipping would probably be a deal killer, but if it helps at all here are two local companies that do good work.
https://www.dynotechengineering.com/
https://www.raven-engineering.com/driveshafts-engineered-products/
Rich H.
Esse Quam Videri
Re: Aluminum Driveshaft? [Re: ZIPPY] #3062479
07/25/22 03:32 PM
07/25/22 03:32 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Everyone uses these folks around here .
https://www.drivelineserviceinc.com/
Re: Aluminum Driveshaft? [Re: bigdad] #3062482
07/25/22 03:40 PM
07/25/22 03:40 PM
Pattison Texas
Pattison Texas
I went through drive shaft hell, Mark Williams has the correct ballance machine to spin it to the correct RPM, I had a Strange shaft & fought a vibration, also 2 other ones built locally to me, turns out they can only spin it 500 rpm, got one from MW & problem solved, $1400 dollars worth of JUNK drive shafts, GRRRRRRRR
Re: Aluminum Driveshaft? [Re: JERICOGTX] #3062493
07/25/22 04:13 PM
07/25/22 04:13 PM
Dunnellon, FL
longram60 Offline
longram60  Offline
Dunnellon, FL
I
I had good luck with a Victory Performance aluminum driveshaft:
http://www.victorynss.com/index.php?option=com_content&view=article&id=12
1979 AMC Spirit, NHRA Q/SA
Re: Aluminum Driveshaft? [Re: JERICOGTX] #3062535
07/25/22 06:26 PM
07/25/22 06:26 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
During the winter, they built a 5" aluminum, about 6 feet long for my truck for $700 something. Maybe they went up, or perhaps they use better more expensive yokes in a race car.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
