Re: Hemi Spark plug tubes
[Re: TJP]
#3063132
07/27/22 09:39 PM
07/27/22 09:39 PM
Posts: 8,356 fredericksburg,va
cudaman1969
fredericksburg,va
Just use the oil plug nylon washer, What's an oil plug nylon washer ? do you mean a drain plug washer? Will they take the heat without losing their rigidity? If not there are likely other plastics that probably would. HMM maybe a good idea Yes, what I meant. Not sure how much heat is right there but I would say no more the hot oil in the pan, 250 degrees?
[Re: moparx]
#3064233
08/01/22 08:04 AM
08/01/22 08:04 AM
Posts: 2,060 Pendleton NY
terzmo
Pendleton NY
Just the one it came with.....someone mentioned to use loctite 518 on the back side of the washer.
[Re: ZIPPY]
#3064618
08/02/22 12:15 PM
08/02/22 12:15 PM
Posts: 15,540 Omaha Ne
TJP
Omaha Ne
The dorman's doo look nice. I've been using these GASKET ASST. LINKY And have taken to wrapping the plug threads with teflon tape Shop on the suggested kits if you go that way as the price varies
[Re: TJP]
#3065082
08/04/22 08:47 AM
08/04/22 08:47 AM
Posts: 1,343 VA
dragon slayer
VA
The dorman's doo look nice. I've been using these GASKET ASST. LINKY And have taken to wrapping the plug threads with teflon tape Shop on the suggested kits if you go that way as the price varies Are we still talking spark plugs or have you shifted to oil plugs? Please tell me you don't teflon wrap spark plugs
[Re: dragon slayer]
#3065141
08/04/22 11:54 AM
08/04/22 11:54 AM
TJP
Omaha Ne
The dorman's doo look nice. I've been using these GASKET ASST. LINKY And have taken to wrapping the plug threads with teflon tape Shop on the suggested kits if you go that way as the price varies Are we still talking spark plugs or have you shifted to oil plugs? Please tell me you don't teflon wrap spark plugs Sure do, keeps them from making a good ground to the cylinder head and is great for comebacks, then i can upgrade the plug wires and other things back to the drain plug, any chance you have a 12mm x 1.75 bolt n a 1/2x20 opening? I ask as they are close diameter and pitch wise, may mate and tighten but with little thread engagement. In over 50 years I have never encountered a drain plug that kept loosening.
[Re: TJP]
#3065185
08/04/22 02:24 PM
08/04/22 02:24 PM
Posts: 16,163 Mesa, Arizona
dart4forte
Mesa, Arizona
I use them on my early Hemi
Abe Lincoln
[Re: dart4forte]
#3065200
08/04/22 02:48 PM
08/04/22 02:48 PM
Posts: 43,315 Bend,OR USA
Cab_Burge
I use them on my early Hemi 426 hemi tubes in an early Chrysler Fire Power 331,354 392 C.I.? Please let us know, that could solve a problem in a different way than I would have thought of
[Re: TJP]
#3065232
08/04/22 03:53 PM
08/04/22 03:53 PM
terzmo
Pendleton NY
The dorman's doo look nice. I've been using these GASKET ASST. LINKY And have taken to wrapping the plug threads with teflon tape Shop on the suggested kits if you go that way as the price varies Are we still talking spark plugs or have you shifted to oil plugs? Please tell me you don't teflon wrap spark plugs Sure do, keeps them from making a good ground to the cylinder head and is great for comebacks, then i can upgrade the plug wires and other things back to the drain plug, any chance you have a 12mm x 1.75 bolt n a 1/2x20 opening? I ask as they are close diameter and pitch wise, may mate and tighten but with little thread engagement. In over 50 years I have never encountered a drain plug that kept loosening. Using the plug that came with the pan
[Re: terzmo]
#3065316
08/04/22 09:02 PM
08/04/22 09:02 PM
TJP
Omaha Ne
Using the plug that came with the pan Depending on a number of variables like where the pan and its parts originated from you may have a tolerance stack up issue or poor QC. I would suggest trying a longer GOOD QUALITY 1/2-20 bolt to see how snug or loose it is in the pan threads. If it's too loose you could go to an oversize plug to resolve the issue. I don't like suggesting that but something is not right and it needs to be identified and remedied.
[Re: TJP]
#3065426
08/05/22 10:07 AM
08/05/22 10:07 AM
cudaman1969
fredericksburg,va
Using the plug that came with the pan Depending on a number of variables like where the pan and its parts originated from you may have a tolerance stack up issue or poor QC. I would suggest trying a longer GOOD QUALITY 1/2-20 bolt to see how snug or loose it is in the pan threads. If it's too loose you could go to an oversize plug to resolve the issue. I don't like suggesting that but something is not right and it needs to be identified and remedied. Could be metric threads in the pan or plug, sometimes the two sizes are real close. Just had that problem replacing blade bolts on my finish mower. Thought they were 5/8 “ course but they were 16 mm. If it wasn’t for the nut and bolt guides on top of the bolt cabinet I wouldn’t have noticed the difference.
[Re: cudaman1969]
#3065446
08/05/22 11:17 AM
08/05/22 11:17 AM
TJP
Omaha Ne
Using the plug that came with the pan Depending on a number of variables like where the pan and its parts originated from you may have a tolerance stack up issue or poor QC. I would suggest trying a longer GOOD QUALITY 1/2-20 bolt to see how snug or loose it is in the pan threads. If it's too loose you could go to an oversize plug to resolve the issue. I don't like suggesting that but something is not right and it needs to be identified and remedied. Could be metric threads in the pan or plug, sometimes the two sizes are real close. Just had that problem replacing blade bolts on my finish mower. Thought they were 5/8 “ course but they were 16 mm. If it wasn’t for the nut and bolt guides on top of the bolt cabinet I wouldn’t have noticed the difference. it could be either the plug itself or the threads in the pan or possibly both I have run into this a few times as well along with other QC issues. TO the OP: FYI 20 TPI is real close to 1.25mm TPI which is 20.32 TPI. A 12mm bolt is about .472 and a 12.5mm is .492. the 12.5 is a bit uncommon but available in a bolt. Not sure on the drain plug though.
