HAS ANYONE RESTORED PLASTIC DOOR PANELS? #3062135
07/24/22 03:33 PM
07/24/22 03:33 PM
S.E.Ohio
Magnumguy Offline OP
S.E.Ohio
The style that early E bodies and later B bodies had. That plastic that seems to dissolve over time. Lighter ones are worse?
Has anyone tried to do this? What did you use?
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: HAS ANYONE RESTORED PLASTIC DOOR PANELS? [Re: Magnumguy] #3062186
07/24/22 06:57 PM
07/24/22 06:57 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Once they dry out & start turning to powder, there is NO WAY to restore them. Question is, are there any good reproductions? I do need a set of white ones for my '72 - F&R.
Re: HAS ANYONE RESTORED PLASTIC DOOR PANELS? [Re: Magnumguy] #3062192
07/24/22 07:21 PM
07/24/22 07:21 PM
IMGTX Offline
IMGTX  Offline
There was a compoany that used to do a "restoration" of sorts but it was an obvious fix.
They would sand down the plastic and vacuum form new vinyl to the panel.
It was obvious it was not OEM, but it did look really good. Good enough that anyone who didn't know what OEM looked like up close wouldn't know they were not original. IMHO
EDIT
Just dashes is the company. Thank you TJP for the info.
Re: HAS ANYONE RESTORED PLASTIC DOOR PANELS? [Re: IMGTX] #3062201
07/24/22 08:03 PM
07/24/22 08:03 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Might try just dashes LINKY
Re: HAS ANYONE RESTORED PLASTIC DOOR PANELS? [Re: TJP] #3062285
07/25/22 05:52 AM
07/25/22 05:52 AM
Virginia
larry4406 Online content
larry4406  Online Content
Virginia
From the other site, First link post 67 he discloses the process he used. Second link the OP is still on his journey.
https://forum.e-bodies.org/interior/6/interior-plastic-restoration-journey/18703/
https://forum.e-bodies.org/interior/6/repairing-wasted-door-panels-and-textured-plastic/24815/;topicseen
Re: HAS ANYONE RESTORED PLASTIC DOOR PANELS? [Re: larry4406] #3062291
07/25/22 06:45 AM
07/25/22 06:45 AM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
it depends on what level of restoration you are looking for.
exact copy of the original texture is impossible and nobody has ever done it.
basically the panels are made out of a polypropylene based plastic. epoxy based glue and paint really don't like bonding to this type of plastic without adhesion promoter.
you can get a so so repair by sanding away the chalky part. them apply a adhesion promoter. them give it a coat of epoxy primer. after this dries then give it the proper coating of a textured paint or apply a coat of spray texture then top coat with the proper dye.
perception is 90% of reality
Re: HAS ANYONE RESTORED PLASTIC DOOR PANELS? [Re: TJP] #3062343
07/25/22 10:24 AM
07/25/22 10:24 AM
IMGTX Offline
IMGTX  Offline
Thank you. I had my companies wrong. up
Re: HAS ANYONE RESTORED PLASTIC DOOR PANELS? [Re: IMGTX] #3062542
07/25/22 06:42 PM
07/25/22 06:42 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Weren't there some reproductions that were REALLY NICE though? I'm talking almost exactly like the OE texture & sheen - I have seen them before. I know there have been several efforts to reproduce them from different manufacturers, but only the ones I'm describing looked good enough for me to get interested in, & I'm pretty fussy. I have several sets of good originals (black), but I really don't want to have to revert to dying them white for my '72.
Re: HAS ANYONE RESTORED PLASTIC DOOR PANELS? [Re: Sunroofcuda] #3062552
07/25/22 07:26 PM
07/25/22 07:26 PM
NW Illinois
MoonshineMattK Offline
NW Illinois
Are the ones Year One sells not so good? We installed a set in 2016. They seemed ok back then. That was just a driver quality car.
Re: HAS ANYONE RESTORED PLASTIC DOOR PANELS? [Re: MoonshineMattK] #3062582
07/25/22 09:50 PM
07/25/22 09:50 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
I thought Mancini was carrying the "good" ones??
Re: HAS ANYONE RESTORED PLASTIC DOOR PANELS? [Re: Sunroofcuda] #3062607
07/26/22 06:52 AM
07/26/22 06:52 AM
S.E.Ohio
S.E.Ohio
Nobody is making repo's for late B body door panels, or interior panels.
Re: HAS ANYONE RESTORED PLASTIC DOOR PANELS? [Re: Magnumguy] #3062656
07/26/22 10:47 AM
07/26/22 10:47 AM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
I'm talking about E-Body.
Re: HAS ANYONE RESTORED PLASTIC DOOR PANELS? [Re: Sunroofcuda] #3063136
07/27/22 09:46 PM
07/27/22 09:46 PM
S.E.Ohio
S.E.Ohio
Late B's used the same material.
Re: HAS ANYONE RESTORED PLASTIC DOOR PANELS? [Re: Sunroofcuda] #3063150
07/27/22 10:35 PM
07/27/22 10:35 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
That may be your only course. Since black seemed to survive the best. Of course changing black to white is best wrt coverage..
Re: HAS ANYONE RESTORED PLASTIC DOOR PANELS? [Re: larry4406] #3064076
07/31/22 01:39 PM
07/31/22 01:39 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
Thanks great information Larry. Thanks for sharing that thread. Should work well on a Late B panel as well.
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: HAS ANYONE RESTORED PLASTIC DOOR PANELS? [Re: DynoDave] #3064261
08/01/22 10:26 AM
08/01/22 10:26 AM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
friends of mine are on a budget and restoring an original 60k 74 road runner. white interior and it was pretty chalky and rough. they asked me if i could do anything with the parts (all the plastic in the interior as well as medal a pillar trim and fabric on the panels)
i own a specialty media blasting company so said i would try it. anything too aggressive will destroy the grain obviously so i went with vapor blasting (cabinet based water/ #10 glass bead mix) other than filling my cabinet up with old chalky plastic it worked very well. retained the grain and brought the panels back from the dead. perfect? nope, but very nice for stuff that should have been replaced. Door panel upholstery come out the best looking like a NOS part when finished. (material was in great shape)
if you have anyone local you could have them try vapor. try on the backside first or a spot you cant see once installed to be safe.
i have great luck with mopar plastics and vapor. might be an option
Re: HAS ANYONE RESTORED PLASTIC DOOR PANELS? [Re: chrisf] #3064264
08/01/22 10:32 AM
08/01/22 10:32 AM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
cuda radio bezel. vapor again
