Page 2 of 3 1 2 3
Re: Would this trans line setup pass tech at your track? [Re: CMcAllister] #3056679
07/06/22 01:08 PM
07/06/22 01:08 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Here’s a sample of what is out there and boy is it nice to work with.
https://www.summitracing.com/parts/add-23-1501
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Would this trans line setup pass tech at your track? [Re: CMcAllister] #3061792
07/23/22 09:17 AM
07/23/22 09:17 AM
Loudoun County, VA
Brad_Haak Offline OP
Loudoun County, VA
Quick update that I ordered the necessary fittings and PTFE-lined hose to replace the current rubber trans lines.
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Would this trans line setup pass tech at your track? [Re: Brad_Haak] #3061848
07/23/22 01:18 PM
07/23/22 01:18 PM
Good choice up
I use PTFE lined hose on all my fuel and oil lines no matter the application, works good, last a long time up
Re: Would this trans line setup pass tech at your track? [Re: Cab_Burge] #3061856
07/23/22 01:53 PM
07/23/22 01:53 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Russel and Areoquip love hearing you guys wanting to use their products. Over kill for inadequate mechanics imo
Re: Would this trans line setup pass tech at your track? [Re: cudaman1969] #3061900
07/23/22 05:04 PM
07/23/22 05:04 PM
i had one aftermarket #6AN non PTFE lined hose leak on my old stocker after one years use down
You get to decide what you want to use, just like I do.
Buy it once and don't worry or loose the shop with all the cars and parts in it due to a leaky, CHEAP fuel line:potentially starting a fire in it work shruggy
Re: Would this trans line setup pass tech at your track? [Re: cudaman1969] #3061915
07/23/22 06:50 PM
07/23/22 06:50 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I'm sure Autozone loves hearing from the guys who buy their high end race car components from them too.
Re: Would this trans line setup pass tech at your track? [Re: CMcAllister] #3061943
07/23/22 09:28 PM
07/23/22 09:28 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Racing flex exhaust pipe, Dayblowna AFBs, Stpm, 3/4 cams and many more. Had a friend who worked a parts store back in the day told me he heard this stuff everyday, a running joke.
Re: Would this trans line setup pass tech at your track? [Re: cudaman1969] #3061954
07/23/22 10:30 PM
07/23/22 10:30 PM
AZLIVN
SLO-KID Offline
SLO-KID  Offline
AZLIVN
Iirc this guy learned about leaking tranny lines….
Re: Would this trans line setup pass tech at your track? [Re: SLO-KID] #3061958
07/23/22 10:39 PM
07/23/22 10:39 PM
PA.
"Little"John
"Little"John
PA.
And he’s not the only one. We have a couple of screw hose clamp guys at keystone that have held up a days racing on many occasions. They have 100.00 for weed but not 100.00 for safe leak free transmission lines.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Would this trans line setup pass tech at your track? [Re: cudaman1969] #3061959
07/23/22 10:42 PM
07/23/22 10:42 PM
Loudoun County, VA
Loudoun County, VA
You'll have to excuse me for having a confused reaction to your statement above. Oh, and I purchased Vibrant Performance, Fragola and Summit brand hardware for this upgrade.
Re: Would this trans line setup pass tech at your track? [Re: Brad_Haak] #3062177
07/24/22 06:19 PM
07/24/22 06:19 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
IMO Fragola is the best stuff out there, but that opinion is like asking who's got the best converter. As for the other comment you do what you like with your car, if cheap hose and hose clamps make you feel all warm a cuddly by all means go that way. I dont use PTFE hose personally but just my choice, just like hose clamp guy makes his.
Re: Would this trans line setup pass tech at your track? [Re: Al_Alguire] #3062194
07/24/22 07:33 PM
07/24/22 07:33 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
It’s not cheapy, it’s knowing how to install the most simple thing on any car. If you can’t get a hose clamp on right get out of the kitchen
Re: Would this trans line setup pass tech at your track? [Re: MR_P_BODY] #3062199
07/24/22 07:51 PM
07/24/22 07:51 PM
PA
moparacer Offline
moparacer  Offline
PA
Originally Posted by MR_P_BODY
I have to laugh at a few on here.. they all talk safety but to do a job right they will blow it off... or they
say.. next time.. even if they have never been checked on it
wave
Hope you are not referring to me Mr P.
Only thing not braided on my car are the rad hoses.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Would this trans line setup pass tech at your track? [Re: cudaman1969] #3062229
07/24/22 10:17 PM
07/24/22 10:17 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Thanks for the tips. I'm pretty new at this.
Re: Would this trans line setup pass tech at your track? [Re: Brad_Haak] #3062243
07/25/22 12:16 AM
07/25/22 12:16 AM
PA.
"Little"John
"Little"John
PA.
Just a little fuel line fire. Stuff happens
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Would this trans line setup pass tech at your track? [Re: Brad_Haak] #3062277
07/25/22 02:25 AM
07/25/22 02:25 AM
I remember NHRA saying 6.0 inch long max on all flexible hoses, tranny and fuel.
I haven't race a NHRA legal class car other than a S/P 7:50 certified car, no rubber or neoprene hose lines on it tsk
Re: Would this trans line setup pass tech at your track? [Re: Cab_Burge] #3062400
07/25/22 01:05 PM
07/25/22 01:05 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
That is true of auto parts store rubber crap and hose clamps. The real stuff from any of the manufacturers, using the correct hardware, is good to go for the whole car. SS braid, Aeroquip Startlite, Fragola Nylon Braid, etc.
Fragola is nice stuff, and I believe all or mostly made at their place in Connecticut.
Their nylon braid hose has a single SS braid in it, where the AQP Startlite Nomex braid hose does not. The Fragola is slightly heavier, but both products are substantially lighter than traditional SS braid hose. Also the Fragola hard parts are not quite finished as nice as the Aeroquip stuff...but they also don't cost as much. And the Fragola catalog has a lot more odd and unusual parts that can be helpful.
I use both, but never mix hose and ends between manufacturers. The stuff is different enough that it won't work.
Re: Would this trans line setup pass tech at your track? [Re: CMcAllister] #3062404
07/25/22 01:13 PM
07/25/22 01:13 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Like I said its like asking whos converter is best...Yes Fragola products are 100% USA made..NO reason for me to try anything else..
As for the clamp guy, I spent all my military career in the USAF. Doing wait for it HYDRAULICS on fighter aircraft. Ask me how many hose clamps we used?
Re: Would this trans line setup pass tech at your track? [Re: CMcAllister] #3062411
07/25/22 01:27 PM
07/25/22 01:27 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Re: Would this trans line setup pass tech at your track? [Re: GomangoCuda] #3062419
07/25/22 01:43 PM
07/25/22 01:43 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Wovn pushlock is very good hose...But does not use a hoseclamp boogie
Page 2 of 3 1 2 3
