Pro Charger racers, which type drive? #3054746
06/30/22 06:55 PM
06/30/22 06:55 PM
Cab_Burge Offline OP
I'm thinking of buying and using a Pro Charger F3R-130 for a new build soon, I'm not sure if there is an advantage to using a gear driven version versus a cog belt driven set up help
All comments on your use are and will be appreciated up bow
Thanks in advance: Cab
Re: Pro Charger racers, which type drive? [Re: Cab_Burge] #3054764
06/30/22 07:59 PM
06/30/22 07:59 PM
in the middle
dodger mope Offline
dodger mope  Offline
in the middle
https://thesuperchargerstore.com/
talk to the mopar guys who have done it
Re: Pro Charger racers, which type drive? [Re: Cab_Burge] #3054771
06/30/22 08:24 PM
06/30/22 08:24 PM
VA Beach, VA
Runnoft Offline
Runnoft  Offline
VA Beach, VA
Gear drives are hands down the way to go for racing. I don't know anyone that races a procharged combo with a belt drive that doesn't get tired of constantly dealing with belts. The other advantages are - easier to change drive ratios, less drag than turning a large belt, puts the weight low and forward (at least for radial racing), and the blower inlet is front facing usually without any obstructions so good, clean and cool air. Two disadvantages - initial cost and packaging. You'll need to get creative with radiator location.
Cruiser: 66 Dodge Coronet 500, Indy SR 440, Gen 7 Accel EFI = 11.38 @ 116.
Racing: Brand X, X275 Procharged Smallblock on M1, Leafsprings, Holley EFI = 4.30 @ 168
Re: Pro Charger racers, which type drive? [Re: Runnoft] #3054867
07/01/22 08:57 AM
07/01/22 08:57 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Get ready to spend 10 grand. For a drive and head unit combo.
Re: Pro Charger racers, which type drive? [Re: Runnoft] #3054899
07/01/22 11:18 AM
07/01/22 11:18 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
iagree A guy I know runs (I think) a cogged F2 side mount, he will just go home if he throws the belt at the track. Due to the tight constraints in the engine bay it takes him 4 -5 hours to replace a belt. He's running in a street class which means treads, if the engine revs up when the tyres spin and he lifts, it throws the belt. It happens a lot unfortunately. I'd run a gear drive and work out how fit stuff around it if I was going to use a Procharger.
Re: Pro Charger racers, which type drive? [Re: Tig] #3055099
07/01/22 11:33 PM
07/01/22 11:33 PM
montana
BANDIT Offline
BANDIT  Offline
montana
Even with the front gear drive, changing gear ratios isn't all that easier. I've worked on both. just got done switching ratios in a gear driven dragster. Had to pull engine in order to change gears, not a real big deal on dragster, could be more involved on a door car. The belt drives that I have worked on were dragsters as well, was really easy as long as you weren't making a big change, just loosen belt and change upper pulley. They do throw belts at most inappropriate times. There are also different versions of front mounts, as was mentioned earlier. Good luck, they are fun to drive! Jim.
64 Dodge Coronet 440. In progress
1998. Dodge Avenger. 8.35@165. 4400 DA
250” Neil and Parks Slip Joint. 7.36@183.
4600 DA
242" Mullis Dragster. 6.90@ 200mph
Re: Pro Charger racers, which type drive? [Re: Cab_Burge] #3056633
07/06/22 12:18 PM
07/06/22 12:18 PM
MI
Jeff440sc Offline
Jeff440sc  Offline
MI
Should you be concerned about harmonics with a gear drive verse a belt ? Was told that a Jesel belt drive is much better because its absorbing harmonics instead of creating them in regards to your cam drive . I imagine that gear drive sticking way out on the crank is going to put some harmonics through the engine. ..Someone that has seen the effects maybe can chime in if the harmonics are something to consider with these Pro-charger set ups.
Re: Pro Charger racers, which type drive? [Re: Jeff440sc] #3056644
07/06/22 12:32 PM
07/06/22 12:32 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
IMO either work well to a point. Obviously with a side slinger you have a belt to deal with. But usually packaging is simpler and as noted any needed changes are made easier. My only experience is with drasgter using them as well
Re: Pro Charger racers, which type drive? [Re: Jeff440sc] #3056775
07/06/22 03:34 PM
07/06/22 03:34 PM
I'm going to use one of the Jesel belt drives I have on this motor up
As far as harmonics in the drive I am a lot more worried about the internal drive harmonics rotating the compressor in or at 72,000 RPM.
I am planning on shifting the motor before 8000 RPM and gear the Procharger for less than 30 Lbs. of boost at or above 7000 RPM work luck
I have a lot of learning to accomplish to get good on tuning a Pro Charger motor luck wrench shruggy
Re: Pro Charger racers, which type drive? [Re: Cab_Burge] #3057037
07/07/22 09:01 AM
07/07/22 09:01 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Every serious racer that I know of using a Procharger uses a gear drive.
Re: Pro Charger racers, which type drive? [Re: BobR] #3057154
07/07/22 02:01 PM
07/07/22 02:01 PM
I was a dealer for Chris Alston Chassis until they got bought out by Heidt suspension and they now don't offer the crank drives that Alston use to make whiney
I'm sure you, Jason and Doug are a lot more knowledgeable on Pro Chargers and how to use them than I will learn by myself, maybe I should call them work
Re: Pro Charger racers, which type drive? [Re: Cab_Burge] #3057171
07/07/22 02:33 PM
07/07/22 02:33 PM
Sidney,Ohio
challenger1320 Offline
Sidney,Ohio
Indy Cylinder Heads has the complete package already worked out for the race drive setup. Everything from the motor plate to the carb all you need is the charge tube. We put one on a 540 -1 motor in a dragster and the only change we had to make was taking a little jet out of the carb. Best so far is 4.13 at 176. F3R 112 with the 136 gear set.
Re: Pro Charger racers, which type drive? [Re: Cab_Burge] #3061363
07/21/22 02:23 PM
07/21/22 02:23 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
We got our drives from the Supercharger Store.
Re: Pro Charger racers, which type drive? [Re: BobR] #3061373
07/21/22 02:36 PM
07/21/22 02:36 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Indy has been doing a ton of work on ProCharged Mopar stuff the last few years. As Challenger mentioned they have alot of those parts out there for BB, Hemi and Predator stuff.
Re: Pro Charger racers, which type drive? [Re: Cab_Burge] #3061458
07/21/22 05:30 PM
07/21/22 05:30 PM
I found out from Vortech that Chrsi Alston Chassis works is still in business shock shruggy
Part of their original business got sold to Heidt, not all of it upboogie
Now which brand and size to choose and use work
More to come soon luck
