72 Duster hood scoops ? #3060542
07/19/22 12:30 PM
07/19/22 12:30 PM
Ontario Canada
Bennoel 10 Offline OP
Ontario Canada
My question is this....was a hood scoop option available on a 1972 340 Duster ?? I've been under the impression that no 340 Duster came from the factory with any kind of hood scoop. Only available on a Duster Twister. Since we all remember seeing examples back in the day I started to believe it was available and maybe some were dealer installed before delivery ??
Thanks in advance for any and all input.
Re: 72 Duster hood scoops ? [Re: Bennoel 10] #3060575
07/19/22 02:01 PM
07/19/22 02:01 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Lots of incorrect scoops have been put on Dusters either by the dealer or owner. The dual snorkle scoop did not come on any Duster. The Twin scoops only came on Twisters. No scoops came on any year 340 Duster. Who cares? Unless you are going for an absolute original restoration, do what you will like the most. Most people won't know or care if it is wrong.
Edit: I would not consider it 100% impossible for a 340 Duster to get a wrong hood treatment while going down the assembly line. You never know. If it did it would not be on the window sticker, build sheet or fender tag so impossible to document.
If a cash customer came to the dealer and said I want that 340 Duster but I want the hood from that same color Twister next to it you can bet that in about half an hour there would have been a 340 Duster with scoops and a Twister with a flat hood. laugh2
Re: 72 Duster hood scoops ? [Re: GomangoCuda] #3060578
07/19/22 02:11 PM
07/19/22 02:11 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
Everything I have ever read says the only Dusters with twin scoops are the Twisters, and Twisters didn't come with a 340.
Were there exceptions that came from the factory that way? I doubt it but maybe.
Were there dealer-installed scoops/hoods set up that way? Probably.
Were most of them put on later by owners? That's my opinion. But the well-done ones really look like they belong there so they relay look like they could be factory. And MANY owners decided to add them after-the fact.
Re: 72 Duster hood scoops ? [Re: Bennoel 10] #3060795
07/20/22 05:17 AM
07/20/22 05:17 AM
Ontario Canada
Ontario Canada
Well that clears that question up
Thanks for the info
Bennoel
Re: 72 Duster hood scoops ? [Re: Bennoel 10] #3060809
07/20/22 07:56 AM
07/20/22 07:56 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I have a 72 Twister sitting out in my lot, /6-3 speed on floor and 8-3/4. NO scoops were ever on that hood, black strobe stripe on orange hood,
Re: 72 Duster hood scoops ? [Re: cudaman1969] #3061048
07/20/22 06:01 PM
07/20/22 06:01 PM
CA
crackedback Offline
crackedback  Offline
CA
Originally Posted by cudaman1969
I have a 72 Twister sitting out in my lot, /6-3 peed on floor and 8-3/4. NO scoops were ever on that hood, black strobe stripe on orange hood,
Scoops were an option on twisters, hood treatment standard.
Re: 72 Duster hood scoops ? [Re: crackedback] #3061316
07/21/22 12:38 PM
07/21/22 12:38 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
The reason I posted what I did, one of the upper posts was a little vague saying Twisters have them, it was an option on them like you said.
