small block X head rocker parts #3061032
07/20/22 05:22 PM
07/20/22 05:22 PM
WI
mopar873 Offline OP
mopar873  Offline OP
WI
I posted this in the parts forum as well, but wanted to post here for more exposure. Looking for a set of rocker stands for stock 340 X heads. Would also consider a full shaft set up with rockers if available.
Thanks!
Re: small block X head rocker parts [Re: mopar873] #3061044
07/20/22 05:47 PM
07/20/22 05:47 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Quote
When I hear “X heads” I think of SB heads number 2531894. 340 heads.......which would have the rocker stand cast into the head.
Re: small block X head rocker parts [Re: fast68plymouth] #3061075
07/20/22 08:15 PM
07/20/22 08:15 PM
Originally Posted by fast68plymouth
Quote
iagree scope
Re: small block X head rocker parts [Re: Cab_Burge] #3061236
07/21/22 08:49 AM
07/21/22 08:49 AM
WI
mopar873 Offline OP
mopar873  Offline OP
WI
I misspoke, its the shaft hold-down kit I'm looking for. This engine didn't come with rocker arms either... and the shafts don't look all that great, so I might be in the search for a whole top end kit.
Re: small block X head rocker parts [Re: mopar873] #3061370
07/21/22 02:34 PM
07/21/22 02:34 PM
Georgia and Washington
JMCarter Offline
JMCarter  Offline
I have a set of Precision rockers with shafts that have never been bolted on an engine. The rockers are bushed to use small shafts, they were the hot setup on stock eliminator small blocks before NHRA permitted roller tip rocker arms. Message for pics and/or questions.
