426 hemi spark plug tube o-rings seals #3060642
07/19/22 05:43 PM
07/19/22 05:43 PM
saint paul mn.
johnzgarage Offline OP
saint paul mn.
Will the rubber o-ring tube seals from a 6 cyl work on on a gen2 hemi ? The M.P. o-rings fit like %$#! . Has anyone tried ? BTW i know i can get the right fitting O-rings from Arruzza.[img]20220719_163416[/img]
Re: 426 hemi spark plug tube o-rings seals [Re: johnzgarage] #3060666
07/19/22 07:00 PM
07/19/22 07:00 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
What trouble are you having?
I have the mp o-rings and stamped steel covers. No problems. (I oil the o-ring)
Re: 426 hemi spark plug tube o-rings seals [Re: INTMD8] #3060678
07/19/22 08:06 PM
07/19/22 08:06 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Yes, as you have found out, the O-rings Mopar has been selling us for the 20 years are waaay too big. If you want, you can take a plug tube down to an industrial supply house and see if they have something smaller. They actually do fit the Ansen cast aluminum valve covers that Mopar sold for the last 5 minutes before they cut us off again but that doesn't make it right that they sold us that crap for 20 years. And they don't sell any breathers for the Ansen valve covers either.
2011 Drag Pak Challenger
Re: 426 hemi spark plug tube o-rings seals [Re: INTMD8] #3060697
07/19/22 08:56 PM
07/19/22 08:56 PM
New York
64 Sportfury Offline
New York
Are you using spark plug washers or do you remove them?
Thanks.
Re: 426 hemi spark plug tube o-rings seals [Re: 64 Sportfury] #3060718
07/19/22 09:26 PM
07/19/22 09:26 PM
saint paul mn.
saint paul mn.
no, not with tubes. I just would like to know if anyone tried 6cyl o-rings.
Re: 426 hemi spark plug tube o-rings seals [Re: johnzgarage] #3060739
07/19/22 11:09 PM
07/19/22 11:09 PM
Mopar had two different type spark plug tube and seals in the 426 street hemi. I think the 1966 and 1967 were the same and the 1968 to 1971 were the better ones scope
Re: 426 hemi spark plug tube o-rings seals [Re: Cab_Burge] #3060741
07/19/22 11:16 PM
07/19/22 11:16 PM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
It’s been awhile but I did try the /6 and they seemed to fit ok iirr.
Re: 426 hemi spark plug tube o-rings seals [Re: cudaman1969] #3060746
07/19/22 11:41 PM
07/19/22 11:41 PM
saint paul mn.
saint paul mn.
O.K. Thanks !
Re: 426 hemi spark plug tube o-rings seals [Re: INTMD8] #3060843
07/20/22 09:56 AM
07/20/22 09:56 AM
S.E. Michigan
ZIPPY Online content
ZIPPY  Online Content
S.E. Michigan
Same.
Rich H.
Esse Quam Videri
