2005 Dodge Ram rough idle #3056801
07/06/22 04:39 PM
07/06/22 04:39 PM
Lee Co. Fla.
5carguy Offline OP
5carguy  Offline OP
Lee Co. Fla.
Truck has about 100,000 miles engine is a 4.7..Engine light came on,code was #2 cyl. faulty spark plug,coil or fuel injector.Has a rough idle.Changed all three and still the same.Compression test was 120lb.Anyone know what's wrong?Any advice?As always, TIA
Re: 2005 Dodge Ram rough idle [Re: 5carguy] #3056883
07/06/22 08:42 PM
07/06/22 08:42 PM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
Not much stuff good with a 100K miles on a 4.7.
Start by pulling the valve covers and make sure all the lifters are still in place and functioning correctly.
Then is probably time to replace the plastic timing chain guides. The worn guides allow the timing chains to flop around and can change the valve timing by a few degrees.
Hopefully it has not been overheated and blown a head gasket, or wiped out the bearings on the crank.
Re: 2005 Dodge Ram rough idle [Re: poorboy] #3058764
07/13/22 03:30 AM
07/13/22 03:30 AM
lyon
fdax Offline
fdax  Offline
lyon
Our 2005 Dodge Ram 1500 with the 5.7 Hemi had a bad seal on the EGR tube. It was leaking on the intake end on the EGR tube.. New seal and all working again as it should.
snaptube vidmate
Re: 2005 Dodge Ram rough idle [Re: fdax] #3060000
07/17/22 05:37 PM
07/17/22 05:37 PM
Lee Co. Fla.
5carguy Offline OP
5carguy  Offline OP
Lee Co. Fla.
Sprayed choke cleaner all around engine to try to find a vacuum leak.No change.This is a tough one.Any more ideas?
Re: 2005 Dodge Ram rough idle [Re: 5carguy] #3060031
07/17/22 08:42 PM
07/17/22 08:42 PM
Freeport IL USA
Freeport IL USA
Did you pull the valve covers?
