Re: Help design a driver accessible master power cutoff! [Re: Cab_Burge] #3059435
07/15/22 02:43 PM
07/15/22 02:43 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Originally Posted by Cab_Burge
The older Mr. Gasket and Moroso battery cutoff switches weren't rated very high on much current they can safely handle, I wore one out and learned that they are rated less than 100 amps puke
There are better ones available, I bought one rated at 250 Amps and it worked great so can you find one to buy when you do a search scope
Sorry for no links or company names: blush:
The Moroso 74100 is no good. 20A continuous, 125A surge. The 74101 is the one to use, 175A continuous, 1000A surge,
Make sure the switch has silver contacts, which I believe the 74101 does. The Littelfuse/Cole Hersee 2484-16 is also a silver contact switch and is 175A rated continuous and intermittence rated 800A at 6VDC-36VDC, 15 On, 5 Minutes Off. Probably the one Moroso sells as the 74101.
Re: Help design a driver accessible master power cutoff! [Re: CMcAllister] #3059448
07/15/22 03:32 PM
07/15/22 03:32 PM
NC
440Jim Offline
440Jim  Offline
NC
These seem reasonably priced. A 43BC morse cable 6ft about $78.
A 30 series Morse cable has #10-32 ends
A 40 series Morse cable has 1/4-28 ends.
https://www.go2marine.com/Pro-X-43BC-Replacement-Control-Cables?quantity=1&length=1499
Re: Help design a driver accessible master power cutoff! [Re: 440Jim] #3059616
07/16/22 09:16 AM
07/16/22 09:16 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
That's what i was thinking...as long as the mechanism out the back is 5/16 were good. I was just wondering if anyone got questioned over it.
Re: Help design a driver accessible master power cutoff! [Re: gregsdart] #3059627
07/16/22 10:18 AM
07/16/22 10:18 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Some people have used an air/CO2 with a Bimba cylinder to launch the parachute and that could also be connected to the shutoff turning it off at the same time.I will stick with the Ford relay and button to cut power and the main thing is to have it in a good place to de activate the power.
Re: Help design a driver accessible master power cutoff! [Re: Clanton] #3059649
07/16/22 11:51 AM
07/16/22 11:51 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Damn, you guys have me considering adding one inside my car now. I have also done the dreaded sit down, strap in , hit the ignition switch and nothing.... have to unstrap , get out, turn it on at the rear and try again. lol.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Help design a driver accessible master power cutoff! [Re: 6PKRTSE] #3059669
07/16/22 01:21 PM
07/16/22 01:21 PM
The only time I would normally turn off the rear battery shut off switch was in the winter when the car sat in the trailer from October to April shruggy
Re: Help design a driver accessible master power cutoff! [Re: Cab_Burge] #3059687
07/16/22 03:31 PM
07/16/22 03:31 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Ford starter relays are for intermittent duty use. Solenoids used for a battery disconnect, that also carry the load of the car while running, need to be for constant duty use. They may look the same but they are not the same.
We use constant duty solenoids for control of "ignition on" circuits, typically 80 -100A rated, but they aren't designed to carry the in rush of a starter motor.
There are battery disconnectors/solenoids/relays made for this and designed to carry higher amperage and be in constant duty use.. But you can't buy them at an auto parts for $15.
250A continuous, intermittent well over 1000A
Re: Help design a driver accessible master power cutoff! [Re: CMcAllister] #3059702
07/16/22 04:54 PM
07/16/22 04:54 PM
gregsdart Offline OP
Thanks for correcting my miss information! ,🙄👍
There might be motorhome solenoids with high enough ratings, if that is what a guy wants to use. Overall it might be a lighter system by a bit.
Re: Help design a driver accessible master power cutoff! [Re: gregsdart] #3059942
07/17/22 02:43 PM
07/17/22 02:43 PM
moparx Offline
moparx  Offline
CM, i couldn't make out the complete tag on the solenoid you showed.
any chance you have a pic that shows the whole tag ? [TIA !]
beer
Re: Help design a driver accessible master power cutoff! [Re: Clanton] #3060671
07/19/22 07:24 PM
07/19/22 07:24 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I got the push switch from amazon and it is well made,no slop and I was thinking of mounting it on my shifter[PPP]
