Re: Carb series ? help
[Re: terzmo]
#3060662
07/19/22 06:42 PM
07/19/22 06:42 PM
Posts: 43,292 Bend,OR USA
Cab_Burge
All things that ran good at one time can be fix to run good again, the hard part is figuring out what wore out or went bad to cause the repair issue You can fix it, don't GIVE UP You can fix it
[Re: terzmo]
#3060675
07/19/22 07:57 PM
07/19/22 07:57 PM
Posts: 3,247 Md.
carnut68
Md.
the throttle shaft was loose when getting to the shop. 23 mile run. Took the carb off and put a race base plate on it (only thing available) and the carb ran at 2000rpm and stalled at 1800. definetely not good. looked at the original base after about an hour and the throttle shaft was solid as concrete. Explains why it stalls after getting to temp. The race base wouldn't work so I have the original back on to get home. Looking to get a new carb as why throw money into parts for a 27 year old carb that has seen better days The Quick Fuel Brawler carbs are nice for the money. The only thing bad is the IFR is in the top position and the T slot needs restrictors. Everything else is tuneable even the pvcr is threaded with small jets.
America First!
[Re: Checker]
#3082412
10/02/22 07:51 AM
10/02/22 07:51 AM
Posts: 2,060 Pendleton NY
terzmo
Pendleton NY
OK...I'm back as terzmo and Checker is temporarily sidelined. Thanks again for all the input
"That also doesn't make sense as the car should have kept running off the battery "confused shruggy I can only assume by interrupting the voltage or running a negitive charge because of loose belt, the ECU would shut down at idle speed.( I have seen meters go to the negitive side at low idles) Electronics have an operating input and output threshold . All's I know is after doing all the other changes, nothing fixed it. Even by shorting the alt and burning wires, the alt checked good at a long time experienced electric shop. ( I was shocked it checked good and still putting out 108 amp-s plus) I have taken the car out about 5 times on decent rides and it has yet to quit.
[Re: terzmo]
#3082468
10/02/22 12:39 PM
10/02/22 12:39 PM
Posts: 15,498 Omaha Ne
TJP
Omaha Ne
"That also doesn't make sense as the car should have kept running off the battery "confused shruggy I can only assume by interrupting the voltage or running a negitive charge because of loose belt, the ECU would shut down at idle speed.( I have seen meters go to the negitive side at low idles) Electronics have an operating input and output threshold . All's I know is after doing all the other changes, nothing fixed it. Even by shorting the alt and burning wires, the alt checked good at a long time experienced electric shop. ( I was shocked it checked good and still putting out 108 amp-s plus) I have taken the car out about 5 times on decent rides and it has yet to quit. Strange??? Welcome to the world electronics. one would have to have a complete accurate schematic to figure this one out as in theory it should have run off the battery unless it was too low. But then it wouldn't have started again. Almost sounds like the ignition is getting it's power from the Alt. thanks for the feedback
[Re: TJP]
#3083330
10/04/22 06:27 PM
10/04/22 06:27 PM
Posts: 19,595 north of coder
moparx
1955 work as well ? https://www.ebay.com/itm/115491061377?hash=item1ae3cdbe81:g:FHwAAOSwNNli9E3t&amdata=enc%3AAQAHAAAAsKk1sDtPwSGytc%2F76Kq0P4RzO9xPwi03NWCaOzvGf6Ho%2Fka7Ud8vyX2%2B8LOsjWNDkWXp6VVNLiCqyteYoPKwIZ3c0OGyW2UZ6i36BccALXZ0FE0Ck8qjunEvpE3V%2FdiIrRrMJOgh7Y2yJlS5evQBShDkVUcCnThHlHDodOF%2BqRJSmHAUERgCtH9H1xmH1v5tIJcIqw%2BMtZHRChTQpmA4O8vuNw6mcK6%2F%2BNVHJMh%2FO7Fs%7Ctkp%3ABk9SR-Dc1pnzYA
another one listed on same page but scroll down further https://www.ebay.com/itm/115491061377?this better ? well, no, it ain't............. that link is to a ferd truck [?] script badge.......
Last edited by moparx; 10/04/22 06:31 PM. Reason: didn't check link to see what it was before posting !
