Re: Where can I find torsion bar specifications?
[Re: Remy-Z]
#3059246
07/14/22 04:40 PM
07/14/22 04:40 PM
Posts: 6,278 nowhere
Sniper
nowhere
[Re: Sniper]
#3059361
07/15/22 09:25 AM
07/15/22 09:25 AM
Posts: 4,427 Michigan
MarkZ
Worthy
Worthy
Remy, what are you working on and what are the goals?
[Re: moparx]
#3059433
07/15/22 02:41 PM
07/15/22 02:41 PM
Posts: 27,468 So Cal
autoxcuda
So Cal
your car looks good with those wheels ! I agree. What make model rims are those? Very cool. Like your paint choice with them, nicely executed.
[Re: Remy-Z]
#3059472
07/15/22 05:18 PM
07/15/22 05:18 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
Nice lookin' Cordoba!
I'd suggest anything that's available from Firm Feel (bushings, etc), but, perhaps the easiest and best bang-for-the-buck would be a set (front and rear) of DOUBLE-ADJUSTABLE shocks.
I've recently installed a set of Viking Double-adjustables (new Biserker models)... and eventually played with the adjustment knobs (while at a high-speed road course track, as well as a local pylon autocross event)... and WOW... you can really make QUICK adjustments with an absolute improvement in ride and handling!... only takes ~one-minute per shock These have replaced my old RED-D KONI shocks (great old shocks, best at the time ~40 years ago), but... having to remove and compress to adjust is a hassle... and very time consuming.
You can also get QA-1 double adjustable shocks... but definitely... as I'm suggesting... get the DOUBLE-ADJUSTABLE versions from your choice of shock company... you won't regret it with the amazing availability of ride/comfort/handling adjustment. I suggest trying different extremes... full soft, middle, full stiff... lots of variables... and you can quickly and easily change the settings per your day of driving.
I don't believe there's much you can get for your car, other than replacing the bushings from FF. Also, I believe Richard E'Berg recently wrote about the bushing replacements for these cars in Mopar Action magazine (one or two latest issues?).
Also, learn to play with and adjust your tire PSIs (front and rear)... per your ride comfort and common travel routes.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: Mopar Mitch]
#3059557
07/15/22 11:14 PM
07/15/22 11:14 PM
MarkZ
Worthy
Worthy
That car looks amazing Remy. I'm going to start with budget minded upgrades first: - frame ties
- front and rear sway bars
- shimming the power steering pressure valve
- five leaf rear springs
- Bilstein shocks
- Rear ISO delete
The above will get you interstate capable that feels more modern without breaking the bank. I can't recommend ties enough. The amount of flex in the unibody is crazy. Difference in normal driving and lane changes at speed will be night and day. Don't go overboard...ties that are welded to the front and rear rails are enough. No need to go through the floor with something like this. I don't think it's necessary to go with adjustable shocks at this level unless you can get a set for a reasonable amount of money. More pricey: - Torsion bars
- Borgeson steering box
- adjustable shocks
Don't be afraid of high rate torsion bars. 300# bars ride fine with enough sidewall. A 235-60-15 BFG on the front works great with this. Higher rate bars though require better shocks, so it does get pricey. I would start on the cheap list and evaluate as you go. For an expressway cruiser the top list would probably make you happy.
[Re: autoxcuda]
#3064978
08/03/22 04:44 PM
08/03/22 04:44 PM
Posts: 4,177 here.
Remy-Z
here.
your car looks good with those wheels ! I agree. What make model rims are those? Very cool. Like your paint choice with them, nicely executed. Halibrand Sprint 15-inch in Anthracite. 15x7 front, 15x10 rear. CLICK HERE to check the whole line out.
[Re: 71birdJ68]
#3064981
08/03/22 04:48 PM
08/03/22 04:48 PM
Posts: 4,177 here.
Remy-Z
here.
Interstate capable? We drove these cars 75/80 mph all day long back then and didn't even know what a overdrive was. Replacing all of the rubber suspension parts would be the biggest improvement, but then again the rubber stuff available today is garbage. This one has seen 70-75 MPH already...and surprisingly, turned 20 MPG in the process! The long-range goal is some kind of overdrive (manual trans is not out of the question) in a car that I can drive anywhere in the lower 48 without fear, but that's also in line with a healthy power bump for the 360. The Charger tracks pretty solid as-is, but I know the subframe mounts are beyond shot and that the shocks need to be replaced. I'll take a look at the double-adjustable stuff, I've got friends who have Viking and QA1 connections for the moment.
[Re: poorboy]
#3065138
08/04/22 11:46 AM
08/04/22 11:46 AM
Posts: 4,177 here.
Remy-Z
here.
Installing higher grade shocks and leaving the wore out rubber in the suspension, and leaving the rubber mounts in the K member and the rubber around the leaf spring mounts just doesn't make much sense to me, but its not my money your spending. I have no intention of leaving in garbage-grade rubber. But I also need to keep the car from bottoming out on the road from my house into town. This car is driven...like "any day it ain't raining daily" driven. It's a Cordoba with sporting aspirations, not a Hemi Coronet.
[Re: Remy-Z]
#3065305
08/04/22 08:34 PM
08/04/22 08:34 PM
Posts: 10,585 Freeport IL USA
poorboy
Freeport IL USA
Installing higher grade shocks and leaving the wore out rubber in the suspension, and leaving the rubber mounts in the K member and the rubber around the leaf spring mounts just doesn't make much sense to me, but its not my money your spending. I have no intention of leaving in garbage-grade rubber. But I also need to keep the car from bottoming out on the road from my house into town. This car is driven...like "any day it ain't raining daily" driven. It's a Cordoba with sporting aspirations, not a Hemi Coronet. Shocks are intended to reduce or eliminate bounce from the suspension, they are not intended to raise the vehicle (unless they are air shocks). If your car is bottoming out, jack up the front end, and use the adjusting screw to put more tension on the torsion bars. If the car sits too high for your taste after the adjustment, larger diameter torsion bars are in your future. I have owned a lot of that era Mopar cars back in the day. Suspension bottoming out was just a torsion bar adjustment, that was why the bars were adjustable. Two full rounds ( got to start some where may need more, or less) on each of the adjusting bolts will make a huge difference on ride quality, and only takes a few minutes of time and no money. Don't judge the ride height until after you have driven the car, it will settle down after being driven a few miles. If its still bottoms out after adjusting the torsion bars, you really need to look at the rear springs and the spring hangers. Here in the rust belt, I've replaced many rear spring shackle frame mounting points. They had a bad habit of sleazing the bushing, and start twisting the steel sleeve in the frame mount until it started ripping out. Gene
[Re: stumpy]
#3065492
08/05/22 02:15 PM
08/05/22 02:15 PM
Posts: 2,468 Answering the call of the wild
ThermoQuad
Engine cradle on steel Proper alignment These cars are rigid, don't bother with frame ties Torsion bar mount on poly bushing Rear sway bar 73-up b body in poly, bolts in Front sway bar from a cop car if you cant find in poly bushings Remove rear iso, convert lower shock plates to the std set up we are used to so you can use real shocks Shocks on the front are a challenge Use a 70's chevy mailbu performance shock and change the lower insert for mopar. tight fit!!! Cop car torsion bars if u can find them look in the parts book, mopar performance chassis manual to understand what u are looking for 15x8 or 16x8 with appropriate tires 26” tall 2.94 rear 2500 stall converter, trans cooler, atf 4 mopar Remember I know nothing even after flogging this stuff around the road course....lol ps cooler, synthetic fluids etc. You are on your own now, tech support is closed
