Electronics box #3058024
07/10/22 05:50 PM
07/10/22 05:50 PM
North Tonawanda
Checker Offline OP
Checker  Offline OP
North Tonawanda
Is it ok to swap an orange electronics box with a blue or silver. All have the same pin configuration. Thanks moparts...thanks to all in advance
Re: Electronics box [Re: Checker] #3058035
07/10/22 07:03 PM
07/10/22 07:03 PM
S.E.Ohio
Magnumguy Offline
Magnumguy  Offline
S.E.Ohio
I have, as I've done several leanburn to E.I. conversions. I think it depends on manufacturer.
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: Electronics box [Re: Checker] #3058057
07/10/22 08:58 PM
07/10/22 08:58 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
I think some of the aftermarket boxes from Standard Motor were blue or silver.. But as long as they have the (4) pin connector U should be fine.
However note that I have found that certain ignition boxes have more latency than others so I would recommend that after installing double check the ignition timing.
Just my $0.02... wink
Re: Electronics box [Re: Sinitro] #3058607
07/12/22 03:09 PM
07/12/22 03:09 PM
moparx Offline
moparx  Offline
as i am aware, most if not all, 4 pin boxes will work.
but as has been mentioned, check your timing, as some boxes can retard timing more than you think.
i don't remember any box that advanced timing, although it may be possible ? shruggy
beer
Re: Electronics box [Re: moparx] #3058667
07/12/22 07:14 PM
07/12/22 07:14 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
beer
If you replcaced a box that retarded a lot with one that retarded less the end result would be advanced timing
