Assembly Lubricant #3057704
07/09/22 04:03 PM
07/09/22 04:03 PM
North Dakota
6PakBee Offline OP
6PakBee  Offline OP
North Dakota
I've always used Lubriplate 105 as an assembly lube. But I bought a tub of this stuff for an automatic transmission and the label says it's good for engine assembly also. From first impressions I like it better than the 105 as it seems to be 'stickier" and yet just a slippery. Has anyone tried this for an engine assembly?
Green Goo
Re: Assembly Lubricant [Re: 6PakBee] #3057711
07/09/22 04:39 PM
07/09/22 04:39 PM
Does your tranny or motor run on this stuff?
If not, why not use the lubricant it uses to assemble them work
I do, motor oil in the engine's bearings and crankshafts, oil on the piston skirts and rings cam lube on flat tappet cams and lifters upscope
I use the proper ATF in the tranny to assemble them also: wrench:
I do prime the oil pump with the spark plugs out and spin the motor over several times on the starter while priming it before firing all my new motors wrench up
Re: Assembly Lubricant [Re: Cab_Burge] #3057732
07/09/22 06:24 PM
07/09/22 06:24 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
GM EOS. The old stuff. For bearings and valve train.. I've even used it in transmissions. Oil on pistons and rings, sparingly. Not dunking them in oil. Pre-lube well before start up with an oil pump driver.
