Axle hop!! #3056468
07/05/22 08:04 PM
07/05/22 08:04 PM
houston texas
gremlinsteve Offline OP
houston texas
Now that I’m used to driving the truck my first attempt at wot
Showed me horrible wheel hop
The 383 magnum really comes on strong enough that it’s plain
Horrible
I need to fix this issue asap. I’m thinking of adding clamps to the fron halves
Kinda the way I was taught how to help in this situation years ago
But this one’s bad enough I dunno
Any one have any idea on what I should start off doing? Measure pinion angle? Ect?
if You Like Gremlinsteve. Gremlinsteve Likes You.
Re: Axle hop!! [Re: gremlinsteve] #3056611
07/06/22 10:48 AM
07/06/22 10:48 AM
moparx Offline
moparx  Offline
start with clamping the front spring segments. that will help a lot.
you could then try a simple set of slapper bars, provided you could find a set long enough that the snubber hits the front spring eye. i don't know what the spring segment lengths are on a pickup.
better rear shocks would help as well, but then again, i am not familiar enough with trucks to offer suggestions on what to use. you may be topping out on the shock now [shock too short] causing the wheel hop.
just things off the top of my head from afar.
maybe others can chime in with ideas.
in the meantime, here's a bump.
beer
Re: Axle hop!! [Re: gremlinsteve] #3057590
07/09/22 05:27 AM
07/09/22 05:27 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
New springs. Everything else is a band-aid fix.
** I went back through your other thread. Show us how your truck was lowered, maybe there's something there. twocents
Re: Axle hop!! [Re: redraptor] #3057613
07/09/22 08:54 AM
07/09/22 08:54 AM
San Diego
JP8 Offline
JP8  Offline
San Diego
I agree. Was your trucks rear lowered with an axle flip or with extended shackles and raised mount?
Instagram : @5_points_racing
Re: Axle hop!! [Re: JP8] #3057621
07/09/22 09:47 AM
07/09/22 09:47 AM
houston texas
houston texas
The rear was lowered via axle flip
Re: Axle hop!! [Re: gremlinsteve] #3057804
07/09/22 09:25 PM
07/09/22 09:25 PM
houston texas
houston texas
Added three clamps on each forward half of the springs and some Lakewood reaction bars
Seems to have worked
Re: Axle hop!! [Re: gremlinsteve] #3057971
07/10/22 11:57 AM
07/10/22 11:57 AM
moparx Offline
moparx  Offline
glad you got it fixed ! up
beer
Re: Axle hop!! [Re: moparx] #3060906
07/20/22 10:57 AM
07/20/22 10:57 AM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
Exactly what I did on my 92 D150 .. clamped the front spring sections , added a set of swap meet traction bars ( Lakewood I believe ) and a pair of B body Rancho adjustable shocks .. works great !
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: Axle hop!! [Re: 11secdart] #3060912
07/20/22 11:10 AM
07/20/22 11:10 AM
houston texas
houston texas
Yes it does
Re: Axle hop!! [Re: gremlinsteve] #3061036
07/20/22 04:31 PM
07/20/22 04:31 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
Drag radials help also !
68 Dart 410 / 904
23 Audi Q5
16 Honda HRV
