Cheapest way to get a new key/fob for a 2017 ram #3056229
07/05/22 12:40 PM
07/05/22 12:40 PM
Minnesota
Hemi_Joel Offline OP
Minnesota
My 2017 ram came with two keys. But they're not really a key. It's an electronic fob. You don't even stick it in a hole in the dash to start the truck. You just have to have it in your pocket and press a button on the dash. My wife lost one of them.
I hate going to the dealership and getting robbed.
What is the cheapest place / way to get a replacement key?
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Cheapest way to get a new key/fob for a 2017 ram [Re: Hemi_Joel] #3056236
07/05/22 12:47 PM
07/05/22 12:47 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
I'd check the dealer price first. With all the cheap replacements they were getting killed, many have come back to near earth on prices. I've heard several complaints about the aftermarket cheapies. I NEVER found an inexpensive way to get the physical key that fits the fob replaced.
My second choice would be to check eBay for a genuine OEM unit. My local dealer reprogrammed ours for free, regular price was $20.00 back in 2018. My '16 300 only came with one fob so I only gave them one for the '13 I traded, that's the one I had reprogrammed. 4+ years later, no problems at all.
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: Cheapest way to get a new key/fob for a 2017 ram [Re: 3hundred] #3056253
07/05/22 01:19 PM
07/05/22 01:19 PM
Minnesota
Minnesota
I just called a stealership. $205 plus tax without the mechanical key insert 25 bucks more for that. And they said if I brought in a key that I got elsewhere did charge me a hundred bucks to program it.
Looking for a cheaper solution.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Cheapest way to get a new key/fob for a 2017 ram [Re: Hemi_Joel] #3056259
07/05/22 01:24 PM
07/05/22 01:24 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Have you checked the local locksmiths?
Re: Cheapest way to get a new key/fob for a 2017 ram [Re: Hemi_Joel] #3056260
07/05/22 01:26 PM
07/05/22 01:26 PM
New Jersey
P
Powerflow Offline
Powerflow  Offline
P
New Jersey
Call a local locksmith and see what they quote. With only one existing remote, whoever does the job will need to contact a dealer because there is a PIN to access the key programming function.
Re: Cheapest way to get a new key/fob for a 2017 ram [Re: Powerflow] #3056271
07/05/22 01:37 PM
07/05/22 01:37 PM
Las Vegas, NV
Tom_440 Offline
Tom_440  Offline
Las Vegas, NV
A local locksmith may do it cheaper than the dealer. There is a "Pin" code they need - it might be in your manual, or not. Without the pin, they will need to contact the dealer and may charge you for that. so when you are asking for quotes, ask if there is an extra charge to contact the dealer for the code up front.
You might look into this DIY option - I didn't try it as I was not certain it would work with the push start in my Challenger https://tomskey.com/collections/dodge-ram-2013-2017
Re: Cheapest way to get a new key/fob for a 2017 ram [Re: Hemi_Joel] #3056287
07/05/22 01:56 PM
07/05/22 01:56 PM
Tucson, AZ
Ramrod39 Offline
My New Title
Ramrod39  Offline
My New Title
Tucson, AZ
Went through this with the wife's '16 Journey a year or so ago. Looked at fobs from aftermarket sources, talked with locksmiths, etc. Many issues appeared to be problematic. Finally decide not to struggle with it and took it to the dealer. Was about $200 and works well now.
Re: Cheapest way to get a new key/fob for a 2017 ram [Re: Hemi_Joel] #3056292
07/05/22 02:03 PM
07/05/22 02:03 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
You might hit the Ram truck forums and see if anyone close to you has the AlfaOBD app and a gateway bypass. It may even be the cheapest way for you if you were to purchase the app and bypass. Together, you are looking at about $100 and they can do so much more than just program your fob. Lots of threads on this on the Ram forums and lots of videos on Youtube. I have it and it is cool!
Introduction: www.youtube.com/watch?v=YreBRFZ7FsU&t=415s
Programming fob: www.youtube.com/watch?v=TdeUN3YmSNs
And by the way, AlfaOBD works on most late model Mopar family vehicles and can unlock many extra features that were options on your truck but not initially activated. Again, really cool. Check it out!
Master, again and still
Re: Cheapest way to get a new key/fob for a 2017 ram [Re: Tom_440] #3056297
07/05/22 02:07 PM
07/05/22 02:07 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
The owner of the vehicle can get the PIN from the dealer, you have to prove ownership of the vehicle to get it.
As already stated, a locksmith can program the FOB's.
I've bought them off eBay and had a locksmith program them.
You need to take all the FOB's you have with you when you go to the locksmith so they can program all of them at the same time.
EBay has been the cheapest on the actual FOB's themselves.
Re: Cheapest way to get a new key/fob for a 2017 ram [Re: DaveRS23] #3056307
07/05/22 02:31 PM
07/05/22 02:31 PM
moparx Offline
moparx  Offline
Dave, do you or anyone know if there is an AlfaOBD or similar tool available for older year vehicles ?
say from 98-2010 or so ?
beer
Re: Cheapest way to get a new key/fob for a 2017 ram [Re: moparx] #3056429
07/05/22 06:31 PM
07/05/22 06:31 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Here is Alfaobd's support list. Some models go back to '04 or '05. Beyond that, I don't know of any other ones for the 'older' models.
www.alfaobd.com/supported_cars.html
Re: Cheapest way to get a new key/fob for a 2017 ram [Re: DaveRS23] #3056441
07/05/22 07:25 PM
07/05/22 07:25 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I just got another FOB from the dealer last week. Mine is the put it in the switch type though. Someone ripped the rubber membrane and it wouldn't work. The service guy took it in the back, found a used one that nobody claimed, and changed it out. Ask your dealer if they have any laying around that could be programmed... wave
JB Rhinehart, Realist
A-Body's RULE!
Re: Cheapest way to get a new key/fob for a 2017 ram [Re: DaveRS23] #3056631
07/06/22 12:15 PM
07/06/22 12:15 PM
moparx Offline
moparx  Offline
thanks for the link Dave. up
beer
Re: Cheapest way to get a new key/fob for a 2017 ram [Re: moparx] #3057141
07/07/22 01:41 PM
07/07/22 01:41 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
You can get the Fobs for key start easy and cheap. The push to start button Fobs are different electronically. Not available nearly as cheap.
Doug
Re: Cheapest way to get a new key/fob for a 2017 ram [Re: dvw] #3057700
07/09/22 03:50 PM
07/09/22 03:50 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
My experience was with local locksmith. He gave me 2 choices. Buy a new or used fob from someone else and he would charge me to do the programming or pay him get a used one from his source and he would program it for free. The second option was actually cheaper and was guaranteed. No guarantee if I bought one somewhere else. Obviously I went with option 2. Looks like new and no problems for four years.
