727 tailshaft issue? #3027344
03/25/22 11:35 AM
03/25/22 11:35 AM
San Diego
JP8 Offline OP
JP8  Offline OP
San Diego
[Please pay attention to the engine being in the correct location and two parts of the transmission being forward by 1/2"
I recently installed a rebuilt 318 and 727 in my 76 D100 2wd SWB. The truck originally had a different 318/727. My issue started with the crossmember mount not lining up with the through bolt. It is too far forward by 1/2". Initially I was thinking the whole engine/trans needed to be shifted to the rear more. Looking at the distributor cap verifies that the engine is definitely in the right location so it must be the trans mount, right? The engine mounts are in the exact same location that the original was.
I bought this Korean trans mount from Rock Auto where there are no reviews. So I went to Summit to find a different brand and I saw they also carry the Korean (Anchor brand) mount with terrible reviews. Looking at the reviews confirms that these are terrible but I didn't read any reviews with my particular bolt hole location issue.
Marching on, I called my Dad and he is sending me the original mount that came off the truck. He took the original 318/727 out of state to where he lives. I will just put a new bushing in the mount.
Sooooo, continuing, while I wait for the mount in the mail I decided to put on the trans cooler lines. What do you know, the fittings are too far forward by 1/2" too! I had to make a little bend in the cooler line to get the flare nut to be in the right position for the fitting.
I am stumped. It just seems that the tailshaft is forward 1/2" due to the mount and cooler fittings both being forward. The trans was rebuilt and in a B-body so it is a long tailshaft. To my knowledge th truck tail is the same, other than the car version having the floor shifter mounting ears. The trucks takeout 727 did not have the floor shifter ears but this current one does. I have never heard of there being two different length long tailshafts.
Anyone have knowledge of this? Is it just coincidence that the lines are long and the Korean mount is of poor quality? Is there a 1/2" difference in truck and car "long tailshafts"?
Instagram : @5_points_racing
Re: 727 tailshaft issue? [Re: JP8] #3027350
03/25/22 11:41 AM
03/25/22 11:41 AM
San Diego
JP8 Offline OP
JP8  Offline OP
San Diego
Pics
2CF4CF82-8CAA-4C89-B463-A57335410FCD.jpeg1CBBE253-0A19-4BC7-A36E-EDE9193D323E.jpegIMG-2691.jpg3317FA08-567E-468D-9DF9-F875CF2ED2F6.jpeg
Re: 727 tailshaft issue? [Re: JP8] #3027363
03/25/22 12:05 PM
03/25/22 12:05 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Not familiar with SB blocks but is it possible you installed the mount brackets on the wrong side of the block ears or swapped sides?
Re: 727 tailshaft issue? [Re: John_Kunkel] #3027367
03/25/22 12:09 PM
03/25/22 12:09 PM
San Diego
JP8 Offline OP
JP8  Offline OP
San Diego
That was my first initial thought when I was lying under the truck fiddling with the trans mount. I got up and looked in the engine bay. The truck engine mounts won’t go on the block other than how I have it AND the distributor cap is as close to the firewall as it can go.
The engine is in the right spot.
Re: 727 tailshaft issue? [Re: JP8] #3027402
03/25/22 02:03 PM
03/25/22 02:03 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
The transmission mount has the metal ears on it and the one stud on the bottom? The stud is usually biased one way or the other. So you could have installed the rubber mount backwards. It is about 1/2” difference
best of 11.53 at 117 mph 1.62 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: 727 tailshaft issue? [Re: FurryStump] #3027405
03/25/22 02:06 PM
03/25/22 02:06 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
Re: 727 tailshaft issue? [Re: JP8] #3027408
03/25/22 02:19 PM
03/25/22 02:19 PM
Guitar Jones Offline
The engine mounting brackets go on the back side of the block ears. It is possible on earlier blocks to move them to the front of the ears, that is how I moved the engine rearward in my Duster, and with a little work you can do it on the later blocks as well. Post up some pics of your mounting brackets.
A long tailshaft is a long tailshaft, the trans mount bolt holes are all in the same place. Maybe post up some pics of the trans, mount and crossmember. Some trans mounts have elongated holes where they bolt to the tailshaft, I've seen some that don't.
I don't think distributor to firewall clearance is a good indicator as if you raise the back the clearance will increase. So exactly where the height of the tailshaft is will affect the clearance at the firewall.
I raise chickens, so I am literally a chicken tender.
The Scamp is sold, now just two old trucks and one newer one.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case.
Re: 727 tailshaft issue? [Re: FurryStump] #3027410
03/25/22 02:23 PM
03/25/22 02:23 PM
Originally Posted by FurryStump
This is not a truck mount.
Re: 727 tailshaft issue? [Re: Guitar Jones] #3027413
03/25/22 02:31 PM
03/25/22 02:31 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Mount like this you need. Get this mount and get the front brackets in the proper place. You are to far forward so quit changing things.
Re: 727 tailshaft issue? [Re: NITROUSN] #3027415
03/25/22 02:38 PM
03/25/22 02:38 PM
San Diego
JP8 Offline OP
JP8  Offline OP
San Diego
Correct. This is the exact one. Rock Auto.
Re: 727 tailshaft issue? [Re: JP8] #3027416
03/25/22 02:39 PM
03/25/22 02:39 PM
San Diego
JP8 Offline OP
JP8  Offline OP
San Diego
Re: 727 tailshaft issue? [Re: JP8] #3027418
03/25/22 02:43 PM
03/25/22 02:43 PM
N
NITROUSN Offline
NITROUSN  Offline
N
The motor needs to go back. Period. The cooler lines tell you that along with everything else. Where did you get the front brackets from? They might be the problem.
Re: 727 tailshaft issue? [Re: NITROUSN] #3027431
03/25/22 03:11 PM
03/25/22 03:11 PM
San Diego
JP8 Offline OP
JP8  Offline OP
San Diego
The brackets are the same, new bushings though. The distributor is telling me the engine is in the right spot. It is a finger’s width in front of the firewall.
I’m not going to rule that out though. Need to get that original mount. Someone suggested the trans Crossmember may need to be rotated 180 degrees but it looks pretty symmetrical.
Re: 727 tailshaft issue? [Re: JP8] #3027436
03/25/22 03:21 PM
03/25/22 03:21 PM
N
NITROUSN Offline
NITROUSN  Offline
N
If the transmission is hanging down a bit the clearance will be less. The brackets on the greasy motor in your pictures shows an offset in the mount to bracket. Maybe you have the brackets on the wrong side.
Re: 727 tailshaft issue? [Re: NITROUSN] #3027459
03/25/22 04:11 PM
03/25/22 04:11 PM
San Diego
JP8 Offline OP
JP8  Offline OP
San Diego
The truck brackets are labeled RR and LR. On the truck's cross member there are three locations where a engine mount can go, B/RB, /6, and LA. The engine mounts are in the correct holes in the crossmember.
Someone suggested the crossmember may need to rotate 180 degrees. I did take it out and clean it up. Perhaps it is on wrong, but just looking at it, it appears to be symmetrical from side to side. I will flip it around. When I get the original trans mount I will re-bushing it, lift the engine/ trans and bolt the trans mount in first, then lower the assembly. Hopefully the engine mounts land in the right spot.
I'm coming around to the idea that the engine could go back a bit more. The distributor is aftermarket and bigger than the original tan cap. Perhaps it is not as far back as I think it should be.
Re: 727 tailshaft issue? [Re: JP8] #3028513
03/28/22 09:56 PM
03/28/22 09:56 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I don't know about the Magnum Engine stuff, but when I changed a 318 LA to a 360 LA, the engines' motor mount bosses were about 1/2" different on one side (I think the drivers side?)
Also the 318 lower engine to trans bracket was about 1/2" shorter too. As I recall I just used a big nut as a spacer and longer bracket to trans bolt.
On the engine mount, I think I may have had one mount (think passenger side?) mounted front to back between the frame and motor mount?
That was back around 1980 on my 1973 Power Wagon W150.
Re: 727 tailshaft issue? [Re: 451Mopar] #3056435
07/05/22 07:01 PM
07/05/22 07:01 PM
San Diego
JP8 Offline OP
JP8  Offline OP
San Diego
Just so I don't leave this issue un-tied I did seem to fix this issue of the engine/trans setting back too far. I flipped the transmission crossmember around. I should have paid attention when I took it out but it did look symmetrical. When I was orientating it the right way I did notice differences , front to back. Also, the stamped part number goes on the driver's side.
Re: 727 tailshaft issue? [Re: JP8] #3056460
07/05/22 08:38 PM
07/05/22 08:38 PM
Glad you got it straightened out. I like your truck.
