Cheapest way to get a new key/fob for a 2017 ram
#3056229
07/05/22 12:40 PM
07/05/22 12:40 PM
Posts: 7,477 Minnesota
Hemi_Joel
Minnesota
My 2017 ram came with two keys. But they're not really a key. It's an electronic fob. You don't even stick it in a hole in the dash to start the truck. You just have to have it in your pocket and press a button on the dash. My wife lost one of them. I hate going to the dealership and getting robbed.
What is the cheapest place / way to get a replacement key?
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
Re: Cheapest way to get a new key/fob for a 2017 ram
[Re: Hemi_Joel]
#3056236
07/05/22 12:47 PM
07/05/22 12:47 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
I'd check the dealer price first. With all the cheap replacements they were getting killed, many have come back to near earth on prices. I've heard several complaints about the aftermarket cheapies. I NEVER found an inexpensive way to get the physical key that fits the fob replaced.
My second choice would be to check eBay for a genuine OEM unit. My local dealer reprogrammed ours for free, regular price was $20.00 back in 2018. My '16 300 only came with one fob so I only gave them one for the '13 I traded, that's the one I had reprogrammed. 4+ years later, no problems at all.
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: 3hundred]
#3056253
07/05/22 01:19 PM
07/05/22 01:19 PM
Hemi_Joel
Minnesota
I just called a stealership. $205 plus tax without the mechanical key insert 25 bucks more for that. And they said if I brought in a key that I got elsewhere did charge me a hundred bucks to program it. Looking for a cheaper solution.
[Re: Powerflow]
#3056271
07/05/22 01:37 PM
07/05/22 01:37 PM
Posts: 5,134 Las Vegas, NV
Tom_440
Las Vegas, NV
A local locksmith may do it cheaper than the dealer. There is a "Pin" code they need - it might be in your manual, or not. Without the pin, they will need to contact the dealer and may charge you for that. so when you are asking for quotes, ask if there is an extra charge to contact the dealer for the code up front. You might look into this DIY option - I didn't try it as I was not certain it would work with the push start in my Challenger https://tomskey.com/collections/dodge-ram-2013-2017
[Re: Hemi_Joel]
#3056292
07/05/22 02:03 PM
07/05/22 02:03 PM
Posts: 12,008 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
You might hit the Ram truck forums and see if anyone close to you has the AlfaOBD app and a gateway bypass. It may even be the cheapest way for you if you were to purchase the app and bypass. Together, you are looking at about $100 and they can do so much more than just program your fob. Lots of threads on this on the Ram forums and lots of videos on Youtube. I have it and it is cool! Introduction: www.youtube.com/watch?v=YreBRFZ7FsU&t=415sProgramming fob: www.youtube.com/watch?v=TdeUN3YmSNsAnd by the way, AlfaOBD works on most late model Mopar family vehicles and can unlock many extra features that were options on your truck but not initially activated. Again, really cool. Check it out!
Master, again and still
[Re: Tom_440]
#3056297
07/05/22 02:07 PM
07/05/22 02:07 PM
Posts: 10,126 A Red State
SNK-EYZ
A Red State
A local locksmith may do it cheaper than the dealer. There is a "Pin" code they need - it might be in your manual, or not. Without the pin, they will need to contact the dealer and may charge you for that. so when you are asking for quotes, ask if there is an extra charge to contact the dealer for the code up front. You might look into this DIY option - I didn't try it as I was not certain it would work with the push start in my Challenger https://tomskey.com/collections/dodge-ram-2013-2017 The owner of the vehicle can get the PIN from the dealer, you have to prove ownership of the vehicle to get it. As already stated, a locksmith can program the FOB's. I've bought them off eBay and had a locksmith program them. You need to take all the FOB's you have with you when you go to the locksmith so they can program all of them at the same time. EBay has been the cheapest on the actual FOB's themselves.
[Re: moparx]
#3056429
07/05/22 06:31 PM
07/05/22 06:31 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Here is Alfaobd's support list. Some models go back to '04 or '05. Beyond that, I don't know of any other ones for the 'older' models. www.alfaobd.com/supported_cars.html
[Re: dvw]
#3057700
07/09/22 03:50 PM
07/09/22 03:50 PM
Posts: 4,711 Moved to N.E. Tennessee
GomangoCuda
My experience was with local locksmith. He gave me 2 choices. Buy a new or used fob from someone else and he would charge me to do the programming or pay him get a used one from his source and he would program it for free. The second option was actually cheaper and was guaranteed. No guarantee if I bought one somewhere else. Obviously I went with option 2. Looks like new and no problems for four years.
