Page 1 of 3 1 2 3
ATF favorite type brand , does it matter ? #3055543
07/03/22 03:00 PM
07/03/22 03:00 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
The person that built my transmission (s) Says to use only , Pennzoil Dex/ Merc..
due to whatver , no one in this area seems to carry it, only thing my google search came up with Wal-Mart for $17.XX something a quart .. good lord in heaven!
Local farm store does have Valvoline DEX/ MERC for $5.99 a quart, are they compatible?
What does everyone else use ?
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: ATF favorite type brand , does it matter ? [Re: bigdad] #3055561
07/03/22 03:59 PM
07/03/22 03:59 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
As long a the fluid meets the spec, the brand doesn't matter. Personally, I'd prefer Valvoline over Pennzoil (brand loyalty)
Re: ATF favorite type brand , does it matter ? [Re: John_Kunkel] #3055569
07/03/22 04:08 PM
07/03/22 04:08 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Lucas Racing ATF
Re: ATF favorite type brand , does it matter ? [Re: bigdad] #3055620
07/03/22 07:10 PM
07/03/22 07:10 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Brand is irrelevant spec is more important
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: ATF favorite type brand , does it matter ? [Re: W.I.N. Racing] #3055641
07/03/22 09:18 PM
07/03/22 09:18 PM
Central TEXAS!!!!
sr4440 Online content
sr4440  Online Content
Central TEXAS!!!!
^^^^This^^^^
TES-295 or TES-668
Without Data, you’re just another guy with an opinion.
Re: ATF favorite type brand , does it matter ? [Re: sr4440] #3055677
07/03/22 10:57 PM
07/03/22 10:57 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Cheapest Wal-Mart type F.
Lots of street/strip abuse in a heavy street car that runs low 10's with a close to stock 727.
'63 Dodge 330
11.19 @ 121 mph
Re: ATF favorite type brand , does it matter ? [Re: GY3] #3055679
07/03/22 11:01 PM
07/03/22 11:01 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Ssssshhhhhh. Now you went and did it.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: ATF favorite type brand , does it matter ? [Re: GY3] #3055711
07/04/22 07:39 AM
07/04/22 07:39 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Yep same here.
68 Barracuda Formula S 340
Re: ATF favorite type brand , does it matter ? [Re: John_Kunkel] #3055721
07/04/22 08:56 AM
07/04/22 08:56 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I'm with you, I've run Valvoline in every application for over 50 years with zero problems. Now is something else better, or at least comparable, probably so but I'm not risking anything to find out.
Re: ATF favorite type brand , does it matter ? [Re: bigdad] #3055736
07/04/22 10:14 AM
07/04/22 10:14 AM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
Valvoline Type-F here, but as the others have pointed out, it's about the specs more than the brand, it helps though if you've had a good history with their products...I did, and keep on using Valvoline here on all of our stuff.
See attached specs sheet.
Attached PDF document
Re: ATF favorite type brand , does it matter ? [Re: Diplomat360] #3055740
07/04/22 10:55 AM
07/04/22 10:55 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
I attended several of the drag race seminars that Tom Hoover and few other engineers put on back in the 70's They had to repeatedly state use any brand type F. All the same. People just couldn't wrap thier head around the idea of using Ford fluid in their Mopar trans.
They wanted to believe that the huge premium they paid for the B&M blue stuff means that it must be better. Nope, it's type F with blue dye for a lot more money. Only difference is the color of the stain on your garage floor. Great marketing B.S. though.
Re: ATF favorite type brand , does it matter ? [Re: pittsburghracer] #3055743
07/04/22 11:00 AM
07/04/22 11:00 AM
Mo.
racerx Offline
racerx  Offline
Mo.
blah rant...this is why i probably not able to find it there anymore laugh2
Re: ATF favorite type brand , does it matter ? [Re: 6PakBee] #3055751
07/04/22 11:18 AM
07/04/22 11:18 AM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
Same here. The problem that I have run into with Valvoline, is that MOST of their products (not just ATF) has gone from "conventional" to "synthetic blend". I'm old school for sure, and don't like changing horses in the middle of the stream. But it's either that or do with out. Not real sure about syn ATF in a race transmission?
Brian
Re: ATF favorite type brand , does it matter ? [Re: bigdad] #3055752
07/04/22 11:18 AM
07/04/22 11:18 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
I'm a proponent of synthetic ATF, especially for street/strip use where there can be extended high-slippage conditions. It's all about the heat breaking down the fluid and synthetic can take higher temps than conventional.
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: ATF favorite type brand , does it matter ? [Re: Brad_Haak] #3055818
07/04/22 12:31 PM
07/04/22 12:31 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Carquest Type FA when it was still made by Ashland. Don't even see it around even though Type FA fluid still shows up on the Valvoline site. Worked in the 2 and 3 speeds. Normally could still see the writing on the frictions after many runs. Wear was minimal over time when I measure the clutch plate thicknesses.
I tried Amsoil synthetic once. Made the high gear clutches streak black from slipping. Back to FA and it was good.
Have been told the Amsoil synthetic Type F is good. Never tried it as I changed fluid often enough that the cost would have been excessive.
I want the friction elements to lock up with a minimum of slippage. Not have a nice smooth shift so Grandma doesn't complain.
JD Hy-Gard is the current hot lick I believe. Especially in high horsepower applications. I've even heard of guys using shock oil. Maybe BS, maybe not.
Re: ATF favorite type brand , does it matter ? [Re: CMcAllister] #3055847
07/04/22 01:18 PM
07/04/22 01:18 PM
A shed in England
Tig Online work
Tig  Online Work
A shed in England
We've been using John Deere Hy Gard for around 15years. Someone on here recommended it saying it tightens the stall a little. We had just re-built the trans so we bought Hy Gard as it was a little cheaper than ATF locally. Still using it to this day, never had any issues but never noticed any change in stall either. It's still a little cheaper than ATF but both have almost doubled in price since then.
Re: ATF favorite type brand , does it matter ? [Re: Tig] #3055849
07/04/22 01:30 PM
07/04/22 01:30 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Available in different viscosities. They will make a difference.
I've heard the rumor that ATI fluid is Hy-Gard. It's available in different viscosities.
Re: ATF favorite type brand , does it matter ? [Re: pittsburghracer] #3055867
07/04/22 02:19 PM
07/04/22 02:19 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
LOL!
It's funny how people will spend money for no reason.
The only time I've had steels start to blue is when we were doing lots of street type races and leaving in 2nd gear for traction. Fluid never burned, mind you. I keep tabs on everything because we use almost all stock type parts and I see no reason to change from what the DC/MP guys recommended back in the day
'63 Dodge 330
11.19 @ 121 mph
Re: ATF favorite type brand , does it matter ? [Re: racerx] #3055877
07/04/22 02:52 PM
07/04/22 02:52 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Next ask the same question about oil....Then converters, this can be fun smile
Re: ATF favorite type brand , does it matter ? [Re: '72CudaRacer] #3055883
07/04/22 03:04 PM
07/04/22 03:04 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Brian
Interesting you say that. I always ran 5W-30 Valvoline conventional in wifey's Tribeca. One day I bee-bop down to NAPA and can't find it. All I can find is 'synthetic blend'. So I go home, get a bottle of what I'd been using and go back asking why the disappearing act. So the owner gets on the Ashland tech line and is told that the 5W-30 was always a synthetic blend and it had to be to get the viscosity range. Nothing has changed except the bottle. Okay, I buy the synthetic blend and change oil. Next oil change I go back to NAPA and lo and behold, conventional 5W-30 is back on the shelf! Happy camper buys three cases. Use them up and go to NAPA a week ago to buy some more and...wait for it...."synthetic blend" 5W-30 is all they have. Don't ask me what is going on. I don't know and the owner doesn't know. shruggy
Page 1 of 3 1 2 3
