Re: Holley dominator issues
[Re: Cape]
#3055286
07/02/22 03:00 PM
07/02/22 03:00 PM
Posts: 3,909 Washington
madscientist
Washington
Probably 3 circuits and no power valve. Way more work to unscrew it.
[Re: fbs63]
#3055426
07/03/22 08:08 AM
07/03/22 08:08 AM
Posts: 4,117 Milford, OH
markz528
Milford, OH
So it was a used carb? Could someone have messed with it?
If you send it to Gary pretty sure he will charge you for a full rebuild. My experience with him on that is that won’t be cheap.
67 Coronet 500 9.610 @ 139.20 mph 67 Coronet 500 (street car) 13.300 @ 101.75 mph 69 GTX (clone) - build in progress......
[Re: Cape]
#3055446
07/03/22 09:31 AM
07/03/22 09:31 AM
Posts: 19,313 State of confusion
Thumperdart
State of confusion
That's a lot of carb for only 850 hp for starters and usually if it falls on it's face like turning off a light switch, it lean not rich. If it blubbers then picks up it's usually rich.. I run 1050ish billets on similar combos and they run awesome and support 950+ hp easily....
[Re: Cape]
#3055483
07/03/22 10:41 AM
07/03/22 10:41 AM
Posts: 30,213 Oregon
AndyF
Could be anything. Maybe something simple or it could be something really wrong. Only way to know is to take it all apart and try to figure it out. That size of carb will make great power on the dyno but it might not drive very well on the street. You'll just have to figure out what your priorities are. A nice 1050 usually works best for the street and often for the track. Once you get to the really big carbs they can act a little "funny". We've run a lot of big carbs on the dyno and most of them have problems. The 1050 design is very solid and there are really good 1250 carbs out there but the big carbs seem to have issues more often than not. You might try Lightning Carbs https://www.facebook.com/lightningracingcarburetors/ He is a Moparts member but I haven't seen him post for a while. He has a booster flow setup so he can figure out pretty quickly if the carb is going to work or not. My guess is that your carb has some sort of booster issue. If so, it can be a difficult thing to sort out without having the correct tools. The really big carbs sometimes have booster signal issues and the average guy doesn't have a chance to solve that stuff. Good luck!
