Re: How to shorten a sway bar...maybe [Re: hemienvy] #3057348
07/08/22 07:48 AM
07/08/22 07:48 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Maybe if you gave us some dimensions of what you are looking for it could help
Might even be that an A body bar would fit but right now no one can say because you haven't given any useful info.
Not sure why it has to be like pulling teeth.
Re: How to shorten a sway bar...maybe [Re: Sniper] #3057373
07/08/22 11:05 AM
07/08/22 11:05 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
On an E-body rear, I've seen it done a few different ways.
1. Bend the ends that the end-links attach to inward so they line up with the leaf spring bracket.
2. Modify the leaf spring brackets so the end link attachment point is out farther.
3. Use offset end links so no sway bar or attaching bracket modifications are needed.
If the sway bar is going to hit the sidewall...that's another issue.
Re: How to shorten a sway bar...maybe [Re: burdar] #3058637
07/12/22 04:14 PM
07/12/22 04:14 PM
Mequon, WI
gzig5 Offline
gzig5  Offline
Mequon, WI
I'm going to have to deal with same issue and am planning to make up some offset links, as shown. Bending it in a touch on either side is my second option if I don't do a custom bar.
Re: How to shorten a sway bar...maybe [Re: gzig5] #3058671
07/12/22 07:24 PM
07/12/22 07:24 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Well I might be in a pickle.The tire is pretty close to the frame rail.
The OE sway bar sticks out of the mounts past the frame rail enough to hit the tire, I THINK. I can't mock it up just yet.
So the bar needs to be narrower, plus I have to figure out a different mounting, I THINK.
