Page 1 of 4 1 2 3 4
For Sale - Small Block Engine - 3rd Quarter #3055042
07/01/22 09:23 PM
07/01/22 09:23 PM
Norwich CT USA
moparts Offline OP
moparts  Offline OP
Norwich CT USA
p3614514 340 Trans Am rods [Re: moparts] #3055056
07/01/22 09:53 PM
07/01/22 09:53 PM
Washington
hemienvy Offline
hemienvy  Offline
Washington
NOS set, perfect shape, standard SB dimensions but far stronger. 7/16 bolts.
$1000.
Re: For Sale - Small Block Engine - 3rd Quarter [Re: moparts] #3055252
07/02/22 01:45 PM
07/02/22 01:45 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
SOLD
Edelbrock D4B
I have an Edelbrock D4B I’m not going to use, pretty good shape. Several bolt hole threads were buggered up so we did a Helicoil repair. Just needs bead blasting.
$250 plus shipping
given the shipping costs these days buyer chooses the shipping method. Also, the part is up in Washington state so shipping will be calculated from there.
Mesa, AZ
Re: For Sale - Small Block Engine - 3rd Quarter [Re: moparts] #3055359
07/02/22 09:28 PM
07/02/22 09:28 PM
MI
6PAX Offline
6PAX  Offline
MI
Chrome six pack lid. Original lid that has been chromed. $100
70 B-body voltage regulator mounting bracket. $15
New chrome coil cover & coil mounting bracket. $20
NOS Cal Custom chrome radiator cap. $20
NOS Cal Custom chrome battery hold down. $25
Four new extra wide chrome valve cover hold down clamps. $10 for the set
New exhaust manifold heat stove to air cleaner flexible hose. $20
NOS fan clutch 3769614 for 1974 all V-8 engines. $100
Factory oil pressure sending unit. $10
Vintage Cal Custom 14" finned aluminum air cleaner with filter. $100
1970 Style single nipple oil breather with hose. $30
New 12" oval 4 barrel finned aluminum air cleaner with filter. It measures 12" L x 8 1/4" W x 3" H and has a 5 1/8" carb opening. $60
New Mopar Performance chrome water neck. Was bolted on an engine but then taken back off before the engine was ran. $10
AC alternator bracket from a mid 70s 360. $10
New Mr. Gasket chrome oil filter cover. $15
137 New Spectre brand radiator and heater hose clamp covers. Some chrome, some red and some blue anodized. Various sizes. $50 for the lot.
9 Chrome t-handle valve cover bolts. $10
Two 318 driver side spool motor mounts pt#3642811. One is used and one is NOS. $20 for the used. $35 for the NOS.
Edelbrock small block valve covers EDL-4295 with breather & PCV valve. $200
NOS Cal Custom chrome dagger dipstick handle. $25
New Mopar Performance 5 blade radiator fan and clutch. $100
Pioneer Automotive cylinder head dowel pins. 21 pieces 1/4" x 5/8". $10
Chrome single groove alternator pulley. $15
1975 Date coded alternator. Part #3874271. $25
Vintage Cal Custom scoop style air cleaner. Includes often missing matching wingnut. $300
Alternator date coded 1965. $35
Prices do not include shipping. No Paypal
Email: gt340 @ yahoo.com
Holley #12-800 Billet Electric Fuel Pump "NEW" [Re: moparts] #3055539
07/03/22 02:54 PM
07/03/22 02:54 PM
Northwest Indiana
19Coronet66 Offline
19Coronet66  Offline
Northwest Indiana
For sale is a "NEW" Holley electric fuel pump. 80 GPH. 14 amps. Supports up to 800 HP with EFI & 900 HP with a carburetor. No longer have the box for it but guarantee it to be new. Never attempted to install it. $265 shipped in the 48 states.
https://www.summitracing.com/parts/hly-12-800
Holley 12-846 HP Billet Fuel Pressure Regulator "NEW" [Re: moparts] #3055540
07/03/22 02:56 PM
07/03/22 02:56 PM
Northwest Indiana
19Coronet66 Offline
19Coronet66  Offline
Northwest Indiana
For sale is a "NEW" in the box Holley HP Billet adjustable fuel pressure regulator. Part number 12-846. EFI applications. Bypass style. Adjustable from 15-65 PSI. -8AN o-ring inlet. -8AN o-ring outlet. -6AN o-ring return. $175 shipped in the 48 states. PM if interested.
https://www.summitracing.com/parts/hly-12-846
Holley HP Billet Fuel Filters (2) "NEW" [Re: moparts] #3055542
07/03/22 02:59 PM
07/03/22 02:59 PM
Northwest Indiana
19Coronet66 Offline
19Coronet66  Offline
Northwest Indiana
For sale are a pair of "new" Holley HP billet fuel filters. #162-554 = -8AN inlet & outlet . Rated @ 175 GPH. 10 Micron. $85 shipped in the 48 states.
#162-564 = -8AN o-ring inlet & outlet. Rated @ 175 GPH. 100 Micron. $85 shipped in the 48 states.
Both filters are designed to be used before & after an electric fuel pump.
PM if interested
https://www.summitracing.com/parts/hly-162-564
https://www.summitracing.com/parts/hly-162-554
Re: Small Block 90 degree oil filter adapter [Re: DusterKid] #3056826
07/06/22 05:39 PM
07/06/22 05:39 PM
A Red State
SNK-EYZ Online tonguue
SNK-EYZ  Online Tonguue
A Red State
Small block Mopar 90 degree angle filter adapter, cast iron.
Fits 318, 340 and 360 engines. Used.
Asking $150 plus shipping.
Message me through Moparts or email me at richdetert@sbcglobal.net
IMG_5055 (2).JPG (930 downloads)
IMG_5057 (2).JPG (930 downloads)
Re: For Sale - Small Block Engine - 3rd Quarter [Re: moparts] #3057623
07/09/22 11:14 AM
07/09/22 11:14 AM
Edison, NJ 08817
budman1965 Offline
budman1965  Offline
Edison, NJ 08817
Holley small block Strip Dominator intake manifold. Intake is used but fairly clean. Has not been modified or cut. Longer carb studs intact. Needs some cleanup before installation. Asking $250. Will be at the All Chrysler Nationals July 14-16. Contact Bud: Kramden426 at aol.com
Re: For Sale - Small Block Engine - 3rd Quarter [Re: moparts] #3057626
07/09/22 11:21 AM
07/09/22 11:21 AM
Edison, NJ 08817
budman1965 Offline
budman1965  Offline
Edison, NJ 08817
Small block electronic ignition distributor kit. Part # P4286510. This kit has been sitting in the basement for over 25 years. Kit is new-has not been installed. Complete except wiring harness and instructions. Has extra ballast resistor. Also this includes chrome ignition box. The current kits have the orange box. Asking $250. Will be at the All Chrysler Nationals July 14-16. Contact Bud: Kramden426 at aol.com
360 Ductile Iron 4 Bolt Main Cap Set – New [Re: budman1965] #3057940
07/10/22 11:42 AM
07/10/22 11:42 AM
CT
Rocket Offline
Rocket  Offline
CT
I have a set of new ductile iron main caps available for 360 main blocks. The sets include all 5 main caps. The center 3 caps are 4 bolt main. These are the same caps that came standard on R3 4 bolt blocks. I have installed these caps on a 340 before by milling off the ends of the center caps to leave them 2 bolt. See pictures for the 3 modified center caps installed on a 340 stroker engine. These caps are more stout than the stock caps and are an excellent upgrade for any high performance build. A line bore will be needed when installing new caps as well as some machining for the thrust bearing on the #3 cap and #5 cap for the oil seal.
Price is $290 shipped per set in the lower 48 states.
Email procketrichard@hotmail.com for more information.
Small Block Rocker Arm Shafts for Adjustable Rockers - New [Re: Rocket] #3057941
07/10/22 11:44 AM
07/10/22 11:44 AM
CT
Rocket Offline
Rocket  Offline
CT
I have a few new sets of small block Mopar rocker arm shafts for LA type cylinder heads. These shafts are made here in the U.S.. They are made from thick induction hardened steel. They feature banana groves and oiling holes that are positioned for the loading of mechanical rocker arms. These shafts have screw in end plugs for inspection and easy cleaning, inspection or if desired to plumb in an oil line. These are drilled on center for 5/16” hold down bolts and are for use with stock small block Mopar heads (273, 318, 340 & 360) or aftermarket cylinder heads including Edelbrock RPM, Indy LAX or other similar shaft mounted cylinder heads where mechanical rocker arms are being used.
They can also be used for W2 Econo heads that have a cast in pedestal if the bolt holes are opened up to use 3/8” hold down bolts. They are far thicker and stiffer than stock or many aftermarket shafts to minimize flex with stiffer aftermarket valve springs.
These are not intended for W2 or W5 heads that use offset drilled shafts and stands.
Price is $180 for the pair shipped within the lower 48 states.
I can ship internationally for the additional shipping cost.
Contact procketrichard@hotmail.com for more information and pictures.
SB Shafts Pic 6.jpg (814 downloads)
Mopar Performance Small Block Pistons - New Incomplete Sets [Re: Rocket] #3057942
07/10/22 11:46 AM
07/10/22 11:46 AM
CT
Rocket Offline
Rocket  Offline
CT
I have 12 new Mopar Performance forged flat top pistons and pins. There are 3 different part numbers. There is not one complete set. Here is what I have.
P4876976 – Quantity of 6. Specs are 4.060” bore & ~ 1.67” compression height. These pistons are for a 0.060” overbore 360 with the stock stroke crankshaft or a 0.020” overbore 340 using a 3.58 stroke crankshaft.
Price for the 6 new forged pistons is $320 shipped.
P4876978 – Quantity of 4. Specs are 4.030” bore and ~ 1.67” compression height, These pistons are for a 0.030” overbore 360 with the stock stroke crankshaft
Price for the 4 new forged pistons is $220 shipped.
P5007413 – Quantity of 2. Specs are 4.030” bore and ~ 1.47” compression height, These pistons are for a 0.030” overbore 360 with a 4.00” stroke crankshaft.
Price for the 2 new forged pistons is $120 shipped.
Email me at procketrichard@hotmail.com with any questions or for more pictures.
Small Block Racer Brown Solid Flat Tappet - New [Re: Rocket] #3057944
07/10/22 11:47 AM
07/10/22 11:47 AM
CT
Rocket Offline
Rocket  Offline
CT
I have a new Racer Brown solid flat tappet cam up for sale. Specs are 585/585 lift 254/254 duration @.050 106 LSA.
Price is $250 plus $25 shipping in the lower 48 states. I will ship internationally for the extra shipping cost.
RDiamond Small Block Forged Pistons 4.070” for 4.0” Stroke [Re: Rocket] #3057947
07/10/22 11:49 AM
07/10/22 11:49 AM
CT
Rocket Offline
Rocket  Offline
CT
For sale is a used set of 8 Diamond forged flat top pistons and pins for a 4.070 bore block and using a 4.000” stroke crankshaft. These pistons use a Chevy sized 0.927” wristpin. These were used in a street-strip engine for a few summers. Diamond part number is 51008.
Bore (in.) 4.070 in.
Stroke 4.000 in.
Rod Length 6.125 in.
Piston Material Forged aluminum
Compression Height (in.) 1.457 in.
Piston Head Volume (cc) +5.60cc
Wrist Pin Style Floating
Pin Diameter (in.) 0.927 in.
Piston Ring Thickness 1/16 in. x 1/16 in. x 3/16 in.
Price is $400 plus shipping.
68-71 Small Block Throttle Cable Bracket [Re: moparts] #3059074
07/14/22 02:19 AM
07/14/22 02:19 AM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
68-71 Small Block Throttle Cable Bracket. Used, $45 + Shipping. Payment via US Postal Money Order Only! Shipping: US Address Only!
Call Steve 810-629-1097
Custom Small Block 3,4 Speed Throttle Cable Bracket [Re: Memongo] #3059075
07/14/22 02:21 AM
07/14/22 02:21 AM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
Custom Small Block 3,4 Speed Throttle Cable Bracket. Used, $25 + Shipping. Payment via US Postal Money Order Only! Shipping: US Address Only!
Note: Works with any high rise intake or carburetor spacer
Small Block Carburetor Throttle Return Spring Brackets [Re: Memongo] #3059076
07/14/22 02:23 AM
07/14/22 02:23 AM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
Small Block Carburetor Throttle Return Spring Brackets. Payment via US Postal Money Order Only! Shipping: US Address Only!
1. Small Block 67-73 273,318, 360 Return Spring Bracket Used, $10 + Shipping
2. Small Block Throttle Return Spring Bracket Used, $10 + Shipping
3-4. AAR Carburetor Return Spring Bracket. New, $15 + Shipping
Factory Small Block Valve Cover Breather [Re: Memongo] #3059077
07/14/22 02:25 AM
07/14/22 02:25 AM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
Factory Small Block Valve Cover Breather. Used, $15 + Shipping. Payment via US Postal Money Order Only! Shipping: US Address Only!
Factory Small Block Valve Covers 273,318,340,360 [Re: Memongo] #3059078
07/14/22 02:26 AM
07/14/22 02:26 AM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
Factory Small Block Valve Covers 273,318,340,360, Used, $60 + Shipping. Payment via US Postal Money Order Only! Shipping: US Address Only!
Note: All Harness, Wire Brackets Intact!
Page 1 of 4 1 2 3 4
