Pro Charger racers, which type drive?
#3054746
06/30/22 06:55 PM
06/30/22 06:55 PM
Posts: 43,215 Bend,OR USA
Cab_Burge
I'm thinking of buying and using a Pro Charger F3R-130 for a new build soon, I'm not sure if there is an advantage to using a gear driven version versus a cog belt driven set up All comments on your use are and will be appreciated Thanks in advance: Cab
Re: Pro Charger racers, which type drive?
[Re: Cab_Burge]
#3054771
06/30/22 08:24 PM
06/30/22 08:24 PM
Posts: 54 VA Beach, VA
Runnoft
VA Beach, VA
Gear drives are hands down the way to go for racing. I don't know anyone that races a procharged combo with a belt drive that doesn't get tired of constantly dealing with belts. The other advantages are - easier to change drive ratios, less drag than turning a large belt, puts the weight low and forward (at least for radial racing), and the blower inlet is front facing usually without any obstructions so good, clean and cool air. Two disadvantages - initial cost and packaging. You'll need to get creative with radiator location.
Cruiser: 66 Dodge Coronet 500, Indy SR 440, Gen 7 Accel EFI = 11.38 @ 116. Racing: Brand X, X275 Procharged Smallblock on M1, Leafsprings, Holley EFI = 4.30 @ 168
[Re: Runnoft]
#3054899
07/01/22 11:18 AM
07/01/22 11:18 AM
Posts: 2,924 A shed in England
Tig
A shed in England
Gear drives are hands down the way to go for racing. I don't know anyone that races a procharged combo with a belt drive that doesn't get tired of constantly dealing with belts. The other advantages are - easier to change drive ratios, less drag than turning a large belt, puts the weight low and forward (at least for radial racing), and the blower inlet is front facing usually without any obstructions so good, clean and cool air. Two disadvantages - initial cost and packaging. You'll need to get creative with radiator location. A guy I know runs (I think) a cogged F2 side mount, he will just go home if he throws the belt at the track. Due to the tight constraints in the engine bay it takes him 4 -5 hours to replace a belt. He's running in a street class which means treads, if the engine revs up when the tyres spin and he lifts, it throws the belt. It happens a lot unfortunately. I'd run a gear drive and work out how fit stuff around it if I was going to use a Procharger.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#3055099
07/01/22 11:33 PM
07/01/22 11:33 PM
Posts: 422 montana
BANDIT
montana
Even with the front gear drive, changing gear ratios isn't all that easier. I've worked on both. just got done switching ratios in a gear driven dragster. Had to pull engine in order to change gears, not a real big deal on dragster, could be more involved on a door car. The belt drives that I have worked on were dragsters as well, was really easy as long as you weren't making a big change, just loosen belt and change upper pulley. They do throw belts at most inappropriate times. There are also different versions of front mounts, as was mentioned earlier. Good luck, they are fun to drive! Jim.
64 Dodge Coronet 440. In progress 1998. Dodge Avenger. 8.35@165. 4400 DA 250” Neil and Parks Slip Joint. 7.36@183. 4600 DA 242" Mullis Dragster. 6.90@ 200mph
[Re: Jeff440sc]
#3056644
07/06/22 12:32 PM
07/06/22 12:32 PM
Posts: 19,372 Las Vegas
Al_Alguire
Las Vegas
IMO either work well to a point. Obviously with a side slinger you have a belt to deal with. But usually packaging is simpler and as noted any needed changes are made easier. My only experience is with drasgter using them as well
[Re: BobR]
#3057154
07/07/22 02:01 PM
07/07/22 02:01 PM
Cab_Burge
I was a dealer for Chris Alston Chassis until they got bought out by Heidt suspension and they now don't offer the crank drives that Alston use to make I'm sure you, Jason and Doug are a lot more knowledgeable on Pro Chargers and how to use them than I will learn by myself, maybe I should call them
[Re: Cab_Burge]
#3057171
07/07/22 02:33 PM
07/07/22 02:33 PM
Posts: 350 Sidney,Ohio
challenger1320
Sidney,Ohio
Indy Cylinder Heads has the complete package already worked out for the race drive setup. Everything from the motor plate to the carb all you need is the charge tube. We put one on a 540 -1 motor in a dragster and the only change we had to make was taking a little jet out of the carb. Best so far is 4.13 at 176. F3R 112 with the 136 gear set.
[Re: BobR]
#3061373
07/21/22 02:36 PM
07/21/22 02:36 PM
Al_Alguire
Las Vegas
Indy has been doing a ton of work on ProCharged Mopar stuff the last few years. As Challenger mentioned they have alot of those parts out there for BB, Hemi and Predator stuff.
