New to me d100 truck
#3054736
06/30/22 06:21 PM
06/30/22 06:21 PM
Posts: 1,828 houston texas
gremlinsteve
houston texas
Fell in love with this 80 model d100 Brought her home last night 383/727 combo runs well
if You Like Gremlinsteve. Gremlinsteve Likes You.
Re: New to me d100 truck
[Re: gremlinsteve]
#3054737
06/30/22 06:27 PM
06/30/22 06:27 PM
Posts: 4,720 Star Idaho
67vertman
Star Idaho
Nice. I have been looking for a decent and decently priced short bed for a while!
My Monster are real!
Living within your means makes life pretty easy.
[Re: Hugh Jorgan]
#3055370
07/02/22 10:01 PM
07/02/22 10:01 PM
gremlinsteve
houston texas
Nice truck. Talk to Alex much anymore? Oh yes. All the time
[Re: racerx]
#3056421
07/05/22 05:59 PM
07/05/22 05:59 PM
Posts: 168 San Diego
JP8
San Diego
Beautiful stance. What are the wheels and tire specs?
Instagram : @5_points_racing
[Re: JP8]
#3059546
07/15/22 10:31 PM
07/15/22 10:31 PM
gremlinsteve
houston texas
295/50/15 on the rear 235/50/15 on the front I think The wheels are unknown other than the rears are ten inch wide. This is the way I purchased it
I just blew out the fuel pump At least I hope that’s what it is The fuel no Getty to carb so I can only assume it’s the pump
If not the pump I’ll be needing to research the issue more from the pump back
I also received my Cvf racing kit in today This kit mounts the ac compressor I’ve bought. I also received my ac underdash system So I should be don’t with this by Monday
I’d like then to try my converter install. This stock converter works great but I’m wanting to rid myself of two issues. The massive rpm drop from park to drive. And the truck trying to push through the brakes while idling in gear
Which me luck
[Re: gremlinsteve]
#3059951
07/17/22 03:05 PM
07/17/22 03:05 PM
Posts: 1,061 Atlanta, GA
mgoblue9798
Atlanta, GA
Which me luck As far as the fuel pump goes, I have had rubber lines at the tank crack before so the pump couldn't pick up the fuel. When you disconnect the tank line from the pump, put a little air pressure in it and crawl under to listen for a possible leak. Since you are taking that line loose either way, it doesn't take long to check.
