Re: Instead of tubing Lifer Oil Galley [Re: pittsburghracer] #3054665
06/30/22 12:44 PM
06/30/22 12:44 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Originally Posted by pittsburghracer
Originally Posted by dart_73_br
Ok guys, it´s crystal clear now. Will not do that!
Thanks,
Like I said earlier get yourself and old Direct Connection book so you can understand the oiling system before diving in. I’ve never had one set up with bronze bushings because of the 600.00 and up cost of doing it. I’ve hand drilled mine and they have turned out fine. Then I use 1/2 inch copper house water pipe. If I live another 10 years I may buy a hone to make it more a slip fit. Forget to redrill one single hole and your engine is toast.
You got an example of all of my tricks. That turd went from putting rod bearings in it every 6 or 7 runs to going a full season and looking pretty good at the end of the year. I had plenty of expert shops work on it, with zero results, before I took it apart and figured it out. Had some old guy give me some tips and I ran with it.
You still have any of that? I may want to buy it back at some point.
Re: Instead of tubing Lifer Oil Galley [Re: CMcAllister] #3054674
06/30/22 12:59 PM
06/30/22 12:59 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Thanks,
To late. It’s been sitting together (short block) and hopefully my son gets his car ready and I will finish a set of Edelbrock heads I have here for him to borrow. He bought a fab 9 inch housing and is updating his car from his old 8 3/4. He also switched over to powerglide so lots of updates.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Instead of tubing Lifer Oil Galley [Re: pittsburghracer] #3054688
06/30/22 01:34 PM
06/30/22 01:34 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Thanks,
Great. Was a good piece for me once I got it squared away.
