wheel bearing grease #3054196
06/28/22 08:34 PM
06/28/22 08:34 PM
ohio
dragon Offline OP
dragon  Offline OP
ohio
What are you using for front wheel bearing grease just off the self or what race only. Thanks
Re: wheel bearing grease [Re: dragon] #3054232
06/28/22 10:56 PM
06/28/22 10:56 PM
NY
B1duster Offline
B1duster  Offline
NY
Re: wheel bearing grease [Re: B1duster] #3054483
06/29/22 06:56 PM
06/29/22 06:56 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Texas refinery 880
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: wheel bearing grease [Re: astjp2] #3054486
06/29/22 07:21 PM
06/29/22 07:21 PM
Sticky South
Rodenteliminator Offline
Sticky South
Lucas Red and Tacky, I take a grease needle and shoot just a small amount in on the rollers and I can spin my front wheels by hand as fast as I can and they will spin for a long time. Doug
Sorry honey I spent the rent
Re: wheel bearing grease [Re: dragon] #3054501
06/29/22 08:54 PM
06/29/22 08:54 PM
Dunnellon, FL
longram60 Offline
longram60  Offline
Dunnellon, FL
On my NHRA stocker, I use the grease shown on this site (also using the bearing spacers):
https://www.drpperformance.net/hub-components
1979 AMC Spirit, NHRA Q/SA
Re: wheel bearing grease [Re: longram60] #3054507
06/29/22 09:27 PM
06/29/22 09:27 PM
Southern Alberta
Uberpube Online content
Uberpube  Online Content
Southern Alberta
At a bearing seminar, the engineer from the bearing supplier was asked what grease was best. His answer was just use a grease with the correct rating for the application, and alway by a box of that grease so you always use the same grease consistently. He said that not mixing greases is way more important than the grease brand.
Re: wheel bearing grease [Re: Uberpube] #3054937
07/01/22 12:55 PM
07/01/22 12:55 PM
central il.
second 70 Offline
second 70  Offline
central il.
This had a oil rep come out and show how using 2 different greases was what caused bearings to look like they were packed with dirt. We just laughed because after all these years we thought that it was dirt. Always clean out old grease if you're not sure you're using the same can.
